somegeek
WA, USA Status: offline
quote:
ORIGINAL: somegeek quote:
ORIGINAL: chowclb hi there cwick the sickle weighs 4pound or close to 2 kilos seems very heavy but leaves you hand without throwing it and screems off only thing is the landings are a bit hot but once you get used to that there a breeze becarful of flutter i am working on resolving the problem as we speek trying some new ideas cheers chris 4lbs? Would think it closer to 2lbs to 3lbs depending on the engine and the type of material used for the fuselage. My dogfighter is on the heavy side and weighs 3lbs 11oz. Think it'd be difficult for a sickle, built to spec, to exceed 4 lbs. somegeek I will now eat my own words... my sickle AUW is 3lbs 4 oz. Gained some weight from using standard servos for the elevons(+1 oz a piece roughly when compared to smaller servos), using an O.S. .46 AX engine and have a AA sized 5-cell NiMH pack(+2 oz vs 4 cell AAA sized pack). Maiden report soon. somegeek
_____________________________
Fly safe, have fun. Measure three times, cut once. The man who makes no mistakes does not usually make anything.
