RE: 2 cycle vs 4 cycle
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> RE: 2 cycle vs 4 cycle
Page: <<   < prev  1 [2] 3   next >   >>
Login
RE: 2 cycle vs 4 cycle - 4/26/2006 2:23:47 AM
khodges
Status: offline
quote:
ORIGINAL: e-dave
Gotta agree, they sound about as much like a Merlin as a Saito 100 sounds like the Lycoming AEIO 540 in an Extra.
yeah, but my Saito 1.00 with a straight pipe sounds like a Ducati racebike comin' down the front straight at Daytona W.F.O.
_____________________________
Club Saito #2, WACO Brotherhood #20. What other trouble can I get into?
(in reply to Rebellion)
       Post #: 26
RE: 2 cycle vs 4 cycle - 4/26/2006 2:29:35 AM
Rebellion
Status: offline
quote:
ORIGINAL: khodges
quote:
ORIGINAL: e-dave
Yes, and my SS piped Jett 50 sounds like----
That's one of the things I like about a high revving two stroke, they sound like nothing else.
All a matter of personal taste I guess.
< Message edited by e-dave -- 4/26/2006 2:51:15 AM >
(in reply to khodges)
       Post #: 27
RE: 2 cycle vs 4 cycle - 4/26/2006 2:49:01 AM
loughbd
Status: offline
Now you take one of my OS 4 cylinder 4 Cycles in a Cub or my Five cylinder OS FF300 in a Fleet Biplane and you get a more realistic sound than a scrreaming 2 cycle or gasoline engine sounds like a Rolls merlin. By the way someone awile back mentioned a Packard Merlin. Now THAT would be a rare engine. Rolls Merlin or Rolls Griffin I will believe but a Rolls packard?? Nope.
Oh and turbines sound like a small vacuum cleaner.
< Message edited by loughbd -- 4/26/2006 2:54:18 AM >
       Post #: 28
RE: 2 cycle vs 4 cycle - 4/26/2006 2:55:25 AM
loughbd
Status: offline
A Jett sounds like a big Cox 049. Two cycles sound like two cycles. Whiney obnoxious noice. That's why we got kicked out of so many flying sights.
Here's a question, would you rather wake up Sunday morning to the sound of some guy using a chain saw or a guy moving his lawn with a Briggs and Stratton powered lawn mower?
< Message edited by loughbd -- 4/26/2006 3:00:44 AM >
       Post #: 29
RE: 2 cycle vs 4 cycle - 4/26/2006 3:43:02 AM
mrbonk
Status: offline
I've got both and I don't understand what all the fuss is about. They've both got applications that they're more suited to.......just depends what you want to use it for. I *love* the torque and the sound that my YS 4 strokes produce though......I can't imagine flying my Ultimate Bipe with anything else
MrBonk
http://www.mrbonk.com
       Post #: 30
RE: 2 cycle vs 4 cycle - 4/26/2006 5:33:46 AM
loughbd
Status: offline
Here's a little item for you. A four cycle engine does not have more torque than a two cycle. It has a higher BEMP, brake effective mean pressure. A two cycle firing every stroke has more torque.
< Message edited by torque wrench -- 4/26/2006 1:02:15 PM >
(in reply to mrbonk)
       Post #: 31
RE: 2 cycle vs 4 cycle - 4/26/2006 1:02:09 PM
Hobbsy
Status: offline
quote:
ORIGINAL: loughbd
ORIGINAL: loughbd
Actually it's BMEP, BMEP = 150.8 x TORQUE (lb-ft) / DISPLACEMENT (ci)
< Message edited by torque wrench -- 4/26/2006 1:05:46 PM >
"I have gone faster backwards, upside down and on fire than most people have gone at all" Don Garlits
(in reply to loughbd)
       Post #: 32
RE: 2 cycle vs 4 cycle - 4/26/2006 1:18:10 PM
mrbonk
Status: offline
quote:
ORIGINAL: loughbd
Doesn't the 2 stroke have to be doing more revs to produce the same torque? I was always lead to believe that the 4-stroke would produce better torque at lower revs, making it more suitable for swinging larger diameter, lower pitch props.
MrBonk
       Post #: 33
RE: 2 cycle vs 4 cycle - 4/26/2006 1:28:32 PM
Hobbsy
Status: offline
I know that there are examples of the opposite, for example my MVVS .91 is real torquer but my ABITAR 1.20 fourstroke is a revver, it will turn a 14x6 APC at 12,000 plus but can't handle a 15x8.
As you say the general rule is that the fourstroke will have a broader torque band.
       Post #: 34
RE: 2 cycle vs 4 cycle - 4/26/2006 1:48:27 PM
aussiesteve
Status: offline
BHP = torque (ft/lbs) x rpm / 5250
If a 2 stroke delivers more torque - why do they need to rev higher to produce the requisite horsepower to suit the engine load (created by the propeller)?
It would appear that the original question has worked. For most people there is very little practical difference - it is mostly personal preference based on the sound. The exeptions being true 3d (4 stroke) - or genuine top end speed (2 stroke) otherwise it is probably much of a muchness. -
1 lb of fuel will only contain a set amount of potential energy - it's how efficiently the engine transfers that into kinetic energy that makes the difference. - This is why, displacement for displacement, different engines have different power outputs - it's all about engine efficiency which is controlled by many factors.
BTW - BMEP is controlled by a large number of factors - most of which are to do with engine design - I would just about guarantee that, size for size and cycle for cycle, an older style of engine will produce a lower BMEP than one with later more efficient designs (Schneurle porting for instance). this also applies to combustion chamber design, valve timing atc and is a fascinating science all of it very own.
Australian agent for
RCGF engines & Boxes, 33RC airframes, Tzone models, Super Kraft (SK) & others
(in reply to Hobbsy)
       Post #: 35
RE: 2 cycle vs 4 cycle - 4/26/2006 3:24:40 PM
Sport_Pilot
Status: online
In most 2 strokes the torque is going down well before it reach's peak HP. The four stroke is limited in top RPM because of valve float, and no company as yet has tried the stiffer springs, roller tappets, overhead cam, etc, so that they will reach the same RPM. At the lower RPM many of the two stroke will attain a higher torque than an equivelant displacement four stroke.
BTW I think Hobbsy's formula is an approximation as it doesn't take in account all of the possible rod, crank, stroke and length combinations. Also I think that displacement is for one power stroke. For a four stroke the power stroke is followed with a no power intake stroke so the torque measured by a dynometer will be about half of his calculated figure.
“I Saw Elvis at 1000 Feet” John Force
(in reply to aussiesteve)
       Post #: 36
RE: 2 cycle vs 4 cycle - 4/26/2006 4:20:53 PM
loughbd
Status: offline
Yeah Dave,
I knew it was BMEP. Just didn't engage brain at the time. It will stir up a can of worms though, you watch.
< Message edited by loughbd -- 4/26/2006 4:24:05 PM >
       Post #: 37
RE: 2 cycle vs 4 cycle - 4/26/2006 11:50:16 PM
Ed Cregger
Status: offline
Well put, Steve.
I love ALL IC engines, even a Ueda .55. You had to be there.
Artisan
"Flying models since the Fifties - I'll get the hang of this yet!!!"
       Post #: 38
RE: 2 cycle vs 4 cycle - 4/27/2006 1:16:56 AM
XJet
Status: offline
Ah, now there's a name I haven't heard in a *long* while.
My most cantankerous engine was an original OS Pet. They were horrible things -- really loud (when you could get them to go) and difficult as hell to start. They'd either be dry or flooded -- with little ground inbetween.
When I'm not here, I'm at RCModelReviews
(in reply to Ed Cregger)
       Post #: 39
