RE: Top-Flite T-34    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Scale Aircraft >> RE: Top-Flite T-34
Page: <<   < prev  11 12 [13] 14 15 16 17 18 19 20   next >   >>
Login
RE: Top-Flite T-34 - 10/18/2005 5:12 AM
khart2000
Score: 100
Last Login: 5/24/2013
Status: offline
Thanks for the info. Do you have a pic. of the nose gear bay? Again great job, it has motivated me to get started!
Hide Signatures
(in reply to tomdensmore)
       Post #: 301
RE: Top-Flite T-34 - 10/18/2005 6:49 PM
tomdensmore
Score: 100
Last Login: 5/3/2008
Status: offline
I've attached a few pictures below, with the cowl removed to make it easier to see things. I molded the gear doors by laminating 1/64" ply on both sides of 1/16" balsa. If I was doing it again, I'd probably mold them out of fiberglass -- I didn't know how to do that at the time I made the doors. In either case, the key is to mold the doors over the cowl before you cut out the door openings.
One thing that made this harder is the fact that the gear is offset to one side. I know some people have taken out the offset. It's there on the real plane, but it doesn't seem to be as pronounced as in the model. You either have to make the gear doors larger to compensate, or offset the doors to one side -- I opted to make them larger.
One resource that I can highly recommend is a book called "Radio Control Airplane Finishing & Detailing: How to create an RC Masterpiece" by the publishers of Model Airplane News. I used that book extensively to learn techniques for creating panels, doors, and other details.
Good luck!
Tom
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to khart2000)
       Post #: 302
RE: Top-Flite T-34 - 10/19/2005 6:55 AM
khart2000
Score: 100
Status: offline
Tom,
Again great job. Thank you for the information and photos.
KHart
Hide Signatures
       Post #: 303
RE: Top-Flite T-34 - 10/25/2005 12:00 PM
raknin
Score: 100
Last Login: 1/23/2013
Status: offline
Aircoboy,
I saw your T-34, outstanding job in short time. Do you have any movie to demonstrate the T-34 in action (Fliyng).
It seems that the model can be finish in a month of evenings work, that is good. I will build mine with a fix landing gear
since the robart retract cost a lot, and it is overhead to the plane with adding point of failure. In addition are U using the flaps for
landing?
Hide Signatures
(in reply to aircowboy)
       Post #: 304
RE: Top-Flite T-34 - 11/27/2005 4:40 AM
SarDog
Score: 100
Last Login: 5/17/2013
Status: offline
Struck Gold again, I found a copy of my 1959 US Air Force T.O. 1T-34A-1 from when I flew the T-34A 20 years ago. Will have to see the legality of making copies of this Air Force T.O.
_____________________________
Life is NOT like a box of chocolates, it is more like a jar of jalapenos... What you do today, can burn your ass tomorrow.
Hide Signatures
       Post #: 305
RE: Top-Flite T-34 - 12/22/2005 12:33 AM
raknin
Score: 100
Status: offline
I am building right now the top-flite T-34. I start building the stab. I have question regarding the
instruction writtn on page 13 step 25. It is written in the manual to "cut 12 1-7/8" (47.6mm) long hinge blocks from the 1/4"*3/8"*36" (6.4*9.5*914mm) balsa stick". The actual space between the ribs is 5.2cm, but in the instruction is written to cut 47.6 mm hinge block. My question to you, If I cut 5.2 cm it can also server of reinforcment for the ribs, can anybody have any suggestion
Hide Signatures
(in reply to SarDog)
       Post #: 306
RE: Top-Flite T-34 - 12/22/2005 1:05 AM
HalH
Score: 100
Last Login: 3/6/2009
Status: offline
Just cut the pieces to fit between the ribs. My ribs are 2-1/16" apart.
Hide Signatures
(in reply to raknin)
       Post #: 307
RE: Top-Flite T-34 - 12/22/2005 1:21 AM
raknin
Score: 100
Status: offline
Hal,
Thanx this is what I was thinking. Just another question, does this balsa stick is used for something else. Because I am afraid that the rest of the stcik is using for something else. If I cut too much it can be missing somewhere else.
< Message edited by raknin -- 12/22/2005 1:22 AM >
Hide Signatures
(in reply to HalH)
       Post #: 308
RE: Top-Flite T-34 - 12/22/2005 1:35 AM
HalH
Score: 100
Status: offline
You will use the remainder in the same way on the fin and rudder.
Hide Signatures
       Post #: 309
RE: Top-Flite T-34 - 12/22/2005 2:00 PM
raknin
Score: 100
Status: offline
Hal,
I made some measurments and it seems that blasa stick supply will fit the rudder and the stab. The issue is that top flite manual has to be modified to the right size. Also according to the plans itself it measure 5.2 cm. I am going to report it to top-flite, so maybe the manual is needed to be modified. Thanx any way.
Hide Signatures
(in reply to HalH)
       Post #: 310
RE: Top-Flite T-34 - 1/17/2006 10:35 PM
aircowboy
Score: 100
Last Login: 1/24/2013
Status: offline
Pictures of my Evolution 100 install.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to PT21Flyer)
       Post #: 311
RE: Top-Flite T-34 - 1/22/2006 10:13 PM
Werner38
Score: 100
Last Login: 1/14/2010
Status: offline
Hi,
are the Robart-retracts made totally from alu or are there an plastic parts in it?
Do you think, the retracts can be used on gras?
Werner
Hide Signatures
       Post #: 312
RE: Top-Flite T-34 - 1/22/2006 11:02 PM
HalH
Score: 100
Status: offline
There are no plastic parts and yes they can be used in short grass.
Hide Signatures
(in reply to Werner38)
       Post #: 313
RE: Top-Flite T-34 - 1/23/2006 6:04 PM
Werner38
Score: 100
Status: offline
Hi,
today I have ordered the kit, the retracts will follow soon (thanks for the infos about them HalH). In the meantime I have to order an engine for the T-34B. One of the favourites is an Evolution 100 (thanks aircowboy). On the other hand I think a Saito 4 cycle would be also a good choice for it. But I really don't know which one should I choose. A few T-34B owners have told me not to use a Saito 100 because I it have to go from a gras runway. The next size is the new Saito 125a. Nearly as light as the 100 and, as far as I have heard, a lot of extra power. Or should I go with a Saito 150, one of the large Saito's. It is heavier then the 125, but a lot of scale models need the extra weight. What do you think about it?
Thanks Werner
Hide Signatures
(in reply to HalH)
       Post #: 314
RE: Top-Flite T-34 - 1/23/2006 6:23 PM
HalH
Score: 100
Status: offline
I believe the larger Saito 4 cycle engines will stick outside the cowl. I have not flown mine yet but I have a RCV 120 in mine. It will be able to turn a rather large prop so it will probably be more than enough power and it definitely fits inside the cowl.
Hide Signatures
       Post #: 315
RE: Top-Flite T-34 - 1/24/2006 9:00 AM
SarDog
Score: 100
Status: offline
HalH,
I am looking at that engine too. Do you have any pics on your engine mount for the RCV 120? Hope it works great for ya. Looks like the best fit for the power, without cutting into the cowling. Keep us in formed of the pros and cons of the RCV.
Hide Signatures
(in reply to HalH)
       Post #: 316
RE: Top-Flite T-34 - 1/27/2006 8:02 PM
GEARED
Score: 100
Last Login: 5/4/2013
Status: offline
Hi HalH,
I have also considered the 120 RCV for the TF T-34, but still have some doubts.
A RCV 120 engine requires a big prop ( 20" to 22" x 12 " ) to benefit from the torque delivered by the 1:2 reduction gears; to clear the nose wheel, however, the biggest prop you can use is 15" diam.
The Propeller Load Factor ( PLF = DxDxP ) of the 20" prop is: 20x20x12 = 4800
That PLF from a 15" diam prop would require a pitch of : 4800/15x15 = 21".
If you go with multi-bladed props:
A 15" diam. 3-blade prop corresponds to a 16" diam 2-blade prop, so the pitch for corresponding PLF should be 4800/16x16 = 18-3/4".
A 15" diam. 4-blade prop corresponds to a 17" diam 2-blade prop, so the pitch for corresponding PFL should be 4800/17x17 = 16-1/2".
So,what propeller are you going to use in your 1/5 scale Top Flite T-34 equipped with a 120RCV engine?
Regards,
Geared.
Hide Signatures
(in reply to HalH)
       Post #: 317
RE: Top-Flite T-34 - 1/27/2006 9:27 PM
HalH
Score: 100
Status: offline
I am using a 18" two blade for mine. ( 18X14 ) Zinger I am able to use a larger one because I lengthened the nose strut and mounted it lower than stock. I actually did this to make the model sit in a more scale nose high stance.
Hide Signatures
(in reply to GEARED)
       Post #: 318
RE: Top-Flite T-34 - 1/27/2006 11:54 PM
GEARED
Score: 100
Status: offline
It seems fine! How much does your plane weight? Have you got any pics?
Regards,
Geared
Hide Signatures
(in reply to HalH)
       Post #: 319
RE: Top-Flite T-34 - 2/1/2006 12:30 AM
greenboot
Score: 100
Last Login: 10/15/2012
Status: offline
I have mine ready to install an engine but I'm still wondering what to use. Does the RCV fit with a stock muffler? I have the Robarts installed so I need a muffler that around them. I like the YS 110. Does anyone know if it fits?
Tom
Hide Signatures
       Post #: 320
RE: Top-Flite T-34 - 2/1/2006 12:48 AM
HalH
Score: 100
Status: offline
Look at my post #246 for a picture with the RCV installed. There are some more pictures in this thread of my engine.
Hide Signatures
(in reply to greenboot)
       Post #: 321
RE: Top-Flite T-34 - 3/10/2006 4:03 AM
eagle1230
Score: 100
Last Login: 5/11/2013
Status: offline
Hello,
My name is Roland and I have been watching your progress on the T-34, very nice. I think you for some of the ideas on how to fix/do some of the process. My question is would please send me the demsions of the muffler you built. I am installing a OS91 Fx in my plane. I have been building my for over two years, I know that is long but I,m slow. Please send me the mesurment of the muffler with a dirgram.
My e-mail is mustang51@bellsouth.net Thank You. Roland
Hide Signatures
       Post #: 322
RE: Top-Flite T-34 - 3/13/2006 8:29 PM
fliir
Score: 100
Last Login: 5/23/2013
Status: offline
Eagle:
So you think two years is SLOW? Did you see the date on the first post in this thread (December 15, 2002)? I think you are in good company...
On the board: Torres 20% T-34C
Future: Navy N3N, Aeronca 402, Blohm&Voss BV-141, Heinkel HE111Z, Dornier 335
Hide Signatures
(in reply to eagle1230)
       Post #: 323
RE: Top-Flite T-34 - 3/13/2006 9:06 PM
PT21Flyer
Score: 100
Last Login: 5/10/2013
Status: offline
fliir,
Yep. It's been over three years in the making and still not finished. I'm applying aluminum to it and hope to fly it this summer. I need to git r done so I can build my Don Smith B-17.
Jerry
BIG really does Fly BETTER
Hide Signatures
(in reply to fliir)
       Post #: 324
RE: Top-Flite T-34 - 3/19/2006 7:39 AM
rkinman
Score: 100
Last Login: 5/5/2013
Status: offline
Jerry,
Keep up the good work. Your T-34 looks great. I was fortunate to make a quick hop to Breckenridge, Tx from Wichita Falls last Monday in a friend of mine's T-34. I've posted a couple of photos. The T-34 is a super nice airplane and I'm sure the model is just a great. I have one in the box I need to build myself. Thanks for letting everyone learn from your build.
Reese
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 325
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.406RCU1
