Way To Go!!!
Tower Hobbies
Logged in as Guest
  Printable Version
More Resources on the
T-34B Mentor - 61
  • See User Ratings
  • Suggest Compatible Equip.
  • Check for Retailers
  • Discussions on this Product
  • All Forums >> RC Airplanes >> RC Scale Aircraft >> Way To Go!!!
    Page: <<   < prev  2 3 [4] 5 6 7 8 9 10 11   next >   >>
    Login
    Way To Go!!! - 3/3/2003 8:27:58 AM
    PT21Flyer
    Status: online
    CNSASS,
    Congrats on your first flights. Really great looking plane. Sure hope mine turns out as good.
    Jerry
    _____________________________
    BIG really does Fly BETTER
    (in reply to PT21Flyer)
           Post #: 76
    Top-Flite T-34 - 3/8/2003 4:48:33 AM
    dany_maia
    Status: offline
    Hi.
    CNSASS do you think a Saito 91 would handle the plane? Can I build it with fixed landing gear and will it look as fine as yours?
    Thanks.
           Post #: 77
    Top-Flite T-34 - 3/8/2003 8:08:40 AM
    CNSASS
    Status: offline
    You sure can build it with fixed gear and just put the Robart scale struts on them to dress it up. I think you will be fine with the Saito 91 up front. It puts out a little less power then the YS 91. It really dosen't take much power to fly this thing. I was alittle worried about it at first but that all went away on the first flight.
           Post #: 78
    Top-Flite T-34 - 3/8/2003 4:31:39 PM
    dany_maia
    Status: offline
    Hi CNSASS.
    Thanks for your oppinon. Do you use the retracts and do you gave lights on it?
    Can you post some pics of your engine instalation please?
    Thanks.
           Post #: 79
    T-34C? - 3/24/2003 9:56:42 PM
    tenman
    Status: offline
    Does anyone have any info about making this kit into a T-34C? Also, any reason for the nose gear to be offset?
           Post #: 80
    Top-Flite T-34 - 3/24/2003 10:16:20 PM
    Chris300s
    Status: offline
    Bob Banka's documentation has everything you need for a T-34C. His three-view packet has notes on the C's and civilian modifications vs. stock.
    Chris
           Post #: 81
    TF T34 - 3/24/2003 11:11:33 PM
    HalH
    Status: offline
    The "C' would require a lot of re-engineering. The nose is much longer and skinnier.
    The nose gear is offset to the right approx. the width of the strut on the real airplane.
           Post #: 82
    Top-Flite T-34 - 3/26/2003 4:22:58 AM
    HalH
    Status: offline
    Here are some pictures that show the mods I have made to the TF T-34.
    Click to see fullsize image.
    Click for fullsize
           Post #: 83
    TF T-34 - 3/27/2003 3:50:06 AM
    HalH
    Status: offline
    The attached photo shows the mods I have made to include nose gear doors and exhaust (augmentor ) tubes. I also modified the cowl opening so that it is more scale.
    Click for fullsize
           Post #: 84
    Top-Flite T-34 - 4/1/2003 10:38:46 PM
    easyd
    Status: offline
    Halh,
    Good looking cowling, what size are the augmenter tubes. On the full size airplane these were like megaphones to provide a venturi effect to provide additional cooling air at high power. Can you give me more info on the gear doors. I.E. Hinges and actuators.
    Dave
           Post #: 85
    Top-Flite T-34 - 4/1/2003 10:53:13 PM
    HalH
    Status: offline
    First of all, one must modify the nose retract mounting so that the gear door opening provides a mounting surface for the hinges. I used some Sonictronics offset door hinges that have springs to force the doors to open. I then used rubber bands attached to the doors that catch the strut when the gear are retracted.
    The augmentor tubes are polished aluminum tubes - 1" diameter
           Post #: 86
    Top-Flite T-34 - 4/1/2003 11:08:22 PM
    easyd
    Status: offline
    Thanks for the info. I am just starting to build my T-34 so I have found this thread very helpful. What engine are you going to use. I am thinking of using the Saito FA-100.
           Post #: 87
    THREAD DONE? - 4/17/2003 11:49:31 PM
    NickC5FE
    Status: offline
    Hey there PT21, is this thread completed? Are you spending more tim flying this beaut than posting pix, i would be. I am about to start the kit in a month or so, and would love to see the finishing pics, and touches. Thanks in advance, nick
    < Message edited by pantherflyr -- Apr 18 2003 6:16AM >
           Post #: 88
    Not Much Progress - 4/18/2003 8:10:30 AM
    PT21Flyer
    Status: online
    Hey Everyone,
    Sorry I haven't posted in a long time. Haven't been able to work on my T-34 for the last 4 weeks or so. Hoping to get going again this weekend and will try to post some more progress pictures. My Flite-Metal is on order but haven't received it yet. Wil probably build a test panel to try it on so I can try rivet details and panel lines etc. before I put it on the actual plane.
    Jerry
           Post #: 89
    Top-Flite T-34 - 5/3/2003 1:30:23 AM
    teamscalepilot
    Status: offline
    Flew my TF T34 at top gun it was a hit...
           Post #: 90
