RE: Official Tamiya TT-01 Thread
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Electric On-Road vehicles, race cars and more >> RE: Official Tamiya TT-01 Thread
Page: <<   < prev  169 170 [171] 172 173 174 175 176 177 178   next >   >>
Login
RE: Official Tamiya TT-01 Thread - 6/18/2008 12:56:40 PM
SIRCC
Status: offline
If it oes'ny fall into to place its not the proper part.
(in reply to vaggy)
       Post #: 4251
RE: Official Tamiya TT-01 Thread - 6/18/2008 7:00:35 PM
pimpedarse
Status: offline
Just Yesterday I totally makeshifted a tt-01 rally... Instead of the normal positioning of the dampers, I drilled holes where the wishbone suspension arms get mounted to the body. So my damper got way smaller and doesn't work properly but I raised the ride height of my car almost a half inch!
I took it out to test it off-road and it's so tight! rallying is the best. I used to drift it all the time but now all I have to do to convert it to drifting again is reposition the dampers in the original locations, and change the tires.
A little warning though is that this makes your top wishbone in the front and the back a lot weaker. So hypothetically crashing can easily brake them... easier than before. So far it hasn't happend to me.
All that happend to me is that I launched it full speed down a trench about 15 feet far and 7 feet down... my rear diff box came undone for a second because of a missing screw and my dogbone fell out... besides that though it rallys perfectly
So if you want to make your TT-01 rally for practically no money, just do what i did.
Heres some pics of the setup... I'll upload action shots later.
^ see the dampers aren't in the normal mounting holes
(in reply to bIGmiK)
       Post #: 4252
RE: Official Tamiya TT-01 Thread - 6/19/2008 4:03:00 AM
DriftingDragon
Status: offline
any one able to control one with 2wd cause i need tips
_____________________________
| DF-03 | E-Firestorm | Desert Truck | TT01 RX7 | Tamiya highlift |
(in reply to pimpedarse)
       Post #: 4253
RE: Official Tamiya TT-01 Thread - 6/19/2008 12:31:48 PM
TIGER76
Status: offline
Interesting rally mod m8
Hope it holds together i can see that upright splitting tho with enough side force hitting the wheel I would grab a spare one now lol
If its spinning out too much lock the diff at the front
VXL pede/ 9.6v 4200 mAh & 8.4v mAh
TT-01r / Quake ESC / Trinity D6 9Turn / Orion Rocket Pack 4500 (X2)
(in reply to DriftingDragon)
       Post #: 4254
RE: Official Tamiya TT-01 Thread - 6/19/2008 1:52:54 PM
DriftingDragon
Status: offline
how can i lock the diff without buying the locked diff
(in reply to TIGER76)
       Post #: 4255
RE: Official Tamiya TT-01 Thread - 6/19/2008 2:04:15 PM
TIGER76
Status: offline
Just open the diff case up with small scewdriver and use something to block the metal cogs,dont glue it unless you want prem locked ive used balls of paper seems to work good.
Bluetac,nitro tubing works too.
To open your front diff,unscew the front bumper and undo the 2 screw on front case.
       Post #: 4256
RE: Official Tamiya TT-01 Thread - 6/19/2008 2:05:45 PM
DriftingDragon
Status: offline
ok thanks
       Post #: 4257
RE: Official Tamiya TT-01 Thread - 6/19/2008 6:55:39 PM
pimpedarse
Status: offline
yeah i used a bunch of tiny rubber bands to block them... it didnt lock them but it tightened them allot, practically locking them.
       Post #: 4258
RE: Official Tamiya TT-01 Thread - 6/19/2008 10:55:07 PM
DriftingDragon
Status: offline
i used a bit of a gum packet locked it good on an 1/8th give
       Post #: 4259
RE: Official Tamiya TT-01 Thread - 6/24/2008 6:59:35 AM
pimpedarse
Status: offline
Have my stock NSX cover on it for rallying
       Post #: 4260
RE: Official Tamiya TT-01 Thread - 6/24/2008 1:46:47 PM
disjaukifa
Status: offline
Got a question and figured this would be the perfect place to ask . . . I just recent recieved a TT-01 kit, new in box and built it and was running it yesterday and had a lot of fun with it, however I want to do some upgrades. Now of course I am going to be doing the following upgrades:
1. Ball Bearings
2. Aluminum Drive Shaft
3. Oil Filled Shocks
Now what I really want is more speed than what the stock Tamiya 540 can give. I can not afford a brushless motor/kit at this time so I want to stay with the standard motors. Now I know that the lower the turns a motor has, the higher the rpm the motor can produce, the faster the car will go. However I have no idea what pinion and spur gear combination I should get. Also I only have the stock ESC that came with the TT-01 from Tamiya, and I don't know what the limitation of that ESC is. I am hoping that someone has the answers to my question :-D!!!
Disjaukifa
       Post #: 4261
RE: Official Tamiya TT-01 Thread - 6/24/2008 1:55:43 PM
SIRCC
Status: offline
BUBLE GUM ALSO WORKS
       Post #: 4262
RE: Official Tamiya TT-01 Thread - 6/24/2008 1:59:57 PM
SIRCC
Status: offline
STO
