Neo02
Joined: 8/20/2003 From: Lugano, SWITZERLAND Status: offline
quote:
ORIGINAL: Magne No, not if you charge from the same source battery. The two chargers would just draw half the current each, with the same total current drain from the battery. My Orbit Microlader 6.3 gets very hot while charging a 10S pack, but barely warm when charging a 5S pack. So I thought that the lost energy in form of heat would be saved and better results achieved (i.e. less voltage drop at the source battery) when charging separately. Still a lot to learn in this world... :-D quote:
An other reason not to do this: The two chargers would not terminate the charge at exactly the same voltage. Even if they were identical chargers they will be differently calibrated. This will cause imbalance between the two packs when these are connected and discharged in series. If I charge the two packs as 5s, I always use the same charger (twice), and always let the charger complete the charge cycle. When I charge as 10s, I often terminate the charge cycle before it is finished. (90-95% fully charged after 1 hour.) Just my opinion. Thanks for the clarification. Do you think this will also be a problem when balancers are used? I plan (planned) on buying 2 separate chargers and charge my 10S packs as 2 times 5S packs, both hooked up to a Hyperion LBA6 5S balancers. This should ensure that both packs are at the same voltage when fully charged, or not? Regards, -Fabrizio
_____________________________
Fabrizio Albonico SUI 36291
