22e crash please help me
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> Walkera Helis - Dragonfly, etc.. >> 22e crash please help me Page: [1]
Login
22e crash please help me - 4/25/2006 10:09 PM
tweak54321
Score: 100
Last Login: 6/18/2006
Status: offline
Hello,
I just got my 22e and it crashed. I think the biggest problem i have is this one litttle peice has broken off that lets te blades move forward and backward.Also on my reciever th right stick locked into the far right possition. If any one can help me please do. Any thing would be helpfull. Here are some pics of the crash. If any one can help me please do.
thanx
Hide Signatures
       Post #: 1
RE: 22e crash please help me - 4/25/2006 11:18 PM
krisma
Score: 100
Last Login: 4/6/2009
Status: offline
hmmm... repost..... and again... can't see pics.
your receiver might have locked, but I suggest charging a batt, disconnect motors, and plug everything else in. run your servos through all motions and see if one of them is not responding, mainly the two back ones. Could be a soldered wire inside the servo has come undone, does it twitch if you wiggle the wires?
PS if you use the 'reply' option in a post (not the fast reply at the bottom of the page) it will give you the ability to upload and post pics. resize your pics to something like 600 x 480 (seperate application) which makes it a decent size for posting.
Hide Signatures
(in reply to tweak54321)
       Post #: 2
RE: 22e crash please help me - 4/25/2006 11:48 PM
krisma
Score: 100
Status: offline
tweak
just realized you were the one that ordered the camera package... hope it wasn't installed
Hide Signatures
(in reply to krisma)
       Post #: 3
RE: 22e crash please help me - 4/26/2006 2:13 AM
tweak54321
Score: 100
Status: offline
no it wasn't intalled, but it still sucks.Ummmm on the controller the right stick actually locked into the right possition and i cant push it back to the center, it litterly locked and cant move
Hide Signatures
       Post #: 4
RE: 22e crash please help me - 4/26/2006 3:00 AM
gordthebiker
Score: 100
Last Login: 8/7/2007
Status: offline
Open the radio up, it's probably an easy fix. As for uploading, I had an Ibook Macintosh before my lovely Toshiba and I couldn't upload pics either, are you using a Mac?
Hide Signatures
       Post #: 5
RE: 22e crash please help me - 4/26/2006 5:06 AM
krisma
Score: 100
Status: offline
try spraying some contact cleaner into the controller levers, but make ABSOLUTELY sure that it is 'plastic safe' contact cleaner as any other kind could damge plastic parts.
another option is to take some alcohol and swab down what you can with a q-tip
Hide Signatures
(in reply to gordthebiker)
       Post #: 6
RE: 22e crash please help me - 4/26/2006 5:38 AM
tweak54321
Score: 100
Status: offline
ya i am on a ibook g4, but if i could just get the pics on the enet any way then i could just copy and paste. Well Ive be in thinking if ways to fix the heli.The biggest problem is the part that lets the main rotors move forward and backward well one of them has broken off. I don't think i can pin point it with super glue, but i am thinking of just burning a tiny hole threw both sides of were it needs to be connected with a red hot needle then sticking a tiny wire thru it. This will probably be hard tho. Maybe i could just find a mechanic or look for the spare part.
Hide Signatures
       Post #: 7
RE: 22e crash please help me - 4/26/2006 7:39 AM
krisma
Score: 100
Status: offline
go to this site:
rcandme.com
find the 22e parts page and post a link to the part that is broken.
Hide Signatures
       Post #: 8
RE: 22e crash please help me - 4/28/2006 1:36 AM
tweak54321
Score: 100
Status: offline
ok i think that this is is the part. but is it easy to attach or if that doesnt work go here http://www.rcandme.com/servlet/the-273/HM-dsh-22E-dsh-Z-dsh-38/Detail
Hide Signatures
       Post #: 9
RE: 22e crash please help me - 4/28/2006 2:59 PM
krisma
Score: 100
Status: offline
check out my posts towards the top of this thread
http://www.rcuniverse.com/forum/m_4147942/tm.htm
where the screw located, is that where you broke it?
Hide Signatures
       Post #: 10
RE: 22e crash please help me - 4/28/2006 10:58 PM
tweak54321
Score: 100
Status: offline
i am pretty sure that the pic you had on is exactly what happend to me. Well the top of the peice that broke off needs to pivet so i cant glue or melt. When you put those screws in did you need a lot of equiptment to do it + could i do it being a biginer.exactly hoe did you fix it? Also the part that i posted is that the same one or the one that could fix my heli.was your pic of a 22e.did you need a electric drver to get it in.And lastly any tips for me when i do it.
thank you so much you have been very helpful
Hide Signatures
       Post #: 11
RE: 22e crash please help me - 4/28/2006 11:41 PM
krisma
Score: 100
Status: offline
you can completely do it as long as the only thing broken are the little posts on the flybar seesaw which is the third part from the left on the picture that you posted. If this is the case I wouldn't recommend buying a new part, but rather do the following for a much stronger attaching point.
You will need:
- #50 drill bit or equivalent
- machine screw/nuts to fit in #50 hole or equivalent
- #1 phillips head screwdriver
- adjustable wrench (small) or something to hold the nuts as you install the screw
- threadlock (optional if you use two nuts)
finish breaking off the little posts and file them flush. if the linkage is still good on one side I'd say break off the little melted cap that holds it in place and do the repair on both sides to keep balance in the head.
drill a #50 hole (or something equivalent) EXACTLY where the little posts use to be
reference the picture in the link I posted earlier and put a little machine screw through the linkage and through the new hole you just drilled. place a nut a on the back side but make sure you leave enough play for the linkage to swivel.
you can now put a second nut on top of the first to act as a lock (which is what I did and prefer) or put a couple of drops of threadlock on the screw/nut (you can buy this at an autoparts store). if you do the second make sure you inspect it often and see that the threadlock didn't break off and the nut hasn't backed off.
I have those little screws/nuts at home, but I assume a place like home depot/lowes would sell these.
GL and take your time.
Hide Signatures
       Post #: 12
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.828RCU1
