RE: Redcat vehicle repair/tune FAQ    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> Redcat Racing Support >> RE: Redcat vehicle repair/tune FAQ
Page: <<   < prev  41 42 43 44 45 46 47 48 [49] 50   next >   >>
Login
RE: Redcat vehicle repair/tune FAQ - 3/13/2009 9:24 PM
richardtf
Score: 100
Last Login: 9/23/2012
Status: offline
hi i have a volcano sv, iam replacing the clutch spring,what kind of brand will fit?
thanks.
Hide Signatures
(in reply to alowco)
       Post #: 1201
RE: Redcat vehicle repair/tune FAQ - 4/3/2009 9:07 AM
00Desmond
Score: 100
Last Login: 4/12/2009
Status: offline
Forgive me I didn't see the quote button at first.
TuffGuy31: My volcano seems to be stuck in neutral??? I start it and the engine just revs when I pull the trigger??? It revs but goes nowhere??? what could it be?????
I am having the same problem. Mine started right after I hit a little bump ... I did about a six inch jump and when I landed, I started having that problem. My spur gear is fine, so I opened up the tranny, everything looks fine in there, it's almost as if the bearings on my two drive gears are too loose (which I doubt very seriously is the problem, just trying to get the point across). They rotate just fine,but if there is any pressure on the drive shaft, it won't spin, the gears just rotate around it. I have been searching for hours for someone else with the same problem. I will definitely pass along a solution if I find one.
-Desmond
< Message edited by 00Desmond -- 4/3/2009 9:12 AM >
Hide Signatures
(in reply to tuffguy31)
       Post #: 1202
RE: Redcat vehicle repair/tune FAQ - 4/3/2009 10:08 AM
chevyderek72
Score: 100
Last Login: 11/8/2010
Status: offline
Richard- the traxxas high stall spring works great, it takes more rpms to launch, so you get a better take off. i think its part number 4146x
Desmond- Your slipper clutch might be loose. There should be 3 sets of gears on different shafts, the first one which had the spur and the other metal gear on it has a slipper clutch. If thats loose it will just spin, check that, thats what it sounds like.
_____________________________
Redcat Racing - Dunerunner, Hurricane XP, Aftershock 8e, Volcano, Volcano epx, Vortex epx, Tremor 18e pro
Its me ti**ta
Hide Signatures
(in reply to 00Desmond)
       Post #: 1203
RE: Redcat vehicle repair/tune FAQ - 4/3/2009 10:49 AM
00Desmond
Score: 100
Status: offline
Thanks Derek,
I am not entirely sure what you mean when you say slipper clutch.
I just watched a pretty helpful video on the two speed tranny that might have explained my problem. There is something called a one way bearing that according to Alishanmao could be the problem. Now I just have to figure out where to get one. I couldn't find parts for the T2 on Redcat's website.
Edit:
Nevermind, I think I found something that will work. They call it a 14mm Hex nut & one way bearing (part number 06067) I searched for the 47t spur gear that it sits in, and found that there is one for the Tornado and Tsunami models. Hopefully it is the same thing.
< Message edited by 00Desmond -- 4/3/2009 11:05 AM >
Hide Signatures
(in reply to chevyderek72)
       Post #: 1204
RE: Redcat vehicle repair/tune FAQ - 4/3/2009 11:01 AM
chevyderek72
Score: 100
Status: offline
Oh is it the 2 speed volcano?
Its me ti**ta
Hide Signatures
       Post #: 1205
RE: Redcat vehicle repair/tune FAQ - 4/3/2009 11:06 AM
00Desmond
Score: 100
Status: offline
Yes it is
Hide Signatures
       Post #: 1206
RE: Redcat vehicle repair/tune FAQ - 4/3/2009 11:13 PM
chevyderek72
Score: 100
Status: offline
Oh i thought it was the single speed. Uh make sure your slipper clutch is tight enough, its on the outside of the tranny housing. That may be it. If i had it with me i could find it, but im not too sure without having it.
Its me ti**ta
Hide Signatures
       Post #: 1207
RE: Redcat vehicle repair/tune FAQ - 4/6/2009 9:01 PM
ferguisa
Score: 100
Last Login: 1/6/2010
Status: offline
Hello, Can you help me with the low speed needle, please explain more detail,. I am from Mexico and I have problems with thew terms, What is flush with the end of the slide??????? How can put it as the factory set. I have the Monsoon and I have already brake it. But I move the low speed needle and will not start.
Fernando Guisa
fguisa@grupo-cpi.com.mx
Hide Signatures
(in reply to Popper252)
       Post #: 1208
RE: Redcat vehicle repair/tune FAQ - 4/7/2009 6:01 AM
chevyderek72
Score: 100
Status: offline
Turn your lsn out 3 turns, and lean from there. You want a crisp throttle response. I think mines at 2.5.
Its me ti**ta
Hide Signatures
(in reply to ferguisa)
       Post #: 1209
RE: Redcat vehicle repair/tune FAQ - 4/7/2009 6:39 AM
ferguisa
Score: 100
Status: offline
You mean close all the needle, then open 3 full turns??? that's what you said? Thanks...I am from Mexico and I am not familiar with the terms.
Hide Signatures
       Post #: 1210
RE: Redcat vehicle repair/tune FAQ - 4/7/2009 6:52 AM
chevyderek72
Score: 100
Status: offline
Ya, if its the sh28 your talking about, then ya, turn the needle all the way in, but dont turn hard, just turn till its snug. Then turn the needle out 3 turns.
Its me ti**ta
Hide Signatures
       Post #: 1211
RE: Redcat vehicle repair/tune FAQ - 4/7/2009 7:02 AM
richardtf
Score: 100
Status: offline
quote:
ORIGINAL: chevyderek72
thanks man... :-)
Hide Signatures
       Post #: 1212
RE: Redcat vehicle repair/tune FAQ - 4/10/2009 2:36 AM
00Desmond
Score: 100
Status: offline
So I got my one way bearing in today, put my car back together, put loctite on the little set screw that holds dog bone in place. Let the car sit for about an hour. Then ... yay ... I get to play with my baby again. Well two minutes into my first run, I lose my rear wheel drive. Surprise, the dogbone is gone. Now I would love to order a new one along with the piece that holds it to the transmission, but as anyone lucky enough to buy a T2 would probably know by now ... Redcat doesn't sell parts for that car. So if anyone knows where I can get parts for my car, I would love it if you could tell me where.
Hide Signatures
(in reply to richardtf)
       Post #: 1213
RE: Redcat vehicle repair/tune FAQ - 6/2/2009 7:52 PM
ghostfaceaz
Score: 100
Last Login: 12/18/2009
Status: offline
Does anyone have any steps, advice step-by-step guide, pics, vids as to how to get tot he transmission.
I am looking for help to replace one or both gears, or the whole transmission.....which seems to be out of stop at redcat.
Hide Signatures
(in reply to Team Knowitall)
       Post #: 1214
RE: Redcat vehicle repair/tune FAQ - 6/3/2009 11:32 PM
chevyderek72
Score: 100
Status: offline
I would but ive been busy lately. But its really easy, just look and it and see what screws you have to take off. What car is it on?
Its me ti**ta
Hide Signatures
(in reply to ghostfaceaz)
       Post #: 1215
RE: Redcat vehicle repair/tune FAQ - 10/8/2009 8:31 AM
Mickstix
Score: 105
Last Login: 11/6/2010
Status: offline
BUMP... This should be stickied at the top of the forum!! Lots of excellent info in this thread!! Mods, if ya see this, please sticky it!! thanks..
EDIT: Never mind.. I now see there's a link to it, up in the "'Redcat Product Support"' thread, that's stickied..
< Message edited by Mickstix -- 10/8/2009 10:51 AM >
Mick Nesevitch
Hide Signatures
       Post #: 1216
RE: Redcat vehicle repair/tune FAQ - 3/5/2010 4:08 AM
Wild Bill98
Score: 100
Last Login: 3/24/2010
Status: offline
I HAVE HIMOTO VIPER X2S  AND WHEN IT GETS WARMED UP IT LOOSES COMPRESON . DOES THIS MEAN THE ENGINE IS NO GOOD?
Hide Signatures
(in reply to ehroof)
       Post #: 1217
RE: Redcat vehicle repair/tune FAQ - 3/5/2010 7:44 AM
Mickstix
Score: 105
Status: offline
How do ya know it looses compression? Does it shut off? They loosen up quite a bit when there warm, but a sure sign of a engine that's toast, is it'll run fine until it gets warm, then die..  Then it's very hard to restart, or wont start at all, until ya let it cool down..
Mick Nesevitch
Hide Signatures
(in reply to Wild Bill98)
       Post #: 1218
RE: Redcat vehicle repair/tune FAQ - 3/12/2010 5:46 AM
fwarrior2010
Score: 100
Last Login: 3/14/2010
Status: offline
my Redcat Lightening VX runs fast and perfect in first gear then tries to shift into second and stalls out. if I let go of the gas fast enough the engine can sometimes catch itself and keep it running. I can't keep it running and in second gear. it pisses me off and I was hoping someone could explain to me what is going on and how to fix it. I am an R/C NOOB so you have to be very specific and go into detail for me. thanks.
Hide Signatures
(in reply to Mickstix)
       Post #: 1219
RE: Redcat vehicle repair/tune FAQ - 3/12/2010 6:22 AM
Mickstix
Score: 105
Status: offline
What do you mean by "if I let go of the gas the engine can catch itself"?? What happens if you just leave the throttle at full, does the engine start missing and then die shut off completely, or does it just start bogging but keeps running? If it dies, (whats called a "flame out").. Your probably running it out of fuel and your High Speed Needle (HSN) is too lean..  Now, if it just starts bogging down, you could have the HSN too rich, and it's overwhelming the engine with fuel (or trying to flood it).. And for my third guess You could just have the transmission set to go into 2nd too late, but it sounds like the engine isnt tuned for full performance.. Remember, if ya need to richen the HSN, turn the screw counter clockwise.. If you need to lean it out, turn it clockwise.. Only adjust in 1/12 increments.. Think of the needle housing as a clock, and just adjust the screw an hour at a time in the direction ya need, then run the vehicle for a minute or two so the change can take effect, then make another adjustment, etc.. It sounds pretty close, so it may only need a small tweak to dial it in! Also, be careful not to run it too lean, cause it'll get hot and could damage the engine.. Either use a heat temp gun, or some spit or water and put a few drops on the top of the engine cooling "head".. If it sizzles, the engine is too hot.. It should evaporate in about 5-7 seconds.. If it takes longer than that, to evaporate, the engine probably isnt running at top performance. Good luck and let us know how it does!!
Mick Nesevitch
Hide Signatures
(in reply to fwarrior2010)
       Post #: 1220
RE: Redcat vehicle repair/tune FAQ - 6/7/2011 5:37 AM
blusls
Score: 100
Last Login: 7/6/2012
Status: offline
Hi All, I just got my first Volcano S30 and seemed to have gotten so frustrated with getting the engine to idle right that i have ended up adjusting the idle to the point where  I don't know where the sweet spot is any more. If I was to turn the screw in clockwise all the way until it stopped, How many turns would I need to make to get it back to the factory setting? TIA!
Hide Signatures
       Post #: 1221
RE: Redcat vehicle repair/tune FAQ - 6/9/2011 2:06 AM
ehroof
Score: 105
Last Login: 5/16/2013
Status: offline
There is really no set turns for idle. you just turn until the carb opening has a 1mm gap. The low and high needles are usually 2 1/3 to 3 turns.
125 characters and 2 lines is not enough to list my RC obsession!!!
Hide Signatures
(in reply to blusls)
       Post #: 1222
RE: Redcat vehicle repair/tune FAQ - 5/25/2012 1:09 AM
juna1103
Score: 100
Last Login: 2/2/2013
Status: offline
Does anyone here know how to take the flywheel on this engine??
Hide Signatures
(in reply to nitrosteve22)
       Post #: 1223
RE: Redcat vehicle repair/tune FAQ - 6/23/2012 2:16 PM
juna1103
Score: 100
Status: offline
Has  anybody ever install these on a Tornado S30 or a similar Rc car?  The shock ball mounts are to big to pop them on, or do you screw them on??
Any help please..
Hide Signatures
       Post #: 1224
RE: Redcat vehicle repair/tune FAQ - 6/23/2012 2:34 PM
blusls
Score: 100
Status: offline
I have not used those exact ones. But they look like they are screw on.
Hide Signatures
(in reply to juna1103)
       Post #: 1225
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.297RCU1
