RE: Redcat vehicle repair/tune FAQ
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> Redcat Racing Support >> RE: Redcat vehicle repair/tune FAQ
Page: <<   < prev  39 40 41 [42] 43 44 45 46 47 48   next >   >>
Login
RE: Redcat vehicle repair/tune FAQ - 1/20/2008 4:06:28 PM
S.R.G.
Status: offline
It is centered on the controller which means nothing most of the time. I am looking at the servo arm - should it be
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to HimotoRacingUSA)
       Post #: 1026
RE: Redcat vehicle repair/tune FAQ - 1/20/2008 4:22:19 PM
S.R.G.
Status: offline
One more thing though - I just noticed that with the throttle trim at zero, and my carb settings, when I applied the break the carb would completely close.
Now I have screwed in the idle about half of the ay to expose about a 1 mm opening (pen head and a little bit more). Now when I have the throttle set to zero, and apply the break, it does not close the throttle. I have taken pictures of my idle setting. Maybe someone can tell me if it looks about right. It is exactly the width of a compressed air straw - sorry for the redneck measurements, but no ruler around here or a measuring tape - and just about everyone can relate to the diameter of a compressed air straw.
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 1027
RE: Redcat vehicle repair/tune FAQ - 1/20/2008 6:37:39 PM
HimotoRacingUSA
Status: offline
by 1mm, i mean inside of the carb, inside the neck. i cant tell by those pictures.
_____________________________
OFFICIAL SUPPORT HIMOTORACING.COM / OWNER HIMOTORACINGUSA.COM
***Its me EHROOF!!!!*** THE REVOLUTION HAS BEGUN
(in reply to S.R.G.)
       Post #: 1028
RE: Redcat vehicle repair/tune FAQ - 1/20/2008 7:42:16 PM
bigredtitan
Status: offline
how far should the carb screw be out? my volcano idles almost wide open and spit out a little fuel. sorry i am new to this. any help appreciated
(in reply to nitrosteve22)
       Post #: 1029
RE: Redcat vehicle repair/tune FAQ - 1/20/2008 7:45:22 PM
Macanan
Status: offline
here you go
Click for fullsize
Click for fullsize
Click for fullsize
OFFICIAL HIMOTO RACING SUPPORT - THE REVOLUTION HAS BEGUN
http://himotoracing.com :: http://himotoracingusa.com
(in reply to bigredtitan)
       Post #: 1030
RE: Redcat vehicle repair/tune FAQ - 1/20/2008 8:07:29 PM
S.R.G.
Status: offline
Yea, I know the 1 mm inside the carb - I was just hoping that the idle screws position is possibly how it should be - as in if all the engines are the same, and the throttle is zero'ed, then the idle screw's position should be the same. I cannot get a good picture if the carb, sorry, but it looks to be 1 mm. Another thing, when the break is applied, the carb should not move, but only the breaks be applied, correct? I am asking because with this new setting which I have not tested, the 1 mm opening stays the same when brakes are applied - but with previous settings, the carb was closed and the breaks were applied.
Thanks for your help.
quote:
ORIGINAL: ehroof
       Post #: 1031
RE: Redcat vehicle repair/tune FAQ - 1/20/2008 8:13:16 PM
HimotoRacingUSA
Status: offline
the carb should NOT move when hitting the brake, sounds like you have it right now.
       Post #: 1032
RE: Redcat vehicle repair/tune FAQ - 1/20/2008 8:18:31 PM
S.R.G.
Status: offline
Yea, I hope so. Before when hitting the break the carb would close and the car would die - so yea, had it all jacked up. The motor has not moved since factory default, so I have not checked the mesh. The gears look just as they did when I got it, so if the mesh was wrong, they should be worn on nicked, correct? I tried doing the mesh slightly - well getting a piece of paper in - with the muffler off, but stopped before I got something jacked up . I may go out today and run it around, but still worried about the rear shaft housing being slivered off, but it was around the outside off the metal, so should not affect the car. Now all I have to wait for is the temperature to go to at least 45, the I will be set.
< Message edited by S.R.G. -- 1/20/2008 8:27:32 PM >
       Post #: 1033
RE: Redcat vehicle repair/tune FAQ - 1/20/2008 9:08:18 PM
bigredtitan
Status: offline
thanks i will try that
(in reply to Macanan)
       Post #: 1034
RE: Redcat vehicle repair/tune FAQ - 1/30/2008 2:21:45 AM
haz
Status: offline
Yes i upgraded the manifold.
(in reply to dominicevans)
       Post #: 1035
RE: Redcat vehicle repair/tune FAQ - 2/3/2008 3:53:04 AM
Redharris
Status: offline
Hi folks. Question for everyone. I have a Volcano SV
I took apart My Rear Lower Arm and Axle Holder. I found Brass axle BUSHINGS instead of ball bearings. Below are some pictures. From the left; the entire assembly, the axle holder, and the brass bushings/bearings.
Does someone Make BALL BEARINGS to replace these brass bushings?
If so, can someone post a p/n or a link?
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to haz)
       Post #: 1036
RE: Redcat vehicle repair/tune FAQ - 2/3/2008 6:49:30 AM
HimotoRacingUSA
Status: offline
get boca bearings bro: http://www.clermontmotorsports.com/servlet/the-Boca-Bearings/Categories
(in reply to Redharris)
       Post #: 1037
RE: Redcat vehicle repair/tune FAQ - 2/3/2008 7:49:49 AM
Redharris
Status: offline
Are these the ones that match?
I measure 10mm x 5mm x 4mm
And 15mm x 10mm x 4mm
The number system on the Bocas are reversed, but I think these are correct.
http://www.clermontmotorsports.com/servlet/the-574/B-5x10x4/Detail
http://www.clermontmotorsports.com/servlet/the-584/B-10x15x4/Detail
