RE: Redcat vehicle repair/tune FAQ    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> Redcat Racing Support >> RE: Redcat vehicle repair/tune FAQ
Page: <<   < prev  41 42 43 [44] 45 46 47 48 49 50   next >   >>
Login
RE: Redcat vehicle repair/tune FAQ - 2/9/2008 7:36 AM
TNIGS
Score: 100
Last Login: 4/14/2008
Status: offline
im havin trouble tuning my forza. it has a vx.18 in it. the low speed needle is working fine but the high speed dosent seem to be doing anything. what shows when your runing to rich. i just keep on turning the needle out but the engine is still stalling when i hit the gas at high speed.
_____________________________
parts by Rob (westcoasthobbies@shaw.ca)
B.C. redcat dealer
Hide Signatures
(in reply to kuppler)
       Post #: 1076
RE: Redcat vehicle repair/tune FAQ - 2/9/2008 7:53 AM
firebird78
Score: 105
Last Login: 12/8/2011
Status: offline
flooding it?...have u checked your o-ring?
keep the shiney side up, the hammer down and the marshalls bored.....himoto rxb-1...himotoracingusa
Hide Signatures
(in reply to TNIGS)
       Post #: 1077
RE: Redcat vehicle repair/tune FAQ - 2/9/2008 7:55 AM
TNIGS
Score: 100
Status: offline
oh. i thought the stalling ussaly ment it was to lean. can you make it stall from to rich????
B.C. redcat dealer
Hide Signatures
(in reply to firebird78)
       Post #: 1078
RE: Redcat vehicle repair/tune FAQ - 2/9/2008 7:56 AM
firebird78
Score: 105
Status: offline
yeah its just a lil engine...just like anything else if u give it more fuel then it can handle it will spit and sputter
Hide Signatures
(in reply to TNIGS)
       Post #: 1079
RE: Redcat vehicle repair/tune FAQ - 2/9/2008 7:58 AM
firebird78
Score: 105
Status: offline
try turning it back in..count your turns...dont have any vx's but give the experts an idea what was up
Hide Signatures
       Post #: 1080
RE: Redcat vehicle repair/tune FAQ - 2/9/2008 7:59 AM
TNIGS
Score: 100
Status: offline
i know since its could here my tornado engine like to run at three turns out on th high speed. but my foza is stalling out at 3. i have gone al the way to 4.5 turns out and still no difference. maybe ill try turning the need more slowly. 1/8 turn at ia time ill try.
B.C. redcat dealer
Hide Signatures
       Post #: 1081
RE: Redcat vehicle repair/tune FAQ - 2/9/2008 8:05 AM
firebird78
Score: 105
Status: offline
plus if your turning the adj and theres no difference you might want to check the o-ring..is it easy to turn or has it got some resistance? any fuel leaking? I think the o=ring has 2 jobs...helps seal plus adds resistance so the adj stays were u set it..
Hide Signatures
(in reply to TNIGS)
       Post #: 1082
RE: Redcat vehicle repair/tune FAQ - 2/9/2008 8:48 AM
Redharris
Score: 105
Last Login: 12/9/2012
Status: offline
I have a Volcano SV truck. I seem to remember that there is a 10 tooth Clutch bell for the Volcano. Am I correct? I would like to buy one. Can anyone Post a p/n or a link.
OFFICIAL HIMOTO RACING SUPPORT - THE REVOLUTION HAS BEGUN
http://himotoracing.com :: http://himotoracingusa.com
Hide Signatures
       Post #: 1083
RE: Redcat vehicle repair/tune FAQ - 2/9/2008 7:54 PM
ehroof
Score: 105
Last Login: 5/16/2013
Status: offline
its 16 or 17 tooth,
http://www.clermontmotorsports.com/servlet/the-221/Hardened-single-speed-clutch/Detail
125 characters and 2 lines is not enough to list my RC obsession!!!
Hide Signatures
(in reply to Redharris)
       Post #: 1084
RE: Redcat vehicle repair/tune FAQ - 2/9/2008 7:57 PM
ehroof
Score: 105
Status: offline
quote:
ORIGINAL: TNIGS
put the hight needle to 2 1/2 out from closed and the low needle flush with the metal collar around it or a little in and lean from there but these are base settings, sounds like your way out of tune
Click to see fullsize image.
Click for fullsize
Hide Signatures
(in reply to TNIGS)
       Post #: 1085
RE: Redcat vehicle repair/tune FAQ - 2/9/2008 10:50 PM
brettjriddle
Score: 100
Last Login: 3/4/2008
Status: offline
Okay so I have a volcano sv pro. It had an os max cv-r .18 in it when I got it but the thing just would'nt start so I pulled it and put the Team Infinity motor back in it. It fired right up and I was able to drive. Does anyone have issues with there volvano not wanting to turn really well to the left but at high speed you can turn to the right and fishtail it? I have also heard you should get about 15 minutes of run time on a tank of nitro but I might get 5 minutes, any clues? What is the preferred glow plug in this engine? It now has an HPI r3 but I might swap it for an os a8 but was wondering if that would help the immediate response to the throttle. It just doesnt have that balls to wall throttle I was hoping for. Any comments would be great especially helpful ones. Thanks from a newbie.
Hide Signatures
(in reply to Team Knowitall)
       Post #: 1086
RE: Redcat vehicle repair/tune FAQ - 2/9/2008 11:02 PM
brettjriddle
Score: 100
Status: offline
oh yeah and the engine dies when I try to put it in reverse or when I go to fast and end up in the shrubbery....my wife is gonna kill me! When I give it full throttle from a stand still it stalls out sometimes. thanks again
Hide Signatures
(in reply to brettjriddle)
       Post #: 1087
RE: Redcat vehicle repair/tune FAQ - 2/9/2008 11:13 PM
ehroof
Score: 105
Status: offline
you need to raise the idle screw a little so it doesnt stall when you hit the brake(reverse)
there is no reverse in the volcano, just brake
os a3 is a great plug
your probably running to rich, you need to lean it up a little to get better power and longer run times, be sure not to lean it too much or you can ruin the engine.
Hide Signatures
       Post #: 1088
RE: Redcat vehicle repair/tune FAQ - 2/10/2008 1:40 AM
TNIGS
Score: 100
Status: offline
would it be fine to run a os #8 in my vx 18. its all the hobby shop carries and i need another one. will it work fine??
B.C. redcat dealer
Hide Signatures
(in reply to ehroof)
       Post #: 1089
RE: Redcat vehicle repair/tune FAQ - 2/10/2008 1:53 AM
ehroof
Score: 105
Status: offline
it will work but you may need to run it a little lean to keep the temps up, give it a try.
Hide Signatures
(in reply to TNIGS)
       Post #: 1090
RE: Redcat vehicle repair/tune FAQ - 2/10/2008 6:48 AM
pocketryder
Score: 100
Last Login: 11/15/2009
Status: offline
hay ed i still cant get my engine to run. i need to call you or something
Hide Signatures
       Post #: 1091
RE: Redcat vehicle repair/tune FAQ - 2/10/2008 6:50 AM
ehroof
Score: 105
Status: offline
pm me tomorrow, i will give you a call or you can call me, i go to church at 8am will be home by like 9:15 or so, i am sure we can figure it out.
Hide Signatures
(in reply to pocketryder)
       Post #: 1092
RE: Redcat vehicle repair/tune FAQ - 2/10/2008 6:58 AM
pocketryder
Score: 100
Status: offline
thanks man
Hide Signatures
       Post #: 1093
RE: Redcat vehicle repair/tune FAQ - 2/10/2008 6:59 AM
ehroof
Score: 105
Status: offline
i would say call me now but i am going to bed in a few
Hide Signatures
       Post #: 1094
RE: Redcat vehicle repair/tune FAQ - 2/10/2008 9:12 AM
TNIGS
Score: 100
Status: offline
quote:
ORIGINAL: ehroof
how do you tell how hot the tower hobbie plugs are. he also had a bunch of those but i didint see and markings on them????
B.C. redcat dealer
Hide Signatures
       Post #: 1095
RE: Redcat vehicle repair/tune FAQ - 2/10/2008 6:47 PM
ehroof
Score: 105
Status: offline
its a medium plug, they only make one plug
Hide Signatures
(in reply to TNIGS)
       Post #: 1096
RE: Redcat vehicle repair/tune FAQ - 2/10/2008 7:46 PM
ranger4x4
Score: 103
Last Login: 9/17/2010
Status: offline
anyone have any ideas on how to change the air filter setup to keep snow from clogging up the filter? i was thinking of trying to make a snorkel type and try to get it up behind the windshield to help keep it from icing up. anyone got any ideas for what might help me in this situation?
mxt 2-s mega e mt10 viper
Hide Signatures
       Post #: 1097
RE: Redcat vehicle repair/tune FAQ - 2/10/2008 8:49 PM
TNIGS
Score: 100
Status: offline
quote:
ORIGINAL: ehroof
maybe ill try that one. i thik i need a hot lplug but i bcant get one. maybe ill jus order one online
B.C. redcat dealer
Hide Signatures
       Post #: 1098
RE: Redcat vehicle repair/tune FAQ - 2/11/2008 3:36 AM
webbl19
Score: 100
Last Login: 9/4/2009
Status: offline
quote:
ORIGINAL: Macanan
Because my single speed is with only one gear. hence single speed.
Will this fit on the volcano? If so where can i get one? I just stripped some gears in mine and dont want to mess with all those gears anymore.
Exceed Razor, RedCat Tsumani and wanna be Volcano
Hide Signatures
(in reply to Macanan)
       Post #: 1099
RE: Redcat vehicle repair/tune FAQ - 2/11/2008 5:32 AM
webbl19
Score: 100
Status: offline
This one here is the one i am talking about. Its listed under the 1/10th buggy parts so thats why im asking....Anyone?
http://www.clermontmotorsports.com/servlet/the-132/Single-speed-gear-set/Detail
Hide Signatures
(in reply to webbl19)
       Post #: 1100
Jump to:
Google
SITE MAP!   : :   FORUM RULES
6.234RCU1
