RE: Redcat vehicle repair/tune FAQ
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> Redcat Racing Support >> RE: Redcat vehicle repair/tune FAQ
Page: <<   < prev  39 40 41 42 43 44 [45] 46 47 48   next >   >>
Login
RE: Redcat vehicle repair/tune FAQ - 2/11/2008 3:10:42 AM
FourMoCajuns
Status: offline
I got a tsunami ultrawide for Christmas and during break-in the brake was set way to high and we burned up the clutch bell, what do we have to replace. The car won't go very fast and the acceleration is decreased. The clutch bell is a blue color.
(in reply to webbl19)
       Post #: 1101
RE: Redcat vehicle repair/tune FAQ - 2/11/2008 3:14:56 AM
Chubbysdad
Status: offline
clutchbell, bearings, shoes, and spring.
_____________________________
Cen truggy, Bigfoot 1/5th, Cen buggy, Mg16
(in reply to FourMoCajuns)
       Post #: 1102
RE: Redcat vehicle repair/tune FAQ - 2/11/2008 3:22:19 AM
firebird78
Status: offline
quote:
ORIGINAL: Clermont Hobby
and he just happens to be the man to get them parts from...lightning fast shippin..good prices
HIMOTORACINGUSA, bodies by blue, allaboutfunhobbies
RXB-1, MTR-3, torpeda, torpeda pro, rapida
(in reply to Chubbysdad)
       Post #: 1103
RE: Redcat vehicle repair/tune FAQ - 2/13/2008 1:28:43 AM
brettjriddle
Status: offline
I had an os .18 cv-rx in my volcano sv pro but neither I or the LHS could get it to run so Ill have to send it back for warranty repair. I installed the team infinty .18 after a good cleaning with some carb and choke cleaner and it fired right up and runs awesome. How can I adjust the throttle arm to not totally kill the engine when I put it in reverse/brakes? Also sometimes after running for a few minutes the throttle dies to to about 15% and after I pick it up and juice the throttle a couple of times it picks back up like normal until I run it out of fuel. This seems to happen whenever I am down to about an 1/8 of a tank. I have venom temp gauge/fail safe and the temp reads about 250 to 280 but after I stop the engine the temp drops 20 - 30 degrees in about 20 seconds. What is an acceptable temp range to run it in. It still has a fair amount of smoke when running it hard so I think I can still lean it up a smidgen more. Thanks for any helpful tips.
(in reply to firebird78)
       Post #: 1104
RE: Redcat vehicle repair/tune FAQ - 2/13/2008 1:38:44 AM
brettjriddle
Status: offline
I just answered my own question about the throttle cut back because of the failsafe, duh...should have looked it up before I asked. But what about the reverse/brake thing?
(in reply to brettjriddle)
       Post #: 1105
RE: Redcat vehicle repair/tune FAQ - 2/13/2008 1:39:34 AM
HimotoRacingUSA
Status: offline
you need to turn the idle screw clockwise to keep the carb open when you hit the brake, 250 is a good running temp when you running it pretty hard, no more than 280.
OFFICIAL SUPPORT HIMOTORACING.COM / OWNER HIMOTORACINGUSA.COM
***Its me EHROOF!!!!*** THE REVOLUTION HAS BEGUN
       Post #: 1106
RE: Redcat vehicle repair/tune FAQ - 2/13/2008 1:45:42 AM
volcanoman
Status: offline
the chrome wheel number is 08008 and the tire is 08043 the combo number is 08071
i need to know what bearing goes in ther steering hub cant get grub screws out so i have to rebuild or does the aluminum one not need bearings
(in reply to NightHawk18)
       Post #: 1107
RE: Redcat vehicle repair/tune FAQ - 2/13/2008 1:48:59 AM
volcanoman
Status: offline
the wheels are 08008 the tire 08043 and the combo is 08071
       Post #: 1108
RE: Redcat vehicle repair/tune FAQ - 2/13/2008 1:59:13 AM
volcanoman
Status: offline
for the dog bone depends for the drive axle dog bone its 08059 for the drive shaft its 08060
       Post #: 1109
RE: Redcat vehicle repair/tune FAQ - 2/14/2008 11:29:47 PM
brettjriddle
Status: offline
I replaced my front left dogbone because it disapearred and since that happend it seems that when I juice it sometimes the front wheels take off like a bat out of hell but the rears don't have near as much power. Is there anything I can do to limit the temp to 270, maybe make it more rich at the sacrifice of power. It gets frustrating having the fail safe cut it back all the time.
(in reply to volcanoman)
       Post #: 1110
RE: Redcat vehicle repair/tune FAQ - 2/18/2008 2:39:57 AM
tihstae
Status: online
ok so hopefully im going to pick my spur gears up from redcat tomorrow and i need help on meshing them. i know how to do it any everything, i did that last time and i still stripped it. i put notebook paper in and pushed it up against it, when i ran it it kinda almost binded, so is that too tight. Should i be pushing it together or just letting it be snug or what? how hard should i push it together? any other advice on meshing would be greatly appreciated.
       Post #: 1111
RE: Redcat vehicle repair/tune FAQ - 2/18/2008 7:58:39 PM
tihstae
Status: online
ok so hopefully im going to pick my spur gears up from redcat tomorrow and i need help on meshing them. i know how to do it any everything, i did that last time and i still stripped it. i put notebook paper in and pushed it up against it, when i ran it it kinda almost was binding, like it would catch it seemed like every turn, so is that too tight. Should i be pushing it together or just letting it be snug or what? how hard should i push it together? any other advice on meshing would be greatly appreciated.
< Message edited by tihstae -- 2/18/2008 8:01:56 PM >
(in reply to tihstae)
       Post #: 1112
RE: Redcat vehicle repair/tune FAQ - 2/18/2008 8:55:18 PM
HimotoRacingUSA
Status: offline
there should be a little play between the clutch bell and the spur gears, just a bit of play. you sould be able to roll the car without any binding.
       Post #: 1113
RE: Redcat vehicle repair/tune FAQ - 2/18/2008 8:58:13 PM
tihstae
Status: online
alright ill try that, just wanted to make sure so i dont keep strippin gears, it pisses me off lol. i havent drove it for real in a while
(in reply to HimotoRacingUSA)
       Post #: 1114
RE: Redcat vehicle repair/tune FAQ - 2/21/2008 6:27:43 AM
