DonnyNitro
ON, CANADA Status: offline
quote:
ORIGINAL: Redharris Ya'all ever had your Throttle Linkage Fall off? Ever had to do the PERP Walk through a Field lookin for you Linkage? Well ....heres a fix so screw holding Linkage to the Servo horn will never fall out Again! It also Tightens Tolerances (less slop) and cures Binding problems(if ya have them),,,,, Heres the picture.... P.S. Thats a 3x15mm hex screw, 2ea 3mm washers, and 2ea 3mm nuts. the nut on top is Loctited ant holds the other in place without having to over tighten(and cause Binding in the linkage). Paint it (or any other parts that may "fall" off.lol) bright yellow or orange. easy to find whey you are doing the "PERP walk:
_____________________________
Traxxas Slash & Traxxas Blast
