RE: Redcat vehicle repair/tune FAQ
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> Redcat Racing Support >> RE: Redcat vehicle repair/tune FAQ
Page: <<   < prev  39 40 41 42 43 44 45 46 [47] 48   next >   >>
Login
RE: Redcat vehicle repair/tune FAQ - 5/5/2008 2:47:00 AM
tihstae
Status: offline
ok so i got a problem, i bust my car out today and at first it was runnin fine, but my tuning is starting to get messed up. i would put it at say 2 1/2 turn out and run down the street, then when i would come back it would bog for a few seconds and then run fine at higher speeds, i would stop and it would do it again, bog out for a couple seconds. but i would bring it back to me and i would lean the hsn a little bit and it would do the same thing, be good on the first run, but on the way back and after that it would bog until i brought it back to me. i thought maybe it was the lsn but i would turn that both ways and it didnt help. does anybody know what it might be. also i know the lsn is flush with the collar, after that do you just lean it out or what, i never got that i just always left it flush.
(in reply to impune)
       Post #: 1151
RE: Redcat vehicle repair/tune FAQ - 5/5/2008 5:07:02 AM
impune
Status: offline
is it hot or cold there. at night its chilly right and during the day hit as anything. like florida but with out the humidity.... so change youhave to do a little depending night or day runs.
but the lsn is for the punch, the begining past when you gas it. the hsn is for the top speed part. so it punches and then bogs its the hsn... it slow starts and bogs then speeds up its the lsn.
yes start flush and turn slight turns clockwise i believe, like not more than a qaurter turn at a time and may take few start and stops...
what engine? this .28 has been tricky for me. i used to run only the .15 pro and the .18 engines, so this is more effort to adjust. but once there all other adjustments are minor they say.
hope this helps. any correct me if i am wrong.
if it's the sh .28 check the ling for more info. http://www.happysale.dk/images/SH28.pdf
_____________________________
just taking another day. these r/c''''s are to destress me...
(in reply to tihstae)
       Post #: 1152
RE: Redcat vehicle repair/tune FAQ - 5/5/2008 5:10:46 AM
impune
Status: offline
sorry for the typo's, i forgot to reread and i've been working waaaay tooo much lately. tired plus adult beverages equals poor grammar.... but i hope you can decipher what i was saying.
if it's the sh.28 link is http://www.happysale.dk/images/SH28.pdf
       Post #: 1153
RE: Redcat vehicle repair/tune FAQ - 5/5/2008 5:25:34 AM
tihstae
Status: offline
its the vx 18 and i was runnin it when i was warm, around 90-95 degrees. like when i floor (pull) it, it boggs from pull to like 10mph or something, for a couple seconds it just boggs, and in the grass it doesnt stop bogging.
       Post #: 1154
RE: Redcat vehicle repair/tune FAQ - 5/5/2008 2:31:51 PM
impune
Status: offline
sounds like the lsn. boggs from the start, it's the lsn. bogg after the start its the hsn.
remember, when you put it wide open you should see smoke, if not, it's too lean and you'll burn the engine up. smoke is good.
       Post #: 1155
RE: Redcat vehicle repair/tune FAQ - 5/5/2008 11:51:40 PM
decompetencia
Status: offline
Hello I have problems with my himoto Syclone pro, i can not find the needle for low speed where is it?, i have the needle for hight speed but the another i dont know, thanks
(in reply to Team Knowitall)
       Post #: 1156
RE: Redcat vehicle repair/tune FAQ - 5/6/2008 2:21:27 AM
impune
Status: offline
what size engine is the syclone? if its larger it will be the screw at the end of the slide carb?
otherwise... some else needs to answer.
(in reply to decompetencia)
       Post #: 1157
RE: Redcat vehicle repair/tune FAQ - 5/6/2008 2:43:57 AM
tihstae
Status: offline
when i stomp it there is tons of smoke, so it would be the lsn, then, lean that out?? and keep leaning it out till it gets better?
       Post #: 1158
RE: Redcat vehicle repair/tune FAQ - 5/6/2008 3:11:08 AM
decompetencia
Status: offline
quote:
ORIGINAL: impune
Hi, the size of the engine is .18, there is a screw but only hold the slide carb doesn´t do anything else
here is the picture of the one side and teh other
[image][/image][image][/image]
Click to see fullsize image.
Click for fullsize
Click for fullsize
       Post #: 1159
RE: Redcat vehicle repair/tune FAQ - 5/6/2008 4:26:28 AM
tihstae
Status: offline
on the second pic its the needle right under the throttle arm, just right of the idle screw
       Post #: 1160
RE: Redcat vehicle repair/tune FAQ - 5/6/2008 4:34:44 AM
decompetencia
Status: offline
hi, there is the picture of the screw, but i move that screw and nothing happend
Click for fullsize
       Post #: 1161
RE: Redcat vehicle repair/tune FAQ - 5/6/2008 5:03:35 AM
tihstae
Status: offline
thats what happens with me, im confused with that too, i never used it really, just left it flush, and now im havin troubles with it
       Post #: 1162
RE: Redcat vehicle repair/tune FAQ - 5/6/2008 5:11:42 AM
Swamp3r
Status: offline
quote:
ORIGINAL: decompetencia
Thats the idle screw it's the screw below that for the lsn. I don't know these motors but thats what makes sence.
HIMOTO RACING Keeps me bashing - THE REVOLUTION HAS BEGUN
http://himotoracing.com :: http://himotoracingusa.com
       Post #: 1163
RE: Redcat vehicle repair/tune FAQ - 5/6/2008 6:38:51 AM
jpilkinton
Status: offline
Here is a description using the picture of the engine:
Click for fullsize
(in reply to Swamp3r)
       Post #: 1164
RE: Redcat vehicle repair/tune FAQ - 5/6/2008 6:51:50 AM
Swamp3r
Status: offline
I thought this was a slide carb engine if so the red circle should be blue and the blue circle should be red.
Edit I'm surprised this hasn't been deleted considering it has nothing to do with redcat.
< Message edited by Swamp3r -- 5/6/2008 7:27:51 AM >
(in reply to
