RE: FLITON EDGE 540 FREESTYLE they did it again    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> 3D Flying! >> RE: FLITON EDGE 540 FREESTYLE they did it again Page: <<   < prev  7 8 9 10 11 12 13 [14] 15 16   next >   >>
Login
RE: FLITON EDGE 540 FREESTYLE they did it again - 12/2/2007 5:05 AM
evanspa
Score: 100
Last Login: 5/22/2013
Status: offline
Does the plane come with motor mount and the Pull Pull setup for Rudder?
Hide Signatures
(in reply to victorzamora)
       Post #: 326
RE: FLITON EDGE 540 FREESTYLE they did it again - 12/2/2007 5:23 AM
victorzamora
Score: 134
Last Login: 5/12/2013
Status: offline
It does come with the motor mount, but not with the pull-pull system. If you buy a DuBro pull-pull system, you'll get the best set-up.
_____________________________
Tact is for people not witty enough to use sarcasm.
Hide Signatures
(in reply to evanspa)
       Post #: 327
RE: FLITON EDGE 540 FREESTYLE they did it again - 12/5/2007 8:54 PM
RVM
Score: 100
Last Login: 3/30/2012
Status: offline
I'd use a nylon-coated kevlar set up from DHS...
There is no substitution for human competition.
Hide Signatures
       Post #: 328
RE: FLITON EDGE 540 FREESTYLE they did it again - 12/10/2007 8:33 PM
pinguecola
Score: 100
Last Login: 5/16/2013
Status: offline
i used do bro pull pull and it was fine. i used two hitec 225 mg mighty mini in the tail and now , about 15 flights everything is ok.
the o.s. 70 ultimate is a jewel . never had any other so regular engine. i have a yamada 180 dz on my extra 300 and there are the same kind of an engine if you not mind cubic inches. the edge fly very light, very nice and predictable. slooow and oooohhhh so nice landings ! . great flat spins!!! no coupling in knife edge. she flies better than 1/4 scale i have seen!!
i can hover it and i am using an apc 13-6. i would like to try this wide apc. i get kavan 350 cc. tank and i fly 15 min.( not so calm aerobatic) with 1/3 of cool power still in !!!
i am not able to load photo. i will try again.
ciao francesco
Hide Signatures
(in reply to RVM)
       Post #: 329
RE: FLITON EDGE 540 FREESTYLE they did it again - 12/10/2007 8:39 PM
pinguecola
Score: 100
Status: offline
sorry , yamada 160 dz.
francesco
Hide Signatures
(in reply to pinguecola)
       Post #: 330
RE: FLITON EDGE 540 FREESTYLE they did it again - 12/10/2007 11:59 PM
pinguecola
Score: 100
Status: offline
voila' , i hope
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 331
RE: FLITON EDGE 540 FREESTYLE they did it again - 12/11/2007 12:03 AM
pinguecola
Score: 100
Status: offline
other....
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 332
RE: FLITON EDGE 540 FREESTYLE they did it again - 12/11/2007 12:09 AM
pinguecola
Score: 100
Status: offline
again....
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 333
RE: FLITON EDGE 540 FREESTYLE they did it again - 12/11/2007 12:41 AM
victorzamora
Score: 134
Status: offline
I'm not knocking that engine, in any way. I mean, that fuel pump has to be great...but isn't it a little under-powered with the OS FS-70?
Hide Signatures
       Post #: 334
RE: FLITON EDGE 540 FREESTYLE they did it again - 12/11/2007 12:48 AM
pinguecola
Score: 100
Status: offline
i suspect with saito 100 it will pull out of hovering better than mine, but i think it is the only situation where i would get the change. otherwise i prefer the lightness of my setup. and the o.s. is so regular.....
Hide Signatures
       Post #: 335
RE: FLITON EDGE 540 FREESTYLE they did it again - 12/11/2007 5:34 AM
jamesrxx951
Score: 100
Last Login: 3/26/2013
Status: offline
pinguecola i want to do the same setup on the rudder that you did with putting the rudder servo up front and do a pull pull. how much down elevator travel do you have. i've been triing to figure a setup to get to most travel with out hitting the rudder horns. if possible could you show a pic with full down travel.
Hide Signatures
       Post #: 336
RE: FLITON EDGE 540 FREESTYLE they did it again - 12/11/2007 6:36 AM
victorzamora
Score: 134
Status: offline
Jamesrxx951, I have a sugestion on concerning that. Have you ever seen the Fliton Extra 330 Freestyle's set-up for the rudder? If not, visit www.flitonstore.com or www.fliton.com and go through its pictures. The pull-pull cables exit through the fuselage higher up, and they mount about half-way up the rudder. If I were building it again, I would have done it that way. It's a great set-up, and keeps the rod WAY out of the path of the elevator. I hope that helped!
Hide Signatures
(in reply to jamesrxx951)
       Post #: 337
RE: FLITON EDGE 540 FREESTYLE they did it again - 12/12/2007 8:55 PM
pinguecola
Score: 100
Status: offline
i do not have any trouble about elevator. in 3d rates full deflection it can touch rudder arms, but softly and i never feel it during 3d flight. yesterday some nice hovering with mi little o.s.... this little plane is really fun ! hs 225 hitec good job. light and effective elevator. ( hangar 9 titanium rods). the plane is so light it land almost stopped in the air, nose up. the most beautiful side slip i ever had. you feel at home.
ciao francesco
Hide Signatures
       Post #: 338
RE: FLITON EDGE 540 FREESTYLE they did it again - 12/13/2007 9:11 PM
Gumybear
Score: 100
Last Login: 4/9/2013
Status: offline
JUST WANTED TO POST A WORD ABOUT THE STOCK LANDING GEAR, WITH THE PLANE FULLY LOADED THE CAMBER ANGLE IS NOT AN ISSUE. I PICKED MINE UP SECOND HAND WITH A OS .91 FS, TWO ELEVATOR SERVOS IN THE TAIL, RUDDER SERVO IN THE BOTTOM OF THE TAIL. 15X 4 WIDE PROP. IT WILL HOVER GOOD, NOT THE TREMENDOUS VERT I WAS EXPECTING, BUT THE GENERAL FLYING CHARACTER MAKES UP FOR THIS. I MAY TRY THE PERRY OSCILATING PUMP TO GET A LITTLE MORE UMPH. I AM USEING Y S 20/20 FUEL AND HAVE A VERY RELIABLE LOW IDLE.
Hide Signatures
       Post #: 339
RE: FLITON EDGE 540 FREESTYLE they did it again - 1/14/2008 7:23 AM
pinguecola
Score: 100
Status: offline
now i have circa 60 flights on my edge with o.s. 70 ultimate. what a nice set up !! the plane is feather light and fly oh so fun !!!! ultimate purrs like a dream and it is reliable like a little ys dingo. some coolpower 30% ely mix and hover and pull out nicely !!! and never tried any wide blade !! i am on my first and sole apc 13-6 !!
ciao francesco
Hide Signatures
(in reply to Gumybear)
       Post #: 340
RE: FLITON EDGE 540 FREESTYLE they did it again - 1/27/2008 5:47 AM
pinguecola
Score: 100
Status: offline
some more phots on my sunshine flight....
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 341
RE: FLITON EDGE 540 FREESTYLE they did it again - 2/3/2008 1:14 AM
busted blade
Score: 100
Last Login: 3/3/2013
Status: offline
I just wanted to update my feelings about this airplane. A while back I posted that I wasnt very pleased with my purchase of the fliton plane. Well I finally decided to get it finished up(tired of looking at it stuffed in the corner) and try it out, but instead of using the Saito 100 I had originally installed in it, I decided to go electric for power instead of glow.
I have to admit that the quality of flight totally caught me by surprise. This plane flies awesome. I no longer regret purchasing this plane. It was sort of a pain to get it all setup but it was worth every minute spent.
My setup consists of E-flite power60, Castle phoenix80 ESC, Flightpower EVO25 5s 3300 lipo, APC 16x10 e-prop. PLENTY of power for it. I put in a couple of 4 minute flights earlier(Maiden/setup) Of what I would say very agressive sport flying on it and each time only put back 1080mah on the charge. Seems like I should be able to get 6-8 minutes of flying out of it per charge. I will need to do some more flights though to get the flight times dialed in.
All I can say is I am glad I finally finished it up and put it in the air, If you are thinking of going electric for power on this plane I highly recommend it. It is truly a lot of fun to throw around the sky.
< Message edited by busted blade -- 2/3/2008 1:17 AM >
Hide Signatures
       Post #: 342
RE: FLITON EDGE 540 FREESTYLE they did it again - 2/3/2008 10:20 PM
pinguecola
Score: 100
Status: offline
great job. i have got electic only in small planes and i am afraid it will cost a lot to convert medium or big birds. Anyway my little o.s. ultimate is a great combo on this light plane and i can fliy 15 minutes with 350 cc tank and it floats like a dream ! not a wing rock in inverted harrier and only a bit in up harrier. ciao francesco
Hide Signatures
(in reply to busted blade)
       Post #: 343
RE: FLITON EDGE 540 FREESTYLE they did it again - 2/14/2008 6:05 AM
busted blade
Score: 100
Status: offline
If anyone is interested here is a graph for amps and watts. This setup is very strong for this airplane and flies it well.
setup consists of E-flite power60, Castle phoenix80 ESC, Flightpower EVO25 5s 3700 lipo, APC 16x10 e-prop.
I am currently up to 8 minutes flying time(using good throttle managment). Might be possible to go 10 minutes but havent been able to do more testing due to weather.
Graph is from an eagle Tree data logger and is just a static test for max amps(47amps) and watts(880), Two quick full throttle pulls just to see what I was getting. I dont have any flight graphs yet.
Click for fullsize
< Message edited by busted blade -- 2/14/2008 6:08 AM >
Hide Signatures
       Post #: 344
RE: FLITON EDGE 540 FREESTYLE they did it again - 2/14/2008 7:45 AM
sknx
Score: 100
Last Login: 8/15/2010
Status: offline
Glad to see this thread is still alive. Just ordered my second edge; first one exploded in the air on a 3d rates snap roll more than a year ago. Had 2 extra as well but as much I want to totally get rid of glow this plane with saito 100 it's perfect to keep in the back sit of your car and have some fun after work.
Boby
Hide Signatures
       Post #: 345
RE: FLITON EDGE 540 FREESTYLE they did it again - 2/23/2008 5:04 AM
jamesrxx951
Score: 100
Status: offline
thought i would post the pics of my plane. saito 100 apc 15/4 prop,spectrum dx7 radio with ds821 servo's and hitec 5625 on rudder.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to sknx)
       Post #: 346
RE: FLITON EDGE 540 FREESTYLE they did it again - 2/23/2008 7:34 AM
victorzamora
Score: 134
Status: offline
Gorgeous plane, I wish I still had mine! Have you flown yours yet? Let me know what you think about the flight characteristics!!!
Hide Signatures
       Post #: 347
RE: FLITON EDGE 540 FREESTYLE they did it again - 2/23/2008 9:08 AM
masonman
Score: 100
Last Login: 8/5/2012
Status: offline
I love this model.
I have four planes.
Funtana X50-Saito72....fun
Little toni O.S. FX91.....Nerve racking sometimes
27% Extra 260.............To big to deal with sometimes.
Fliton Edge540..............Total blast
I have a 75 2s on this little guy with a 13x6-10 prop. It will dart across the sky if you want or it will just hang in the sky at half throttle.I put the rudder servo up front help with the CG.I put futaba 3152 digital servos all the way around.Center very well an are snappy aswell.This model is worth its weight in gold.............LOVE IT
Hide Signatures
       Post #: 348
RE: FLITON EDGE 540 FREESTYLE they did it again - 2/23/2008 4:24 PM
jamesrxx951
Score: 100
Status: offline
this is my second one the first the wing root glue gave up in the air and it was to hard to land with only 3 wings,at least on the landing gear. but u can land on the nose the only down fall to that is you can't fly it any more.haha. but i loved flying this plane so much i bought another one. the first had the saito 82 and it was great but needed alittle more power so i put a 100 in it. i havnt flown this one but it should be ablast. this plane makes you very confident. what you ask it to do it does with no problem. just add alittle more glue to the wing root,just incase.
Hide Signatures
(in reply to masonman)
       Post #: 349
RE: FLITON EDGE 540 FREESTYLE they did it again - 2/24/2008 1:25 AM
victorzamora
Score: 134
Status: offline
I had a Saito 100 on mine, and it could fly well no matter what was going on. Even after the Rx battery became unplugged, it flew miraculously and had an "AWESOME" landing. It struck awe in my mind!
But I know what you mean about confidence. The first time I flew it was in 15mph winds. I took off because I had driven nearly two hours to maiden it, so I really HAD to...plus I hadn't flown in 4 months, so I was dying to. The plane wasn't bumpy at all, in fact I did a runway-long HA-KE on the maiden flight. I also did a parachute-to-harrier landing. It wasn't great, and it wasn't really high alpha, but there was enough wind to compensate for that (the wind was a dead-on steady headwind with NO gusts).
I've had two planes that have made me confident, this one and the H9 Tribute 36. The problem with the tribute is it made me feel like i could do stuff it couldn't . The Edge delivers!
I can't wait for y'all to fly and give us all a little flight report.
Hide Signatures
       Post #: 350
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.563RCU1
