RE: FLITON EDGE 540 FREESTYLE they did it again    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> 3D Flying! >> RE: FLITON EDGE 540 FREESTYLE they did it again Page: <<   < prev  6 7 [8] 9 10 11 12 13 14 15   next >   >>
Login
RE: FLITON EDGE 540 FREESTYLE they did it again - 7/30/2006 10:32 PM
Xtrem3dJer
Score: 100
Last Login: 4/16/2007
Status: offline
The instructions in the plans were off for my Saito 100, so I measured the distance from the front of the cowl to the back (about 135mm). Then measured the distance from where the cowl would mount to the front of the motor (where the prop mounts). Just leave space for the prop to spin.
Jer
Hide Signatures
(in reply to .:RClunatic:.)
       Post #: 176
RE: FLITON EDGE 540 FREESTYLE they did it again - 8/16/2006 2:05 AM
s. wallace
Score: 102
Last Login: 10/16/2012
Status: offline
Looks like mixed reviews as w/ most Fliton ARF's but I ordered one Saturday anyway. It looks good and once it's built the flying reviews are pretty positive. Looks great in their video too
I have both a Saito 82 and 91 brand new in the box, can't decide which for this.
I am primarily looking for quasi realistic aerobatic performance and not all out 3D; and would like
to not be worried about overstressing the airframe so I am leaning towards the 82.
Sound about right?
Hide Signatures
(in reply to BasinBum)
       Post #: 177
RE: FLITON EDGE 540 FREESTYLE they did it again - 8/17/2006 5:19 AM
GarySS
Score: 100
Last Login: 5/22/2013
Status: offline
Both are good engines; kind of a toss-up. Some might say the .91 is actually a smoother running engine,though. Almost identical power.
Hide Signatures
(in reply to s. wallace)
       Post #: 178
RE: FLITON EDGE 540 FREESTYLE they did it again - 9/19/2006 10:31 AM
.:RClunatic:.
Score: 100
Last Login: 10/21/2009
Status: offline
anyone have more pictures of their edge freestyle setup, gas in particular? i just picked one up and am thinking of a saito 82 or a 100. saw one at a local fly-in and fell in love, what a great plane...
Hide Signatures
(in reply to GarySS)
       Post #: 179
RE: FLITON EDGE 540 FREESTYLE they did it again - 10/22/2006 5:08 AM
lemmerjo
Score: 100
Last Login: 3/27/2012
Status: offline
Would an MDS .78 work well on the edge? I currently have it in a Funtana .40 and have great performance. I am wanting a new plane and wonder if the Fliton edge would work well with a MDS .78
Thanks Joe
Hide Signatures
(in reply to RenoSportFlyer)
       Post #: 180
RE: FLITON EDGE 540 FREESTYLE they did it again - 10/22/2006 5:13 AM
imfly123
Score: 100
Last Login: 1/9/2007
Status: offline
a buddy has the saito 82 in his and he loves it. it has been his favorite airplane for about 3 months running and i dont blame him. I dont know too much about the MDS .78, but i imagine it would be a great power system with the right nitro mixture. im thinking 20%? the plane is sweet ...
Hide Signatures
(in reply to lemmerjo)
       Post #: 181
RE: FLITON EDGE 540 FREESTYLE they did it again - 11/30/2006 9:32 PM
RC Pat
Score: 100
Last Login: 5/29/2009
Status: offline
Here are some shots of my build with a Saito 100. Going to maiden her this Saturday.
Hide Signatures
(in reply to imfly123)
       Post #: 182
RE: FLITON EDGE 540 FREESTYLE they did it again - 11/30/2006 9:36 PM
.:RClunatic:.
Score: 100
Status: offline
shes looking sweeet pat, goodluck on the maiden. how is it balancing out with the pull/pull in the hatch?
Hide Signatures
(in reply to RC Pat)
       Post #: 183
RE: FLITON EDGE 540 FREESTYLE they did it again - 12/1/2006 5:20 AM
RC Pat
Score: 100
Status: offline
Right now it is just behind the carbon wing tube, I might need to move it forward a little bit, but I'm going to try it here first. I'd say the CG is at about 4.5" behind the leading edge. Anyone have some suggestions?
Hide Signatures
       Post #: 184
RE: FLITON EDGE 540 FREESTYLE they did it again - 12/2/2006 4:05 AM
RC Pat
Score: 100
Status: offline
Here is the finished product, going to maiden her tommorow:
Hide Signatures
       Post #: 185
RE: FLITON EDGE 540 FREESTYLE they did it again - 12/2/2006 4:19 PM
OTT
Score: 100
Last Login: 3/22/2009
Status: offline
I had one of these, which unfortunately met an untimely end. However, it was one of the sweetest flying planes I've ever owned. I also mounted a Saito 100 and had to add a little weight to the firewall (can't remember how much) to get it to balance at the recommended point. I'm not a 3-Dr, but it flew beautifully, and I could do low inverted flybys with complete confidence.
One change that I feel is mandatory is that I used a carb spring to hold the wings together. The first time I tried to take off with rubber bands holding the wings, the right one pulled loose and caused a rather dramatic nose over right at the moment of liftoff, which resulted i nsome customizing of the cowl. You can go to a local discount auto store and buy a variety of carb springs for less than $5.00. Oh, by the way, the supplied control horns are complete garbage. I had an elevator horn break in half in flight, but fortunately I landed with no trouble. I don't know why they supply horns that can be bent like a piece of paper. Replacing all horns with cheap plastic ones solved that problem.
One other thing to watch for; due to the VERY light weight of this model, be very careful when taxiing with some tailwind. Without fail, the plane will nose over if no elevator is dialed in while taxiing.
Good luck on the maiden!
Hide Signatures
       Post #: 186
RE: FLITON EDGE 540 FREESTYLE they did it again - 12/2/2006 5:50 PM
RC Pat
Score: 100
Status: offline
Thanks for the suggestion on the carb springs, I'll get some on my way to the field.
I replaced all of the control horns with Du-Bros because they felt so flimsy. Hopefully
mine will fly as good as everyone says it will.
Hide Signatures
(in reply to OTT)
       Post #: 187
RE: FLITON EDGE 540 FREESTYLE they did it again - 12/3/2006 6:15 AM
RC Pat
Score: 100
Status: offline
Maidened her today and she flew great. The best knife-edge I have ever flown and harriers were very easy. I only flew her twice, but I will get her out next weekend for sure. Great plane.
Hide Signatures
       Post #: 188
RE: FLITON EDGE 540 FREESTYLE they did it again - 12/7/2006 5:17 AM
casey g
Score: 100
Last Login: 3/8/2008
Status: offline
i just got my edge last night and it looks awsome very high quility
i plan on using the saito 100
jr ds811 on 6 volts
im lookin forward to flying her i will get video and post a link once im done with it
i love this plane so far the covering and every thang is awsome. they pack it very well lots of foam. im very happy so far
Hide Signatures
       Post #: 189
RE: FLITON EDGE 540 FREESTYLE they did it again - 12/7/2006 5:30 AM
RC Pat
Score: 100
Status: offline
You will love this plane Casey. Be sure and build up the motor box. This one flies like a big bird. Lets see those videos.
Hide Signatures
(in reply to casey g)
       Post #: 190
RE: FLITON EDGE 540 FREESTYLE they did it again - 12/7/2006 5:57 AM
casey g
Score: 100
Status: offline
cool we need to see some of u flying it to
here is a link to me flying my funtana and now im puttin my stuff in the edge http://www.****/gallery/showphoto.php?photo=17768&cat=504
< Message edited by casey g -- 12/7/2006 6:01 AM >
Hide Signatures
       Post #: 191
RE: FLITON EDGE 540 FREESTYLE they did it again - 2/23/2007 9:47 AM
casey g
Score: 100
Status: offline
Ok I got to maiden my edge last weekend.
This plane is sweet, im so happy with it right now. Knife edge has not coupling to the belly or the cockpit, just the slightest roll. Very little.
And I just got a new video camera last night. so I hope to have video soon, depends on weather, right now I have 2 inches of snow but it should melt by Saturday.
So to some it up im very happy with the plane I only have 6 flights on it but the plane has no bad habits. Landings are slow and easy. It. fly’s bigger then it is and the color scheme presents well in the sky.
So far my favorite thing to do with it is the high Alfa knife edges.
Casey g
Hide Signatures
       Post #: 192
RE: FLITON EDGE 540 FREESTYLE they did it again - 2/24/2007 4:00 AM
casey g
Score: 100
Status: offline
ya i agree
its snowing right now but we might have to [ut the skis on. lol i have to fly
what moter are u using
Hide Signatures
(in reply to imfly1234)
       Post #: 193
RE: FLITON EDGE 540 FREESTYLE they did it again - 2/24/2007 6:23 AM
3DHUSKER
Score: 100
Last Login: 6/14/2012
Status: offline
How is the landing gear holding up?
I heard some talk of the gear breaking and not taking much abuse.
_____________________________
The question is not "Is it going to crash?".....It is "WHEN?"
Fly it like you stole it!!!
Hide Signatures
       Post #: 194
RE: FLITON EDGE 540 FREESTYLE they did it again - 2/24/2007 7:26 AM
casey g
Score: 100
Status: offline
i only have 6 flights on it and the landing gear semes to be doing fine. i dont usaully land hard so im not the person to ask about that but i bet it will be just fine.
casey g
Hide Signatures
(in reply to 3DHUSKER)
       Post #: 195
RE: FLITON EDGE 540 FREESTYLE they did it again - 2/25/2007 12:16 AM
3DHUSKER
Score: 100
Status: offline
Some have said theirs is cracking, just wanted some more input before i pull the trigger on one.
I am going to put a ys 63 in it.
< Message edited by THUNDERSTICK -- 2/25/2007 12:17 AM >
Hide Signatures
       Post #: 196
RE: FLITON EDGE 540 FREESTYLE they did it again - 2/25/2007 3:32 AM
casey g
Score: 100
Status: offline
Hey guys got to fly this morning with skis on the plane. It affected it a little but not much but I got some vid but not much. Dad thought he was recording but forgot to push the button lol. i will shoot more vid over the next few weekends and hopefully get a good vid.
The thing I love the most about this plane is the knife edges. They are so sweet. And on the planes 7 flight im bringing it down in a high Alfa knife edge at about 2 to 3 foot. the plane fly’s so stable.
Casey g
Hide Signatures
       Post #: 197
RE: FLITON EDGE 540 FREESTYLE they did it again - 3/7/2007 9:08 AM
casey g
Score: 100
Status: offline
hey guys
the weather is lookin a lot nicer for this weekend and i plan on getting more vid so hopefully some time in the near future we will get a new vid lol
but i still love this plane .
casey g
Hide Signatures
       Post #: 198
RE: FLITON EDGE 540 FREESTYLE they did it again - 3/7/2007 2:58 PM
pliebo
Score: 100
Last Login: 5/15/2011
Status: offline
hey guys, this is making me want to go fly mine again. I haven't flown it in a while but I do love it. I am having a little trouble with my gear . it's cracked pretty bad and is real wobbly on landing I'm afreaid it might break and do some damage to the plane. Other than that, I love the way this one flies!
IF YOU ONLY HAVE TO BEND OVER ONCE TO PICK UP YOUR PLANE, IT WAS A GOOD LANDING
Hide Signatures
       Post #: 199
RE: FLITON EDGE 540 FREESTYLE they did it again - 3/7/2007 6:09 PM
casey g
Score: 100
Status: offline
i would give edson @ fliton a call he should be able to help u out .
casey g
Hide Signatures
(in reply to pliebo)
       Post #: 200
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.047RCU1
