RE: Eletronic engine syncronizer - no joke
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Twin & Multi Engine RC Aircraft >> RE: Eletronic engine syncronizer - no joke
Page: <<   < prev  6 7 8 9 10 11 12 [13] 14 15   next >   >>
Login
RE: Eletronic engine syncronizer - no joke - 7/28/2006 3:51:06 AM
roltech
Status: offline
quote:
ORIGINAL: yl5295
Here is the new glowplug algorithm that runs once per second:
If plugs are off....
is there rpm on at least one engine?
yes: are both engines >3500 rpm
yes: leave plugs off
no: turn plugs on and start 30sec timer
no: leave plugs off
if plugs are on...
is there rpm on both engines?
yes: are they both >3500rpm
yes: turn plugs off
no: leave plugs on
no: if 30 sec timer has expired then turn plugs off
I personally like the older version better with the timer but I don't fly four-strokes. Seems like this is what everyone wants. Let me know before I start shipping this software if this needs any changes.
Right now both plugs turn on and off together so both engines have to be >3500 rpm to turn off and if either engine goes below 3500 they will come on. Maybe if a lot of these devices are sold I might spend the time to sense each engine and automagically turn on each plug independantly but right now I don't see a need to put that much time into it. The other problem is there is only one red LED (1 plus a connector). You really need two glowplug leds if they were independant.
I don't know about 2 stroke in twins my own opinion I think that most twin would run 4 strokes, even if it 's just for how they sound.
roltech
(in reply to yl5295)
       Post #: 301
RE: Eletronic engine syncronizer - no joke - 7/28/2006 4:22:14 AM
yl5295
Status: offline
That is already there. Mode 5 is a switch/AUX channel controlled glow driver. The aux channel switch turns it on and off.
(in reply to Kmot)
       Post #: 302
RE: Eletronic engine syncronizer - no joke - 7/28/2006 4:26:08 AM
William Robison
Status: offline
Rol:
I don't know for sure, but I'd suspect there are far more two stroke twins than four stroke powered. Of all mine, only one has four stroke engines. I am putting another together now, when it's finished I'll have seven (I think) two stroke, and two with four stroke engines.
TomK:
One mode in the TwinSync is already set to allow tx conttol of the glow heat.
Bill.
_____________________________
Real Airplanes have Two Engines
AMA 25139 - More than 40 years.
(in reply to roltech)
       Post #: 303
RE: Eletronic engine syncronizer - no joke - 7/28/2006 4:41:44 AM
roltech
Status: offline
quote:
ORIGINAL: William Robison
Rol:
TomK:
Bill.
You probably right! I'm putting together a B 25 and will install 2 - 4 stroke RCV 91 CD mostly for more realistic sound. If anyone think I should not I would like to know why. Every thing I will install in this model will be first class, after all it cost enough in the first place,and I want to do it right.
roltech
(in reply to William Robison)
       Post #: 304
RE: Eletronic engine syncronizer - no joke - 7/28/2006 4:51:29 AM
pc55bomber
Status: offline
Hi Bill
To sum up the software upgrade in relation to the glow plug driver:
Engine running --Glow on both plugs if RPM <3500
Starting -- Rock prop to start glow, Engines not started 30 sec timeout turns glow off.
Engines running -- RPM <3500 glow on until RPM >3500 (does the timer kick in here?)
Is my summary correct?
I cant see the point in having independant glow sensing when in practice if you loose an engine
you will want to land as soon as possible so the drain on the glow battery is not important.
From a practical viewpoint IMO there is no need to go any further with the device its great.
Cheers
Paul
(in reply to Kmot)
       Post #: 305
RE: Eletronic engine syncronizer - no joke - 7/28/2006 5:06:17 AM
William Robison
Status: offline
Rol:
The first and most important consideration in selecting engines for a twin is reliability.
To me reliability is Saito, K&B, and Magnum. I have only one twin with another brand, that one has the Russian AMD 0.061 engines, none of the others were small enough.
The latest plane I’m putting together was supposed to get the K&B ringed 61 engines, but when I started to fit them the amount of wood that had to be removed changed my mind. Tried a Saito FA-72, looked great, so I ordered a new pair of FA-82 engines for it.
The K&B engines were (and are) ready for installation, the new Saitos mean a fair delay getting them run in and set as well as a goodly chunk of added money. But I think the result will be worth the expense and delay. I’ll use the K&B engines in the Super Duellist and the new Tigercat. They will both accept the two stroke engines without a lot of cutting. And I have a pot full of the K&B engines.
So what I’m saying is this plane was intended to be a two stroke also, just the nacelle design made me change my mind and go with four stroke engines.
I think the pictures will illustrate my point here.
Bill.
Click to see fullsize image.
Click for fullsize
Click for fullsize
       Post #: 306
RE: Eletronic engine syncronizer - no joke - 7/28/2006 5:25:53 AM
yl5295
Status: offline
Roltech,
in response to post #301... I guess it depends on scale flyers versus sport/speed loving flyers. I personally would not build a twin with four stokes because the sound of synced screaming 2 strokes is why I build twins. I would build a gas powered twin though for many reasons.
I have twin engine combat planes and eveyone at the field thinks they are very fast (many estimate about 90MPH). They are 2548 legal and are not fast- 17.5K rpm on an 8x3 prop puts them at probably 60mph is my guess. The only thing that turns more heads than a low flyby with twin two stokes in sync is a turbine. I often take my twin engine combat planes sport flying - just because I like the way they sound.
I think I probably have an example of every other single engine flying model available like big gas 3D aerobats with smoke, WWI and WWII scale planes, pattern, Q500, helis, turbine jet, etc., etc. Twins excite people including the pilot when they scream by in sync. But that is hard to do and many have really nasty habits when one dies. (I spent hours getting a P-38 out of a tree one time) that is why I sunk the time into this device even though I have higher volume, more profitable, and easier products that I could have introduced first.
I am building a scale twin now and I may eventually go to 4-strokes for it but they are 2X the price. I saw a piped duelist fly once and it seemed like the echos lasted for about 5 seconds after a highspeed pass. There are probably more scale twins out there than than anything else but I think we are getting ready for increasing populatiry of twins because of increasing reliability and arf companies trying to differentiate. I bet that it is about even now (2S/4Stroke). I predict in a year there will be 2X-4X more 2 stroke twins than 4stoke twins flying. Gas twins will always dominate scale events.
Just my opinion.... At my field the crowd argued whether I should put 2-stokes or 4-stokes in the Cessna 310 I am building and it was about 3:1 in favor of the 2-stokes because of the sound. The guys that wanted 4-stokes were the full scale pilots.
(in reply to pc55bomber)
       Post #: 307
RE: Eletronic engine syncronizer - no joke - 7/28/2006 5:45:52 AM
yl5295
Status: offline
In response to PC55 post #305...
Great question... I actually had to look at the code to answer it...
The timer kicks in every time the plugs are turned on. The plugs are only turned off by both engines going to >3500 RPM or 30 seconds later and both engines engines are not running yet.
So now I realize that I was thinking when I wrote this code. In the event of a dead stick the plugs will come on but will go off after the timer expires in 30 seconds.
I think I like this plan/software right now... very simple and easy to use.
The other thing that I saw when looking through the software tonight that I thought I should point out is that the plugs will never turn on if a TX signal is not present. So no worries about turning over the props with handling unless you have a PCM receiver. Then you can turn plugs on if the RX is powered and failsafes are set.
Bill
       Post #: 308
RE: Eletronic engine syncronizer - no joke - 7/28/2006 6:25:41 AM
Kmot
Status: offline
quote:
ORIGINAL: yl5295
quote:
TomK:
Good enough for me. Thanks fella's!
Ahhh......screw it!
       Post #: 309
RE: Eletronic engine syncronizer - no joke - 7/28/2006 7:02:48 PM
Jim Reeves
Status: offline
Silly question here ...what if my receiver has not got an aux socket, where do I put that plug..
Jim
Always put off today what you can do tomorrow....
       Post #: 310
RE: Eletronic engine syncronizer - no joke - 7/28/2006 7:13:30 PM
William Robison
Status: offline
Jim:
"AUX" channel just means any channel not used for the primary flight controls. If you’re using AUX for the glow control as an example, channel five which is usually retracts can have its on-off switch used. If your transmitter has a three position flap witch, that could be used for the independent engine run up, and so forth.
Bill.
(in reply to Jim Reeves)
       Post #: 311
RE: Eletronic engine syncronizer - no joke - 7/28/2006 9:08:16 PM
Jim Reeves
Status: offline
Many thanks Bill, retract switch it is, I'll be using the proportional flap control.........for flaps!!
Jim
       Post #: 312
RE: Eletronic engine syncronizer - no joke - 7/29/2006 5:10:28 AM
roltech
Status: offline
One of the reason of choosing the RCV CD .91 is that other than the muffler there is no cutting on the cowl for the motor
hence CD stands for Compact Design.This motor was recommemded by the MFG of the B 25 . but after reading the post I will give it a good thought about what I will install.
Thanks guys.
roltech
< Message edited by roltech -- 7/31/2006 1:16:59 AM >
       Post #: 313
RE: Eletronic engine syncronizer - no joke - 7/30/2006 8:10:03 PM
drifter
Status: offline
Bill,
Here is a situation I have not seen a comment on.
I have an OV-10 Bronco fitted with two receivers, one in each boom. Each engine servo is connected to the throttle channel on it's respective receiver. Both are on the same frequency. Will the Twin sync function with each engine controlled by the throttle function on each receiver, or do I have to use an auxillary channel on one of the receivers? Since the Twin sync controls the channel plugged into it , can they both be throttle channels or must the Aux on one be used?
       Post #: 314
RE: Eletronic engine syncronizer - no joke - 7/31/2006 1:31:14 PM
yl5295
Status: offline
I have not considered this mode of operation. Is the reason you have two receivers due to wiring difficultly or safety?
If it is safety then having two throttle signals going to the twinsync will not make it "safer". The throttle signals should be the same. If they are not something is wrong? What should you do if something is wrong? Well you want the engines matched. The worst thing you could do is idle one and have the other at full power. The best thing to do probably is to idle or kill both engines. The device will do that now with only one throttle input if it is an FM recevier and it looses throttle signal.
If it is a problem of running wires there is no way arround having to run a wire between booms regardless of the design of a syncronizer because both booms have to know the RPM of the other boom to sync the engines. So there has to be at least one or more wires between the booms.
I guess I don't see a reason to run two throttle signals to the device? Control surfaces I understand how dual receivers add safety and simplify wiring. (actually interference is more likely with two receivers than one). But for throttles on a twin seems to me like one is better or at least as good?
Am I missing something here?
(in reply to drifter)
       Post #: 315
