MORROMAXX
Joined: 11/9/2002 From: Panama, PANAMA Status: offline
Butlern: Good moorning, I have a Kmp Beaver flying now, it is my first big plane and I like it, but yes it does need some mods This is what I did: 1 Got rid of the 2 servos and stock water rudder ( too heavy) and installed a Ernst rudder and a pull pull system using the rudder servo. The access hatch was eliminated and painted the floats: Water would come in even if I put silicone on the hatch cover. 2. All hardware, screws, clevis were gone. Bad quality. 3. Inside the fuse where the aluminum tube goes in and the former were reinforced, the firewall was also reinforced. 4. And the most important was to correct the position of the step of the float, originally was 3 inches behind the cg, end up at 1 inch behind the cg, and the wing incidence was 8 degrees so I fix it and made it 2 degrees. Also got rid of that cheap landing gear and struts and made new with some aluminum bars I bought on a web site. By doing so I notice the floats were 18 inches appart and the rule tells you they should be 25 percent of the wingspan, so 24 inches apart, so I dit it that way. 5 The wing strut goes attach to the wing by a regular screw. I put a blind nut in there ( on the wing) and replace the screw. I did this to make the wing and strut stronger, once came off on flight. If you have any question feel free to ask, and hope it helps Sincerely Morromaxx
_____________________________
morromaxx
