Tim Taylor
WY, USA Status: offline
quote:
ORIGINAL: Josey Wales Ok I spoke with Sullivan and they suggested to go to a lower voltage pack so I tried a 7.4 instead of the 11.1 and its MUCH better..even at 7.4 it still really pumps a lot at 100%..I lowered my End Point to 30% and it seems just about perfect...at least on the ground..The smoke comes on just a few clicks under 1/2 throttle..hopefully I will be close enough so I will only have to adjust the end point a little. Bob this is how I have my TX setup..its a 9C Pump is plugged into channel 5 endpoint is 30% PMix #6...throttle master..aux 5 slave Aux 5- null pos 1 +100 pos 2 -89 pos 3 -90 pos 4- 90 pos 5 -93 I sat mine up yesterday after I found the smoke was killing the engine at low RPM. I used the Futaba FAQ for the 9C. My reciever is a PCM 9 channel. The pump is a TME SmartSmoker Simple Smoke Pump. The pump is on channel 8. I had lots of trouble setting it up as the FAQ said but it did work as a guideline. Setup is in PMX-6. Channel 8 is Aux2. Aux 2 had to be reversed or it was max smoke at idle and Minimum at full throtttle. The subtrim of +120 needed to be used to get the pump to slow to a crawl with the motor at idle. By crawl I mean it pumps about two clicks at a time seperated by several seconds before the next cycle. So -100 means crawl. This is still enough to put out some thick smoke at idle but it doesn't seem to want to kill the motor. Switch A was used to cut off the smoke completely. Formerly I had it on one of the side VR's. It worked OK there, but it was too easy to kill the motor plus I was wasteing oil. Page 1; Mix ON Mas 3:Thro Slv 8:Aux2 Link Off SW A Position Null Page 2; On Thro-Aux2 Pos 1 -100 Pos 2 -100 Pos 3 -90 Pos 4 -60 Pos 5 -40 With the -90, -60, -40 the smoke thickens to max without much residue on the plane. I'm concidering reducing the numbers further to make the smoke last longer, IE -100, -100, -90, -75, -60 or lower. I'm running two 10 ounce smoke tanks. Also, I use a seperate 6v battery and external switch for the smoke. This is just my setup, it may not work for others.
< Message edited by Tim Taylor -- 5/27/2007 11:36:08 PM >
