DaddySam
WA, USA Status: online
I had a Sullivan Skywriter that worked great, except for the fact that it was causing my radio to glitch. It took me quite a while to figure out it was the pump that was causing the problem. I opened it up and just by moving the PC board it would intermittently cause the radio to glitch. Also, I never could get the pump to stop running, using my PMIX on my Futaba so that I had full smoke at full throttle, progressively less to half throttle, and none at below half throttle. So now I'm doing my pre-purchase research on the other brands. Anybody have glitching problems with the Slimline or 3W? thanks, Sam PS: I echo the praise for SuperDri. I used up the last of my Bennett's and switched to SuperDri. What a difference! For the relatively small amount of time that I use smoke, the money is well spent on SuperDri.
