RE: The BEST Smoke System
Tower Hobbies
Logged in as Guest
  Printable Version
Universal Cradle System
Seller:  flyn4wrd
Details:   $175.00   |  10/5/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> RE: The BEST Smoke System
Page: <<   < prev  1 [2] 3 4 5 6 7 8 9 10   next >   >>
Login
RE: The BEST Smoke System - 5/17/2006 2:56:18 AM
Josey Wales
Status: offline
How much oil do you guys get on the bottom of the planes with the smoke?
_____________________________
Joe
(in reply to mrbigg)
       Post #: 26
RE: The BEST Smoke System - 5/18/2006 4:05:34 PM
Hooked-On-RC
Status: offline
well that all depends on what smoke oil you use....some you get far more than others.
Diesel fuel= BIg Mess
Diesel and transmission fluid=Big Mess
Mineral Oil= Big Mess
Super Dry= not to bad, easily cleaned up
Almag Oil= not to bad, easily cleaned up
I am sure guys have a million different recipes for smoke oil, personally I like almag oil, makes really thick long lasting ultra white smoke. I haev actually flown my plane in such a manner I haev been able to create a knot in teh sky with the smoke!
Hooked-On-RC
"I am not rich enough to buy cheap stuff"
(in reply to Josey Wales)
       Post #: 27
RE: The BEST Smoke System - 5/21/2006 6:52:12 PM
bdunsire
Status: offline
I've been very pleased with my new TME programmable pump - about 100 smoking flights so far (a lot of smoke from that plane) - the biggest problem is getting the programming right, but for any electric pump getting the flow rate to throttle setting is always going to be a challenge (I mean if you want to have tons of smoke, and a minimal clean up) .
I have used the previous TME (simple smoke) pump for more than 8 years - and overall I would say I was not terribly happy with it, but the new one is excellent!
       Post #: 28
RE: The BEST Smoke System - 5/21/2006 9:38:09 PM
mrbigg
Status: offline
how do you program the mix? I have a RD8000 and would have to use channel 8, which is operated by a switch. This channel has endpoint and center adjustment that can be done. I'm guessing that I would use the throttle as the Master and the #8 as the Slave.
PROVERBS 15:22 - Plans go wrong for lack of advice; many counselors bring success.
(in reply to bdunsire)
       Post #: 29
RE: The BEST Smoke System - 5/22/2006 8:14:15 PM
ww2birds
Status: offline
Interesting thread. I have used the Don Harris pumps for years with Zero problems.
Of course, the supply of DH pumps is zero (as far as I can tell), so I've been searching for an alternate.
I bought one of the programmable PowerBox pumps from AI. It pumps fine, and seems similar to the DH .. BUT .. the entire range of programmable flow occurs over a very very small range of proportional channel travel .. to the point where it's virtually impossible to adjust the flow rate smoothly.
Are others having this problem? Am I missing something?
Dave
       Post #: 30
RE: The BEST Smoke System - 5/28/2006 2:54:16 AM
mrbigg
Status: offline
Well, I picked up a TME Simple Smoke II at the LHS today. I'll see if I can get it going by tomorrow afternoon and will post some pics.
(in reply to ww2birds)
       Post #: 31
RE: The BEST Smoke System - 5/29/2006 3:57:10 AM
Flying Hog
Status: offline
Hey Guys.... I just Installed a Sullivan Skywriter and fired her up today 4.8v battery, 20oz tank, and Superdry Smoke oil. A short video, nothing fancy... Check it out. http://media.putfile.com/Smoke-On
Bob
       Post #: 32
RE: The BEST Smoke System - 5/29/2006 2:53:59 PM
mrbigg
Status: offline
nice video. I'm going to try and finish my install today. Had to hit a cookout yesterday.
(in reply to Flying Hog)
       Post #: 33
RE: The BEST Smoke System - 5/30/2006 1:53:53 AM
mrbigg
Status: offline
Finished the install and started it up. Plenty of smoke at just above idle and half throttle where I fly most of the time. Actually, plenty across the whole throttle range. I'll get some pics tomorrow, the rain came in before my assistant arrived to help with taking them.
       Post #: 34
RE: The BEST Smoke System - 5/30/2006 12:01:17 PM
Flying Hog
Status: offline
Mrbigg... I haven't read the whole thread, what are you using for oil?
Bob
       Post #: 35
RE: The BEST Smoke System - 5/31/2006 1:43:24 AM
mrbigg
Status: offline
I just grabbed a jug of Super Dry (spelling?) off the shelf. Seems to work good.
Here's some pics. These pics cost me $60.00. When I was putting the plane back in the garage, the prop tip caught the brick moulding around the garage door and cracked it!
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by mrbigg -- 5/31/2006 1:50:36 AM >
       Post #: 36
RE: The BEST Smoke System - 6/15/2006 1:37:50 AM
mikerc
Status: offline
I have a Sullivan Smoke system. Works great. I have a 2 cell lipo running it. Here it is on my 35% Edge/DA100. http://www.mikerc.com/video/Edge%20Flying%206-18-05.wmv
Using Super Dri. I am planning on putting one in a GP Stearman with a Saito 125. Should be cool.
       Post #: 37
RE: The BEST Smoke System - 6/16/2006 9:00:34 PM
mrbigg
Status: offline
Nice smoke show!
How do you load your video into the windows media player and then get a link to it?
(in reply to mikerc)
       Post #: 38
RE: The BEST Smoke System - 6/16/2006 9:51:38 PM
mikerc
