RE: New Giant GP Super Sportster!!!!!    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> ARF or RTF >> RE: New Giant GP Super Sportster!!!!!
Page: <<   < prev  91 92 [93] 94 95 96 97 98 99 100   next >   >>
Login
RE: New Giant GP Super Sportster!!!!! - 10/11/2012 4:35 AM
Joystick TX
Score: 170
Last Login: 4/19/2013
Status: offline
quote:
ORIGINAL: Super08
How did you like the Worldtex? I used it for the first time this year as well. I found with high heat you can stretch it around anything. I hear it does get dirty easy however if it is not clear coated.
I liked the Worldtex for the ease of covering. My covering skills are terrible, so I didn't try to do any fancy stretching.  I don't know about how much dirt it will pick up and hold yet. I do have some clear paint on it, a very light coat. I fly from a grass and dirt field, so I hope it is easy to clean.
_____________________________
Steve
Check Six!
Hide Signatures
(in reply to Super08)
       Post #: 2301
RE: New Giant GP Super Sportster!!!!! - 10/18/2012 2:08 AM
Joystick TX
Score: 170
Status: offline
I just put a brand new Syssa 30cc engine on my re-covered GSS. Happy 70th birthday! (To me)
Plan to do the maiden early  tomorrow.
Steve
Check Six!
Hide Signatures
(in reply to Joystick TX)
       Post #: 2302
RE: New Giant GP Super Sportster!!!!! - 10/18/2012 2:22 AM
Charlie P.
Score: 192
Last Login: 5/18/2013
Status: offline
Hals und Beinbruch!
Tear up that sky.
Charlie P. (NY) "Gravity is weak but persistant".
AMA 747089/IMAA 30723
Hide Signatures
       Post #: 2303
RE: New Giant GP Super Sportster!!!!! - 10/18/2012 3:03 AM
Super08
Score: 135
Last Login: 5/17/2013
Status: offline
Mine arrived in the mail today, everything looks good.
Quote: Hey, who put that tree there?
Ultra Sport brotherhood #125
Hide Signatures
(in reply to Charlie P.)
       Post #: 2304
RE: New Giant GP Super Sportster!!!!! - 10/18/2012 3:27 AM
Joystick TX
Score: 170
Status: offline
Mine started up and ran great, got 30 min of run time on the ground today. Still have the factory carb settings. Restarts were good, all hand flipping, took four or five times at most. Solid idle at 2K, may go as low as 1,700 but don't want to try that in the air. Don't need to go that low with a 14.5 lb plane anyway. Top RPM was 8,700 with the 18.5x5.5 Vess prop.
Steve
Check Six!
Hide Signatures
       Post #: 2305
RE: New Giant GP Super Sportster!!!!! - 10/18/2012 7:37 PM
Joystick TX
Score: 170
Status: offline
Did the re-maiden flight today with the new engine and new covering job.
Got 45 min of flying time, no trim adjustments were required, nothing came loose, fell off, or broke so it was a great day. Temps in the low 50's and zero wind.
The Worldtex does pick up and hold dirt and goop from the engine breaking in, but it comes off with Bug and Tar remover from Turtle Wax. Not sure yet if that will do any damage to the pin-stripe tape or paint, but so far so good.
Wow, the prop in the picture sure looks big, but is only an 18.5" prop.
Click to see fullsize image.
Click for fullsize
Click for fullsize
< Message edited by Joystick TX -- 10/22/2012 5:13 AM >
Steve
Check Six!
Hide Signatures
       Post #: 2306
RE: New Giant GP Super Sportster!!!!! - 10/20/2012 1:29 AM
Charlie P.
Score: 192
Status: offline
quote:
ORIGINAL: Joystick TX
Got 45 min of flying time, . . . , nothing came loose, fell off, or broke so it was a great day.
That's what I look for in a good model!
Glad it "came back" for you and is again making air time.  Good work!
Hide Signatures
       Post #: 2307
RE: New Giant GP Super Sportster!!!!! - 10/22/2012 1:48 AM
Joystick TX
Score: 170
Status: offline
Now that I have some run time on the engine I decided to put on the cowl.
I liked the carb screw guide tubes that Jim made for his plane, but I'm lazy so mine are not as professional. I did put some brass tubes, with hex screw heads, over the crappy screws that come with the Walbro carb; I can never get a screwdriver to stay in those odd slots.
My method of figuring out where the engine cutouts should be made is shown. It usually takes three or four manilla folders to get it right, okay close enough. Got the cowl marked and ready to cut. I always hate making the cowl cutouts for the engine. Don't know of an "easy" way to do that.
Notice that the template is marked "bottom", that is important because if it is flipped over and the cowl is cut with it that way, the muffler stinger holes will not line up right due to the engine offset. I hate it when that happens.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Steve
Check Six!
Hide Signatures
       Post #: 2308
RE: New Giant GP Super Sportster!!!!! - 10/23/2012 3:39 AM
Joystick TX
Score: 170
Status: offline
Thanks Bill for getting a good picture of me with my favorite plane.
Click for fullsize
Steve
Check Six!
Hide Signatures
       Post #: 2309
RE: New Giant GP Super Sportster!!!!! - 10/23/2012 6:20 AM
Super08
Score: 135
Status: offline
Now that is a smile.
Hide Signatures
       Post #: 2310
RE: New Giant GP Super Sportster!!!!! - 10/23/2012 12:34 PM
Muttdog
Score: 100
Last Login: 5/16/2013
Status: offline
I have found a great tool for cutting out the cowls. I had a neighbors RotoZip at my house that I was borrowing for another project but tried it when I was cutting out a cowl. As long as you can support the cowl properly it is a piece of cake. You can make plunge cuts with no issues and it moves through the fiberglass like a hot knife through butta. It's basically nothing but a small sized router. Making perfectly straight lines is hard so I cut a little inside the lines and used a handheld dremel with sander roll to finish it off.
Hide Signatures
       Post #: 2311
RE: New Giant GP Super Sportster!!!!! - 10/23/2012 12:46 PM
Joystick TX
Score: 170
Status: offline
I have a Roto Zip and Moto Tool. Seems like I tried both of them before and since they are rotary tools, they had a mind of their own when trying to cut straight line.
I may practice on the old cowl an try again.
Thanks.
Steve
Check Six!
Hide Signatures
(in reply to Muttdog)
       Post #: 2312
RE: New Giant GP Super Sportster!!!!! - 10/23/2012 1:30 PM
ahicks
Score: 669
Status: offline
If the bit is held 90 degrees to the surface it's cutting, it's a lot harder to control than one layed way over in the direction of the cut. I doubt you'll ever get to the point where you could make a finish cut though? FWIW, -Al
Hide Signatures
       Post #: 2313
RE: New Giant GP Super Sportster!!!!! - 10/23/2012 1:32 PM
Muttdog
Score: 100
Status: offline
agreed but it works great to remove 99% of the material. I then go in with a dremel hand held tool with sanding roll to remove the final 1%
Hide Signatures
(in reply to ahicks)
       Post #: 2314
RE: New Giant GP Super Sportster!!!!! - 10/23/2012 2:31 PM
Super08
Score: 135
Status: offline
I just use a Dremel cutoff wheel for the rough cut and finish with a sanding drum.
Hide Signatures
       Post #: 2315
RE: New Giant GP Super Sportster!!!!! - 10/25/2012 9:28 PM
Joystick TX
Score: 170
Status: offline
Muttdog and Ahicks,
Took your advice and it worked great. Did some practice cuts on the old cowl first just to get the hang of it. Not holding the tool at 90 degrees helped a lot. Also, not trying to do a finish cut. I always get in a hurry. This job is still not on my top 100 "fun" things to do list.
Anyway, I think the re-cover job is finally done. Cost was $150 to $170, I lost track, but way more expensive  than I thought it would be. It may be worth it to look at a finish without all the wrinkles.
Click for fullsize
< Message edited by Joystick TX -- 10/25/2012 11:05 PM >
Steve
Check Six!
Hide Signatures
       Post #: 2316
RE: New Giant GP Super Sportster!!!!! - 10/31/2012 10:10 PM
CB36
Score: 105
Last Login: 4/7/2013
Status: offline
Hi all,
I'm just finishing up my conversion to fuse mounted gear. I'm wondering what size wheels, (tires), you all are putting on?
Thanks!
Hide Signatures
       Post #: 2317
RE: New Giant GP Super Sportster!!!!! - 10/31/2012 10:18 PM
Muttdog
Score: 100
Status: offline
I used the wheels it came with along with the wheel pants. If you plan on flying off of grass you could certainly go bigger but I have not had any issued with the standard wheels it came with.
Hide Signatures
(in reply to CB36)
       Post #: 2318
RE: New Giant GP Super Sportster!!!!! - 10/31/2012 10:43 PM
Joystick TX
Score: 170
Status: offline
I'm using the 4-1/4" antique wheels. I fly off rough fields and grass, so the are great for that.
Steve
Check Six!
Hide Signatures
       Post #: 2319
RE: New Giant GP Super Sportster!!!!! - 11/2/2012 4:35 PM
Joystick TX
Score: 170
Status: offline
Got about 6 hours of time on the plane with the new engine and covering. Here it is with the cowl and the cowl cutouts.
Click for fullsize
Click for fullsize
Steve
Check Six!
Hide Signatures
       Post #: 2320
RE: New Giant GP Super Sportster!!!!! - 11/2/2012 5:22 PM
Super08
Score: 135
Status: offline
Excellent!
Hide Signatures
       Post #: 2321
RE: New Giant GP Super Sportster!!!!! - 11/3/2012 5:48 AM
Kostas1
Score: 330
Last Login: 5/14/2013
Status: offline
Excellent job Steve!!!!
<==**Check my gallery for more pictures**
Club Saito member #706
Hide Signatures
       Post #: 2322
RE: New Giant GP Super Sportster!!!!! - 11/17/2012 12:46 AM
Joystick TX
Score: 170
Status: offline
Got the engine broken in, just started on gallon #3 with the Ultra HP synthetic oil. Nice to have a clean plane again.
Steve
Check Six!
Hide Signatures
       Post #: 2323
RE: New Giant GP Super Sportster!!!!! - 11/18/2012 12:31 PM
sevillious
Score: 100
Status: offline
Hello all, I was wondering if anyone has had success converting one of these to electric? I am thinking of a Hacker A 60 with a cc HV 120 ESC.
10 cells. My biggest problem is going to be where to put the batteries. Don't really want to remove the wings for a batt. change. Anyone have any suggestions? Any advice would be greatly appreciated.
Hide Signatures
       Post #: 2324
RE: New Giant GP Super Sportster!!!!! - 11/18/2012 2:34 PM
Joystick TX
Score: 170
Status: offline
I think it would be a great electric powered plane.
It would be easy to make a section of the fuselage with the canopy removable with some minor kit-bashing. A lot of us have already moved the gear from the wing to the fuselage. Magnetic latches could be used to hold the hatch on and make it easy to R&R the batteries.
Steve
Check Six!
Hide Signatures
(in reply to sevillious)
       Post #: 2325
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.922RCU1
