JR16
PA, USA Status: offline
quote:
ORIGINAL: yyyh412 quote:
ORIGINAL: JR16 quote:
ORIGINAL: JR16 ok a few months back I started working on my GSS. I purchased the fugi 32b with the plane. for those of you with this motor how does it run? what 2 stroke oil are you using? I have read that this motor with lack of a better term "sucks", what are you thoughts? this will be my first gas plane. Thank you John I bought the package of the GSS and 32B from Tower, After some vibration issues (My Wing dowl pins were not secured properly by me) I have had no issues with the 32B. It was plug and play. Once broken in, its performance is perfect for my needs (Sport flying) It starts easy, runs well. With the addition of the Fuji smoke muffler and a smoke system it is an awesome site to see. I'm just using penzoil 40:1 and pump gas after break in. Thought heavy with the magneto ATM ignition, I still had to add 6oz of lead to the tail. The current 32B has no issues as shipped, some crankcases had issues very early on thought. Does this engine suck? No. Is it the end all for your GSS? No. many engines used produce more power. But as a plug and play unit with the GSS for your average sport flyer its perfect.... ~johnny how do you have your electronics setup im still coming up with having to add atleast 12oz's to the plane My CG is at the forward limit, All electronics to the rear including a 4200mh battery. That where I picked up most of the weight saving for CG ballast by moving that receiver battery way aft... haha thats the same battery im going to put in my plane, I have a 1500 in there now. How did you mount that battery? Im thinking about epoxying in like a battery box under the servos in the rear.
