flaviosi
Joined: 3/2/2007 From: Rio de Janeiro, BRAZIL Status: offline
Thunder, I'm the one who did. Someboduy gave me this tip, and I did it. I don't know tjhe tech stuff behind it, but it works. What I did: I took a 1/16 ply, cut a square out of it and wrapped it with thin alum foil, the one used to pack sandwiches. I screwed it to the latest cavern and passed a wire from one of the screws to ground it on the engine block. Also, I took one of those Futaba plastic servo boxes, wrap it the foil and installed it like a shelter, as a "C", right before the receiver. Also, I grounded it with a screw to the engine block. g It worked. Before I did that, if I moved 30 feet from the plane with the engine on, all controls were moving around. After applying this technique, I have no glitches whatsoever, after 40 + flights. If you need, I can take some pictures of what I did and post it here. Let me know. Flavio
