FSOneDev
Joined: 10/10/2006 From: Urbana, IL, USA Status: offline
quote:
ORIGINAL: sctholson So, I've got a question for you guys; does anyone fly 3d airplanes? and if so, has anyone flown the Tirbute 3D. I'm curious if it does harriers, and hovers. I've been playing around with this plane and I know I'm not a 3d pilot (although I've flown rc planes many years ago), but I can't seem to hold a slow flight steady. I'm sure it is just my skill level, but it would reassure me if someone else could verify that this plane in FSOne actually does 3d in it's stock configuration. Thanks Scott H Scott -- The Tribute is a 3D airplane in it's stock form. If you are new to 3D you may want to try the following to help with your learning: Go to the Aircraft Selection Menu. Use the combo box on the right to select "Scaled: All Airplanes". Then select "Scaled Tribute 12 ft span". This oversized Tribute is not only quite a bit of fun to fly, but it's slower response is helpful in learning 3D maneuvers and hovering. Give it a try. I had a visitor to the 2006 Toledo show try this approach at the show with great success. He even came back to the booth a second time with his girl friend, saying "this is the sim that taught me how to hover".
_____________________________
Brian InertiaSoft, Inc.
