RE: FS One by Hangar 9
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> RC Flight Simulator Software >> RE: FS One by Hangar 9
Page: <<   < prev  58 59 60 61 [62] 63 64 65 66 67   next >   >>
Login
RE: FS One by Hangar 9 - 3/14/2008 12:45:18 AM
sctholson
Status: offline
Neko,
Does your DX7 radio fly anything well?
Are you aware of the inertiasoft's support page:
http://www.inertiasoft.com/fsonefaq/index.html
There you will find a few radio set up instructions. It doesn't seem that they have a DX7 radio setup, but I can't imagine the basic set up is all that different.
The location of different buttons is anyone's guess and the Takeoff mode, sorry I have no idea.
The more you read up on the FAQ's the more you'll find that FSOne is a very robust program, even if it is a bit difficult to figure out.
Best of luck to you,
By the way are you flying FSOne for Heli's or Airplanes?
Scott H
quote:
ORIGINAL: Neko
Started using FSOne after several months of RF 3.5 and have a few questions.
It seems much harder to fly. Is that because of better physics? Or maybe I need to set up my DX7 better (I don't have the standard controller).
Setting up my Tx took 4 phone calls to Horizon. It's there transmitter! You'd think there would be a document or help file on setting it up.
Why in some windows are the OK buttons in the top right (Edit Transmitter), and some on the bottom left (Transmitter)? Not good bad interface practice. And why does the OK button not link to the Return key, which is standard Win and Mac interface?
What is "Takeoff Mode", which shows on the screen while flying? Not in the manual that I can find.
It is a pretty remarkable piece of software though. The number of features and options and edits is overwhelming.
(in reply to Neko)
       Post #: 1526
RE: FS One by Hangar 9 - 3/15/2008 3:36:25 AM
Neko
Status: offline
Thanks guys. I'll take a look at the FAQ and keep plugging. I'm a programmer myself, so I appreciate the flexibility of the program, but I wish now I had gotten their controller. Would have made things simpler.
(in reply to sctholson)
       Post #: 1527
RE: FS One by Hangar 9 - 3/15/2008 4:06:48 AM
sctholson
Status: offline
Neko,
If your a programmer, that you should have no problem interpreting the FAQ's. I wonder if you can buy a transmitter from Horizon?
I know my dad has the transmitter version and he likes it as he can always leave it hooked up, stays with the computer at all times and never needs a charge.
Scott H
(in reply to Neko)
       Post #: 1528
RE: FS One by Hangar 9 - 3/15/2008 4:39:55 AM
CloudSkipper
Status: offline
Depending on what transmitter you're using, some of the model setups can be confusing if you're starting out with the no-transmitter version. I have Hitec Prism 7x myself. Gears, flaps and the rotary knob (for Heli's) have given me some head scratching (but fixed eventually). The mode switches as well don't work 100% the same in the sim... for flight modes, I sometimes reassign those to the keyboard (assign to "single value" and "key down" )
Again, this is a good example of why to get the transmitter version of FS One... You can start flying right away with ALL the aircraft and deal with interfacing your real TX later.
Should be noted though that for just the basic aileron/rudder/elevator planes, setup should not be a problem with any TX... just assign the correct "axis" for the channels and reverse channels that need reversing and you're done. And of course make sure the trims, expos, etc are ALL reset on the TX first, because FS One handles all those internally.
It can be rather confusing at first, but it's all very logical and organized once you take a calm look at things. There are necessarily A LOT of settings and that can be only so user friendly. Better instructions (or a TX startup guide) would help. I hope they are working on those.
< Message edited by CloudSkipper -- 3/15/2008 4:42:49 AM >
       Post #: 1529
RE: FS One by Hangar 9 - 3/17/2008 11:28:41 PM
iamman711
Status: offline
the fs-one is better than realflight?
< Message edited by iamman711 -- 3/17/2008 11:38:52 PM >
(in reply to CloudSkipper)
       Post #: 1530
RE: FS One by Hangar 9 - 3/17/2008 11:30:08 PM
iamman711
Status: offline
i think its almost same thing.
< Message edited by iamman711 -- 3/17/2008 11:39:11 PM >
(in reply to iamman711)
       Post #: 1531
RE: FS One by Hangar 9 - 3/20/2008 5:20:32 PM
JPEE
Status: online
To IAMMAN,
Could not help but to catch your opinion on the FS and G4 sims. I have been doing my homework trying to determine which one to purchase by reading all of the old guys opinions as I am a newbee. I am flying a CX-2 helio and want to grad to a e-flite 400 helio. I would like a good sim that would mimic those copters. I just got off the phone with Horizon back east and the FS has the cp and cx in their "basic" package. The G 4 requires you to buy their additional pack for a 29.00 to get a cx2 helio. Neither offers the e-flite 400. Sorry for being verbose, but I want the best sim as a priority and then the software which as you can see I might have to buy their add ons. With that all said, after reading your opinions it appears you like the FS?
Any help you can offer would be greatly appreciated!
_____________________________
CX 2, Hirobo SRB Quark
Blade 400s, #401, #402, Trojan T-28
       Post #: 1532
RE: FS One by Hangar 9 - 3/20/2008 7:09:07 PM
Skarn
Status: offline
JPEE,
The Blade CP and CX models in FSONe fly nothing like the real thing....I have both the real ones and FSOne.
If you want to get a larger heli like the B400, you might want to consider Phoenix. I personally have not tried it, but just about every thread I've researched asking which is the best heli sim recommends Phoenix.
Good luck!
Skarn
(in reply to JPEE)
       Post #: 1533
RE: FS One by Hangar 9 - 3/20/2008 8:13:43 PM
iamman711
Status: offline
I think both are way overpriced. its like Vonage. it should be free. Voice over IP, that is. That's why I like FMS flight model simulator which is free you can use your own Tx.
if you look at software at electronics stores, prices of games/software (and hardware) depreciates much more rapidly. But because flight sim software is part RC hobby, depreciation of the software and hardware technology for that matter virtually never depreciates. its insane. but what can you do?
< Message edited by iamman711 -- 3/20/2008 8:15:27 PM >
(in reply to Skarn)
       Post #: 1534
RE: FS One by Hangar 9 - 3/20/2008 9:08:56 PM
JPEE
Status: online
Iamman,
I got a bit confused regarding the TX. It sounds as if you said the FS is the way to go as you can use your own existing TX. However, if I only have the TX controller for the CX 2 which is greatly different than the Spektrum’s DX6i 2.4GHz DSM2 that come with the larger E-Flite's then hows that work? I "thought" that all of the sims came with the Spektrum’s DX6i 2.4GHz DSM2 LIKE like the E-Fite 400 does?
Thank both of you for replying.
       Post #: 1535
RE: FS One by Hangar 9 - 3/20/2008 9:29:36 PM
iamman711
Status: offline
Hey JPEE,
Actually, both FS-One and Realflight let you use your own transmitter but most likely you just need to have their USB-adapter (used for copyright protection) hooked up to your computer.
I was referring to FMS (flight model simulator) which is free, and also lets you use your own transmitter but since the software is freeware, there is no copyright. google "FMS" and you will be able to download it for free.
"However, if I only have the TX controller for the CX 2 which is greatly different than the Spektrum’s DX6i 2.4GHz DSM2 that come with the larger E-Flite's then hows that work? I "thought" that all of the sims came with the Spektrum’s DX6i 2.4GHz DSM2 LIKE like the E-Fite 400 does? "
Your CX-2 controller should work. FS-One and Realflight should have adapter cables to let you hook up your CX-2 Controller to your computer and fly on the sims. or if not, they both sell them separately. If I didn't answer your question, please post again and I or someone else will try to help.
You should check out the reviews of both simulator software before you decide to take the plunge. HEREis one such review.
Edit: I can't post the link because its against forum rules but I tell you what... Search for this exact phrase "G3 vs FSone vs G3.5 (FSone comparison review)" and you should get to a review and its on RCuniverse.com too
< Message edited by iamman711 -- 3/20/2008 9:32:58 PM >
(in reply to JPEE)
       Post #: 1536
RE: FS One by Hangar 9 - 3/20/2008 11:12:07 PM
adwb
Status: offline
I wonder if anyone cna answer 2 questions for me,
Has anyody any comment on the realism of the Hanger9 Corsair in FSone compaired to the real H9 Corsair model?
Second question; if you look at my laptops graphics specs below will FSone run on this laptop?
Intel(R) Graphics Media Accelerator Driver for Mobile Report
Report Date: 03/20/2008
Report Time[hr:mm:ss]: 21:49:33
Driver Version: 6.14.10.4764
Operating System: Windows XP* Home Edition, Service Pack 2 (5.1.2600)
Default Language: English
DirectX* Version: 9.0
Physical Memory: 758 MB
Minimum Graphics Memory: 8 MB
Maximum Graphics Memory: 128 MB
Graphics Memory in Use: 10 MB
Processor: x86 family 6 Model 13 Stepping 8
Processor Speed: 1729 MHZ
Vendor ID: 8086
Device ID: 2592
Device Revision: 03
* Accelerator Information *
Accelerator in Use: Mobile Intel(R) 915GM/GMS,910GML Express Chipset Family
Video BIOS: 1222
Current Graphics Mode: 1280 by 800 True Color (60 Hz)
* Devices Connected to the Graphics Accelerator *
Active Notebook Displays: 1
* Notebook *
Monitor Name: Plug and Play Monitor
Display Type: Digital
Gamma Value: 2.20
DDC2 Protocol: Supported
Maximum Image Size: Horizontal: Not Available
Vertical: Not Available
Monitor Supported Modes:
1280 by 800 (60 Hz)
Display Power Management Support:
Standby Mode: Not Supported
Supercub [Slightly Modified],Raptor 30 Heli Converted to EP;Hanger9 Corsair converted to EP, ParkzoneTyphoon3d
       Post #: 1537
RE: FS One by Hangar 9 - 3/20/2008 11:59:30 PM
CloudSkipper
Status: offline
I used to run FSOne on a low end GFX initially... ATI 9250.
I would guess that generally you'll need to put the 3D scenery details and quality to medium for your integrated GFX (edit: or actually even a bit lower than medium). But the lower setting won't necessarily have a huge impact and the 3D scenery is not mind blowing anyway.
With that GFX, your best bet is the photo panorama scenery, which you could get away with 100% quality with... if not, then just under max settings. Panorama is markedly less taxing on the GFX (and CPU)... I know that from GPU and CPU load and temperature monitor logs.
And with the airplane
