RE: SPORTWERKS chaos 1/16 buggy
Tower Hobbies
Logged in as Guest
Users viewing this topic: vicdat
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> 1/16th, 1/18th, Mini & Micro RC Cars >> RE: SPORTWERKS chaos 1/16 buggy Page: <<   < prev  26 27 [28] 29 30 31 32 33 34 35   next >   >>
Login
RE: SPORTWERKS chaos 1/16 buggy - 3/28/2008 7:20:58 PM
t9dragon
Status: offline
quote:
ORIGINAL: maxxin2.5
also i am havng toubles with the directions yuou gave me i dont get half the stuff you said...and what do you with with epoxy??
"Take the center diff apart and filled it full of epoxy to make it a locked diff."
(in reply to maxxin2.5)
       Post #: 676
RE: SPORTWERKS chaos 1/16 buggy - 3/28/2008 7:28:27 PM
maxxin2.5
Status: offline
ok thanks...is that the only thing neede to be filled??
_____________________________
13 going on 14...haha
if you arent breaking anything then you arent having enough fun!
(in reply to t9dragon)
       Post #: 677
RE: SPORTWERKS chaos 1/16 buggy - 3/28/2008 9:00:14 PM
sballroundplaya1
Status: offline
yea should we be filling the front and rear differentials with anything?
       Post #: 678
RE: SPORTWERKS chaos 1/16 buggy - 3/28/2008 9:55:43 PM
t9dragon
Status: offline
I would add either diff lube of diff grease to the front and rear diffs...................
(in reply to sballroundplaya1)
       Post #: 679
RE: SPORTWERKS chaos 1/16 buggy - 3/28/2008 10:17:00 PM
sballroundplaya1
Status: offline
is there any major difference between the lube or grease?
       Post #: 680
RE: SPORTWERKS chaos 1/16 buggy - 3/28/2008 10:30:24 PM
sballroundplaya1
Status: offline
quote:
ORIGINAL: t9dragon
quote:
ORIGINAL: maxxin2.5
what epoxy did u use? brand name and type would be helpful, thank you
       Post #: 681
RE: SPORTWERKS chaos 1/16 buggy - 3/28/2008 10:47:38 PM
t9dragon
Status: offline
quote:
ORIGINAL: sballroundplaya1
If you get the AE diff grease it is around $3.00, the diff lubes are around $10.
I'm not sure what epoxy he used.
       Post #: 682
RE: SPORTWERKS chaos 1/16 buggy - 3/28/2008 11:55:14 PM
twin3d
Status: offline
The center diff is the only one that gets filled with epoxy. I used 5 minute epoxy. The center front drive line is removed and the two front drive lines are removed. These are not put back in, this makes it a two wheel drive car. I left the brake off( never use it any way). Hope this helps. Sorry I did not get back to you guys sooner.
       Post #: 683
RE: SPORTWERKS chaos 1/16 buggy - 3/28/2008 11:57:05 PM
maxxin2.5
Status: offline
ohh i want mine 4wd so i can still drive it in dirt and have no problem...
or well did you have problem??
(in reply to twin3d)
       Post #: 684
RE: SPORTWERKS chaos 1/16 buggy - 3/29/2008 12:07:29 AM
sballroundplaya1
Status: offline
yea same, i prefer 4wd. but i plan on using mine more on road than off road but there still may be times where i want to go a little bit offroading. would 2wd be ok for this since i will be off road sparingly? or should i stick with 4wd to be safe. like maxxin said, are they any problems with ur method going off road?
       Post #: 685
RE: SPORTWERKS chaos 1/16 buggy - 3/29/2008 12:15:01 AM
maxxin2.5
Status: offline
maybe we can just pu them back in so its 4wd again and see what happens...and i am definately not taking out the brake...even if it does just a little ill get it to work better i also have some friends acrosss hte street that are like experts and they have made my 4 year old brakes on my t maxx soo good it does frontflips when i hit the brakes...soo i am definatley keeping those in...
so playa1 you should try and just exopy it them put the drive lines back in so its 4wd and maybe its still going to be an awsome car!!
never know till you try!!
       Post #: 686
RE: SPORTWERKS chaos 1/16 buggy - 3/29/2008 12:16:03 AM
maxxin2.5
Status: offline
also i started a new thread about the picco engines and i wanted to know if anyone has on yet???
plz tell me
thanks
       Post #: 687
RE: SPORTWERKS chaos 1/16 buggy - 3/29/2008 12:31:01 AM
sballroundplaya1
Status: offline
yea hopefully ill pick up some epoxy tomorrow and give it a shot. i wont be able to drive it tho for another week until i get my servos i ordered form hong kong but ill def keep everyone updated
       Post #: 688
RE: SPORTWERKS chaos 1/16 buggy - 3/29/2008 12:37:47 AM
maxxin2.5
Status: offline
ok kool thanks...i want some new wheels/tires but i cant find the kyosho ones anywhere...and i would rather have onroad tires...
anyone know where to find onroad wheels/tires???
i dont want slicks either...
       Post #: 689
RE: SPORTWERKS chaos 1/16 buggy - 3/29/2008 2:52:03 AM
twin3d
