RE: SPORTWERKS chaos 1/16 buggy
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> 1/16th, 1/18th, Mini & Micro RC Cars >> RE: SPORTWERKS chaos 1/16 buggy
Page: <<   < prev  29 30 [31] 32 33 34 35 36 37 38   next >   >>
Login
RE: SPORTWERKS chaos 1/16 buggy - 4/7/2008 6:07:44 PM
zazzster
Status: offline
Yeh, but the KMI 09 still uses gears. The Xray seems to be the onle nitro mini that comes stock with ball diffs. So for now I live with my shoulda' woulda' coulda' and I'm useing the front diff in the rear(2wd). Still fun on the tarmac...
Go ball diffs............
(in reply to maxxin2.5)
       Post #: 751
RE: SPORTWERKS chaos 1/16 buggy - 4/9/2008 6:41:36 PM
E.Keller
Status: offline
Hey Guys,
Just joined. so, instead of reading all of the great stuff you guys have wrote. now i can join in the fun! Had my Chaos for a few weeks now and havin a lot of fun! But,also having the same problems too. some of my "mods" are......
1. steering servo. changed to a Futaba S3107 (fit like a glove)
2. flip top fuel door. A Choas option.
3. switch harness. So i can charge without pulling out the batts.
4. 1000 mAh AAA's. these things are great! Wall Mart for about 7 or 8 bucks.
       Post #: 752
RE: SPORTWERKS chaos 1/16 buggy - 4/21/2008 6:43:31 AM
magnum12
Status: offline
has anyone figured out what to do with the diffs any steel ones that work thanks
< Message edited by magnum12 -- 4/25/2008 6:41:00 AM >
       Post #: 753
RE: SPORTWERKS chaos 1/16 buggy - 4/29/2008 4:09:27 PM
vicdat
Status: offline
I'm also interested in better gears for my Chaos...My partner just picked-up a new one here in SoCal (they range from $60-$90 if you look hard enough), anyway before he even fired it up he went to Rob's Hobby in Garden Grove and got just about every hop-up part on the shelf, and they are a Sportswerk Dealer with good inventory also new Hitech steel gear servos, and will intall a new FAST receiver. Sounds like a lot of money just to break a crapload plastic gears!
Last night I rebuilt all my diffs and packed them with silicon grease. I noticed that from the factory the grease was pretty much non-existent. They seem a little stiff. Does anyone know if they will loosen-up after I run it a few times? Also I recently noticed a lot of slop around the clutch so I installed a new roller bearing I only had larger shims for my Picco so I put two in inside of the bell. It seemed to work OK...any thoughts?
(in reply to magnum12)
       Post #: 754
RE: SPORTWERKS chaos 1/16 buggy - 5/1/2008 12:47:25 AM
zazzster
Status: offline
I put mine on the shelf. The dog bone hubs are stripped and need to be replace and epoxied on. I did make some shims to tighten up the mesh between the bevel and spur gear. I have enough experience to know that the Chaos is not going to cut it. So I'm going to repair it and sell/give it to a friend. Since no metal drive upgrades are available, I see no sense in throwing more money away. Good luck with your Chaos...
(in reply to vicdat)
       Post #: 755
RE: SPORTWERKS chaos 1/16 buggy - 5/1/2008 1:00:34 AM
cmerritt
Status: offline
quote:
ORIGINAL: zazzster
yup me too. my chaos is on the shelf in my work area. it runs fine, i just got bored of it. i converted it to 2wd and lost interest. i'll prolly end up giving it to someone also since they're not worth anything haha
_____________________________
"It''s funny ''till someone gets hurt... then it''s HILARIOUS!"
(in reply to zazzster)
       Post #: 756
RE: SPORTWERKS chaos 1/16 buggy - 5/2/2008 10:28:32 PM
chaos_is_junk
Status: offline
i got mine from rob's rc also.......the day i got it problems !!!!!! the radio was bad in the three they had in stock ......so i sent it back to horizon hobby them people really did there best to help me out....... i sent in the tires with flat spots and the radio they shipped me a new one ......still the same crap radio would not work farther than two feet and went threw three axle cups for the rear both sides in 20 minutes it only has front wheel drive now.....i will never buy sportworks any thing ever again..... fedex sent it today.... three hours after the drop it's broke again .......three tanks three months ago now same crap really upset at this paperweight
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by chaos_is_junk -- 5/2/2008 10:31:23 PM >
       Post #: 757
RE: SPORTWERKS chaos 1/16 buggy - 5/3/2008 6:38:54 AM
zazzster
Status: offline
Yeh, you get what you pay for....
As for the radio problems. Sounds like my X-Mod...LOL
(Make sure the TX & RX crystals are seated securely & all battery voltages are at proper) I've made the voltage mistake more times then I care to mention. HEY WHERE IS MY CAR GOING????
Back to the Chaos...........
Keep it real! If you really want to make the Chaos BOSE, you just need some time and money. I don't mean over the counter or ebay chaos stuff. I mean putting parts from a better mini onto the chaos chassis(& a new power plant). Seem like a waist? Depends on how you view it. Is it cost effective to build a bad azs chaos? NO! Is it cool? I think so since no one on this forum has done so. That is, as far as I know.
I once put a Kyosho Rampage drive train onto an RC10T graphite chassis(with all tie-stuff). It still couldn't touch a stock RC10 T .12 nitro. It was the stock Kyosho .12 engine, I swear!!!
What all my babbling is leading up to is that, before you spend another dollar on the Chaos, consider the Xray. No, I don't own one yet. Next winter... Time to play with the big toys...
If someone following this thread has upgraded to a new mini nitro your 2,3 or 4 cents would be appreciated.
B.
(in reply to chaos_is_junk)
       Post #: 758
RE: SPORTWERKS chaos 1/16 buggy - 5/7/2008 9:34:11 PM
rabies73
Status: offline
I have a friend that machines small RC gears. He is looking at my chaos diffs. I will let everyone know. I promised him alot of business!!!
       Post #: 759
RE: SPORTWERKS chaos 1/16 buggy - 5/12/2008 3:05:13 PM
NOVA454
Status: offline
Does anyone have info/pictures of the throttle linkage hook-up on the Chaos when converting from rotory to slide carb (Installing the Picco P-Zero)
(in reply to Tigger N. Bennie)
       Post #: 760
RE: SPORTWERKS chaos 1/16 buggy - 5/13/2008 3:25:43 AM
rally drift
Status: offline
Has anyone found a different body?
lol
(in reply to NOVA454)
       Post #: 761
RE: SPORTWERKS chaos 1/16 buggy - 5/20/2008 6:42:58 PM
magnum12
Status: offline
quote:
ORIGINAL: rabies73
let us know i and a few friends would pay for them .
(in reply to rabies73)
       Post #: 762
RE: SPORTWERKS chaos 1/16 buggy - 5/22/2008 4:13:06 AM
Lestrange04
Status: offline
Hello ppl, after purchasing 3 Chaos, and then reading these forums I got a little worried that my kids (6, 8, 10) wouldnt be able to play with them as much as I would like them to. Ya know, around the house and at the track. Well, they have each had theirs for over 6 months and we can goto the track on a weekend and put 2 gallons through the 3 of them and they run like a champ. Yes I keep it rich, but after running a couple tanks, we let them cool off because the heat spreading around the bottom plate REALLY heats up the diff cases. I have not modified their buggies in ANY way except for shortening the fuel line and recycle line. I have their steering response set at 1/2. There have been a few big jumps but landed out ok, but I have NEVER had to replace ANY part (stearing servos/throttle servos as well) other than tires and triple A's. This buggy is a great RC for the beginner. I hope they will last for at least a year because i told em once they can master steering and throttle response without using much brake, then we will move em up to the 1/10 nitros. That is just my 2 cents. Ive been holding off posting until I knew what they were and what they were able to put up with.
< Message edited by Lestrange04 -- 5/22/2008 4:14:31 AM >
       Post #: 763
RE: SPORTWERKS chaos 1/16 buggy - 5/27/2008 6:38:41 PM
cansoykal
Status: offline
