RE: kyosho inferno gt ready sey
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC On Road Nitro Cars >> RE: kyosho inferno gt ready sey
Page: <<   < prev  15 16 17 18 19 20 [21] 22 23 24   next >   >>
Login
RE: kyosho inferno gt ready sey - 4/20/2008 1:15:09 PM
jspeed
Status: offline
Here's some images & results from last week's Kyosho US Open Championships at Kraceway in Florida.
Here's the A Main Final results.
2008 Kyosho U.S. Open Sedan Championships
Position Driver Name Car Laps Race Time
 1 Danny Sawyer 1 20 10:18.316
 2 Paul Roberts 2 19 10:00.072
 3 Jeff Vargas 13 19 10:21.181
 4 Jeff Epperson 5 19 10:24.865
 5 Ronnie Setser 12 19 10:27.006
 6 Rich Casteline 3 19 10:27.163
 7 Frank Poruba 9 18 10:09.565
 8 Tony Cabral 8 18 10:12.353
 9 Alejandro Villada 6 18 10:21.474
 10 Todd Forcione 7 17 10:18.929
 11 Gary Strainer 11 11 7:18.976
 12 Brian Bosley 4 0 0.000
 13 David Larry 10 0 0.000
Here's what I won!
A nice 3rd place throphy & a brand new Subaru IGT!
I wish to thank Kyosho America, Kraceway, Werks Racing & Maxy for making it all possible to race our IGT cars at this event.
It was a lot of fun racing the IGT cars on the big track.
All of you guys & girls out there with Kyosho Inferno GT cars should try getting a racing program going at your local tracks it's a blast!
< Message edited by jspeed -- 4/20/2008 1:27:26 PM >
(in reply to maoy)
       Post #: 501
RE: kyosho inferno gt ready sey - 4/21/2008 6:12:22 AM
maoy
Status: offline
Hey, I noticed that all pinions above 23t are 16mm diameter. I wanted to convert my IGT to centax clutch just to use those pinion gears. But, apparently my LST2 clutch bell comes with a 12mm and 16mm slot. I wanted to know if anybody here has tried the lst2 clutch bell with 16mm pinions? If so, what modifications are needed? Pictures would be good. Thanks.
(in reply to jspeed)
       Post #: 502
RE: kyosho inferno gt ready sey - 4/21/2008 7:03:45 AM
joizeex
Status: offline
jspeed, you're the shiznit, congrats! what kind of tires did you run in that race?
_____________________________
Kyosho: FW05-T WRC Evo6, TR-15 StadiumForce, InfernoGT WRC Sti, Seawind; Heli: HoneyBeeKing; HiroboEvo50; 1:1 Mitsubishi Evo
(in reply to maoy)
       Post #: 503
RE: kyosho inferno gt ready sey - 4/21/2008 1:46:19 PM
jspeed
Status: offline
quote:
ORIGINAL: joizeex
Thanks, but I just got lucky starting at the last position in the Final.
The track was wet because of the Florida rain storm, so I used the "Twister/ATS" tires. They have threads, so I thought they would be better for the race than using the v-slicks.
After the race was over, Joel Johnson of Kyosho America told me the the actual winner was running v-slicks for the Main, go figure....
i guess in the end, good drivers adjust to changes in the enviroment & equipment available to them.
(in reply to joizeex)
       Post #: 504
RE: kyosho inferno gt ready sey - 4/22/2008 12:21:49 AM
biggin69
Status: offline
What tires is everyone running? I am looking for something premounted to be use on a local track.
(in reply to BILL9)
       Post #: 505
RE: kyosho inferno gt ready sey - 4/22/2008 5:09:28 AM
maoy
Status: offline
Hey, I have a question regarding Peak Racing Diablo .28 engine. Somebody offered me a new one for $100. Is is worth it or should I get the LRP .28 Spec 3? The link below shows the torque of each engine at different RPM. I have 2 diablo engines so far, Diablo .18 and Diablo .15. Both are very reliable and the .18 has tons of power. I want to know if the Diablo .28 will provide more power than my current Sportwerks .26. Or is it better to just get a LRP .28? Please let me know, thanks.
URL:
http://hpisavageforum.com/forums/showthread.php?t=1419
(in reply to biggin69)
       Post #: 506
RE: kyosho inferno gt ready sey - 5/7/2008 3:41:05 PM
PatrickBW
Status: offline
Hey, I've been scouring the thread - I think I may have already posted in it before, but once again, I'm thinking of getting an IGT.. I see - again - people saying you have to convert to single speed.., which I find a bit of a turn-off.. Is it really still an absolute MUST?? I'd probably get the Aston version.. I assume they haven't improved anything in the last year or so??..
Right now I think it'd be between a new IGT, or a used Serpent or Evolva or Mugen or something.. There's a great onroad track near me, and I just want something bigger and faster than my Kyosho FW-05T to mess around with.. No real racing.. Also, here in Germany Kyosho seems easier to get parts for..
Anyway, I read somewhere in the thread about having to invest a lot of money in the IGT.. What exactly was meant by that??
If someone would be so kind.., could you give me a run-down list of any "musts" for getting started with an IGT? Much appreciated...
Thanks..
(in reply to maoy)
       Post #: 507
RE: kyosho inferno gt ready sey - 5/7/2008 8:13:35 PM
maoy
Status: offline
Yea, this is what will cost you money:
New tires & wheels: $60
New brake pads & brake disc = $50
New radio system (old one lacks distance and gets glitchy) = $100 - $300 depending on what you want
stabilizer rods (front & rear) = $30
new shock springs, shock oil, and drivetrain oil = $40
That should be good enough. The stock shock springs are stiff and is very good for parking lot bashing. If you want to go track racing, then you definitely should change it to something softer like the blue springs.
The stock motor and gears should get you up close to 50 mph. The stock motor has tons of bottom end torque but lacks serious rpms.
You don't have to go single speed. Single speed is only if you want to hit super high speed. I personally run a sportwerks .26 engine with second gear as HPI 23t pinion x Stock Kyosho 43t spur. My car is seriously fast. Right now, my tires are worn out and the car would do about 10-15 feet sideways before going straight. Too fast, engine revs up and tears the tires apart. I can do about 70+ mph. The guys with single speed can do close to about 80 mph. The car is extremely fast. You should talk to people at the track before buying an IGT though. Maybe they might suggest something else. The IGT is just great for me.
The flaw for the IGT is the shift spot for gear 2 would wear out easily. Some guy is selling a custom created second gear on ebay that will last 4ever. I will post the link later on.
(in reply to PatrickBW)
       Post #: 508
RE: kyosho inferno gt ready sey - 5/7/2008 8:20:58 PM
biggin69
Status: offline
Where can I find different shock springs for the IGT?
(in reply to maoy)
       Post #: 509
RE: kyosho inferno gt ready sey - 5/7/2008 8:21:28 PM
PatrickBW
Status: offline
Thanks.. After looking and asking around a bit, I think the IGT is the right deal for me.. For starters I think I'll just get some new foam tires.. Radio I have...
A German dude here said something abot the pins in the tranny going bad every gallon and a half or so, so to have those on hand..
I have a practically new Mach 427 just sitting there, so maybe I'd sell the Kyosho engine new for 50 bucks, and recoup some dough.. I'm a big Mach fan anyway..
Now when I go on ebay and look up foam tires ("moosgummi" here in German..), are they all the same, or are there different hex sizes etc..?? Would I also run those big fat wide rear tires I see on the high end race cars??
If you don't mind, a link to some stabi rods would be great too.. But I'll check the bay right now.. Thanks again for your help..
(in reply to maoy)
       Post #: 510
RE: kyosho inferno gt ready sey - 5/7/2008 10:28:11 PM
FifthScaleRacer
Status: offline
The Coolest RC Action Pics: http://www.RobsPics.com
       Post #: 511
RE: kyosho inferno gt ready sey - 5/8/2008 5:08:47 AM
maoy
Status: offline
biggin69, just go to google and type it in. I am using the blue ones from Sportwerks but it is bad because it raises the car all the way since it is so long. I know Kyosho makes specific ones for the Inferno GT so try to find it on google. I believe they are $10-$15 each. You can get the sportwerks Mayhem version for $5 each and just cut it to make it shorter. My suggestion is really to get the ones from Kyosho for the IGT. It is more but it should be good.
(in reply to FifthScaleRacer)
       Post #: 512
RE: kyosho inferno gt ready sey - 5/8/2008 12:41:22 PM
TommyGun24
Status: offline
No, its not essential to convert to a single speed. I dont blame you for thinking its a turn off, I love 2 speed too, just not the IGT 2 speed
Theres a good variety of choices in how to fix it or change it. Most are easy and relatively inexpensive.
It depends what you want to do with your car ofcourse, the IGT is fun and has lots of bonuses, but it needs work, and if your considering one of those 1/8 tourers you mentioned you need to know that there is no comparison in quality between the 2. Everything about the touring cars is far superior.
But again if your looking for street racing and versatility then thats the IGT's strength.
< Message edited by TommyGun24 -- 5/8/2008 12:44:11 PM >
(in reply to maoy)
       Post #: 513
RE: kyosho inferno gt ready sey - 5/9/2008 12:56:24 PM
jspeed
