Why Methanol?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
90 Dgree Muffler Adapters
Seller:  RC Specialties
Details:   $19.95   |  6/6/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> Why Methanol?
Page: [1] 2 3   next >   >>
Login
Why Methanol? - 5/2/2006 1:19 AM
TestPilot6
Score: 100
Last Login: 11/8/2011
Status: offline
Does anyone know what we got to use methanol for the glow engines? What about other fuels that have more energy, like hexane?
Hide Signatures
       Post #: 1
RE: Why Methanol? - 5/2/2006 2:08 AM
TestPilot6
Score: 100
Status: offline
I meant "how and why", not "what".
Hide Signatures
(in reply to TestPilot6)
       Post #: 2
RE: Why Methanol? - 5/2/2006 2:37 AM
joesabido
Score: 100
Last Login: 12/20/2009
Status: offline
Well,
1.- I don't know about the prices of Hexane, but methanol is cheap (nitromethane is what makes glow fuel "expensive")
2.- Methanol is more enviromental friendly since it's produced by the direct combination of hydrogen and carbon monoxide gases, heated under pressure in the presence of a catalyst or by combining natural gas and steam and then forcing the mixture through a series of heated catalytic chambers, contrary to Hexane (as an example) since hexane is produced by refining crude oil.
3.- Castor oil (another natural product used for lubrication in glow fuel) is soluble in Methanol.
4.- Methanol is VERY volatile, which helps combustion AND helps cooling the engines.
5.- Methanol acts as a catalyst to maintain the glow plug coil hot.
I'm sure there are other reasons, but hope that helps
_____________________________
Time is the fuel of idle hands
Hide Signatures
       Post #: 3
RE: Why Methanol? - 5/2/2006 3:06 AM
pilotpete2
Score: 120
Last Login: 6/19/2013
Status: offline
Joe,
You got it covered, especially item 5.
As a computer guy, and a glow flyer, I love your avatar
Regards,
pete
"If the woman don''''''''t find you handsome, they should at least find you handy"
Hide Signatures
(in reply to joesabido)
       Post #: 4
RE: Why Methanol? - 5/2/2006 3:22 AM
joesabido
Score: 100
Status: offline
Thanks Pete, would you like one?
Hide Signatures
(in reply to pilotpete2)
       Post #: 5
RE: Why Methanol? - 5/2/2006 3:31 AM
pilotpete2
Score: 120
Status: offline
Joe,
Thanks for the offer, but I gotta come up with a good one of my own
Best regards,
pete
Hide Signatures
       Post #: 6
RE: Why Methanol? - 5/2/2006 3:36 AM
Jim Thomerson
Score: 160
Status: offline
Two groups who, in the old days, experimented with weird fuels are the control line speed fliers and the control line team race fliers. The speed fliers were going after maximum speed and used several now banned ingredients. I think they now have a defined fuel formula in most events. The team racers, in the 50's and 60's, were interested in both speed and economy and tried a wide range of fuel components. There is a revival of interest in "B team race" but I think fuel may be specified. The international team race class is all 2.5 cc diesels which run over 100 MPH and use almost no fuel to do so for lap after lap.
Anyway, given all that, here we are today flying methanol based glow fuels.
Hide Signatures
       Post #: 7
RE: Why Methanol? - 5/2/2006 3:43 AM
TestPilot6
Score: 100
Status: offline
Thank you, joe. Those make sense. And thank you, jim for the historical background.
Hide Signatures
       Post #: 8
RE: Why Methanol? - 5/2/2006 6:22 AM
B.L.E.
Score: 100
Last Login: 4/14/2010
Status: offline
Actually, hexane and it's cousins (decane, nonane, octane, heptane, etc.) will also react with the platinum catylist in the glow plug. Coleman lantern fuel, which consists mostly of alkanes, works just fine in camp heaters that use a platinum catylist to burn the fuel.
Here is what I feel is the real reason glow ignition and methanol go so well together. When used in spark ignition engines, methanol makes nearly full power even when the mixture is silly rich, not so with gasoline. This is important because it lets us use the fuel/air mixture to control the ignition timing of the engine. The dramatic power dropoff when we richen the mixture of a glow engine comes from the retarded ignition timing of a rich mixture. Those of us who have played with different head shims have noticed that when we raise or lower the compression of a glow engine, the engine wants a different air/fuel mixture for optimum power.
Well, that's my theory. If someone has a more plausible theory, I'm all ears.
Hide Signatures
       Post #: 9
RE: Why Methanol? - 5/2/2006 7:06 AM
loughbd
Score: 100
Last Login: 10/28/2006
Status: offline
Coleman fuel is naptha and will not work in a glow engine. Same as lighter fluid. Works fine in an ignition engine. Methane is the fuel of choice because it's cheap and reacts with the platinum of the glow plug. Ethane will work buyt much less power. The other alkanes won't work in a glow engine.
I flew Speed in the 60's and the only oddball thing added was nitro benzene. Smelled like shoe polish and turned out to be carcinogenic. We did add propylene oxide when using more that 60% nitromethane to get the fuel to mix.
< Message edited by loughbd -- 5/2/2006 7:22 PM >
Hide Signatures
(in reply to B.L.E.)
       Post #: 10
RE: Why Methanol? - 5/2/2006 10:58 AM
Kweasel
Score: 100
Last Login: 6/10/2013
Status: offline
In all my fuel testing methanol works best with an unheated glow plug. It also offers more power and a broader needle valve than other inexpensive chemicals that I have found. Camp fuel mixed with Coolpower makes good power, idles well, and gives incredible fuel economy but requires glow heat for reliability.
Hide Signatures
       Post #: 11
RE: Why Methanol? - 5/2/2006 2:27 PM
Rupurt
Score: 100
Last Login: 8/24/2011
Status: offline
Hexane is an excellent degreaser better than methanol so you would need more oil, also running hexane will make the needle very sensitive because the mixture will be more lean than with methanol. Another reason why you would need more oil. I think using the exhaust to pressurize the tank would be a big no no.
I think methanol is just the best comprimise and just about any fuel could be made to work.
Somethings are stranger than fishin
Hide Signatures
(in reply to Kweasel)
       Post #: 12
RE: Why Methanol? - 5/2/2006 6:57 PM
downunder
Score: 123
Status: offline
Going on with what Jim said about CL fliers experimenting with fuels, and especially speed fliers, the first engines were all spark ignition (ok, except the diesels but they weren't exactly the best for speed) so of course these sparkies were run on petrol at first. Then the experiments began because speed fliers are crazy and if they could find a way to feed nitroglycerine into an engine they'd have tried it
Now, if a fuel can be mixed with oil then a sparkie will run on it so methanol will have been tried by many fliers to good effect. But the story goes that one day a guy called Ray Arden was trying out a new spark plug with his methanol fuel. It ran great but when he turned off the ignition the engine kept on running. It turned out that his new type plug had a platinum electrode and he realised this was reacting with the fuel. From then it was a comparatively short step to him substituting the centre electrode with a coil of platinum wire he could heat up with a battery.
Hide Signatures
(in reply to Rupurt)
       Post #: 13
RE: Why Methanol? - 5/2/2006 7:10 PM
djlyon
Score: 100
Last Login: 10/3/2012
Status: offline
60% nitro, 20% propolene oxide, 20% castor used to make a TD049 scream on the front of my son's 1/2A proto speed planes. We could get 3 runs between engine rebuilds.
Denis
< Message edited by djlyon -- 5/2/2006 7:17 PM >
I never met an engine I didn''t like.
Of the things I''ve lost I miss my mind the most.
Hide Signatures
(in reply to downunder)
       Post #: 14
RE: Why Methanol? - 5/3/2006 3:27 PM
B.L.E.
Score: 100
Status: offline
I once experimented with a mixture of Coleman lantern fuel and after run oil mixed 50/50 as an after run fuel. After a day of flying, I connected a small tank containing this to the carb and started the engine and let it idle for a minute or until I was satisfied that all the remaining methanol and nitro were gone. Yes, glow engines will run on naphtha, which is a mixture of mostly alkanes. The engine would even keep running when the glow battery was removed.
Hide Signatures
(in reply to djlyon)
       Post #: 15
RE: Why Methanol? - 5/3/2006 4:18 PM
Sport_Pilot
Score: 233
Last Login: 6/18/2013
Status: offline
That's not exactly right. He actually was using a normal plug. His first glow plug experments used ni-chrome, he later found that platinum alloys worked better. If you go to the AMA website there is his history there under the hall of fame members.
After posting this the first time I realized this may be in the memebers area, so people from "down under" would most likely not be member's. So I found it and posted the link below. Go to the bottom of page 2 about the invention of the glow plug.
http://www.modelaircraft.org/museum/bio/Arden.pdf
< Message edited by Sport_Pilot -- 5/3/2006 4:25 PM >
“I Saw Elvis at 1000 Feet” John Force
Hide Signatures
       Post #: 16
RE: Why Methanol? - 5/3/2006 4:28 PM
Sport_Pilot
Score: 233
Status: offline
In the engine conversion forum there have been some people expermenting with glow plugs on gas engines using gas fuel and mixtures of gas and other fuels. Seems they have only fair success with pump gas, often having to use on board glow igniters to keep it running through idle. But by adding methanol to the mix most have good performance without the igniter.
Hide Signatures
       Post #: 17
RE: Why Methanol? - 5/3/2006 4:37 PM
speedster 1919
Score: 100
Last Login: 3/14/2010
Status: offline
Lets keep it simple---------Here is 2 rules---It has to be better and cheaper. period. There are all kinds of alternative fuels , for autos,heating ,RC engines,ect. But they don't meet the 2 rules better and cheaper.
Hey Buddy -That was the most spectacular crash I've ever seen , That rolling cart wheel with parts slinging out was cool...
Hide Signatures
       Post #: 18
RE: Why Methanol? - 5/3/2006 5:29 PM
Sport_Pilot
Score: 233
Status: offline
Well, gas is whole bunch's cheaper! That is better for the wallet.
Hide Signatures
(in reply to speedster 1919)
       Post #: 19
RE: Why Methanol? - 5/3/2006 5:51 PM
downunder
Score: 123
Status: offline
quote:
ORIGINAL: Sport_Pilot
I stand corrected...thanks for that. And no, I definitely don't belong to the AMA
Hide Signatures
(in reply to Sport_Pilot)
       Post #: 20
RE: Why Methanol? - 5/3/2006 6:03 PM
speedster 1919
Score: 100
Status: offline
YES SPORT Gas is cheaper but not better when were talking glow engines. Unless you convert engine to ignition. Ethanol is the closest to methanol but it is not cheaper unless goverment subsidized and has less power so it is not better.
Hide Signatures
       Post #: 21
RE: Why Methanol? - 5/3/2006 7:10 PM
wcmorrison
Score: 105
Last Login: 6/16/2013
Status: offline
Hexane is also unavailable in some countries like United Kingdom. Hexane is extremely volital, dangerous at best and to expensive at the least.
Cheers,
Chip
Hide Signatures
       Post #: 22
RE: Why Methanol? - 5/3/2006 9:50 PM
Sport_Pilot
Score: 233
Status: offline
Gas is cheaper and more effecient. In my book that is better. Sure the engine can't burn as many BTU in a short amount of time, so they make it up by using a larger engine. IMO the next phase will be smaller gas and or diesel engines, may be four strokes. When I say smaller I mean smaller than the large 23 cc and up gas engines currently in production. But larger than what we use now. Someone using a .52 four stroke may have to use a .70 sized four stroke for the same power.
Hide Signatures
       Post #: 23
RE: Why Methanol? - 5/4/2006 5:52 AM
B.L.E.
Score: 100
Status: offline
You can convert glow engines to spark ignition, they even make micro spark plugs with 1/4x32 threads that is standard for glow plugs. You still need to use glow fuel oil percentages because glow engines do not use roller/needle bearings in the rods like the gas burners have. BTW, the most expensive component in glow fuel is not methanol, it's oil. On the down side, it takes just as much spark energy to ignite the fuel/air mixture in a .40 as it does to ignite the fuel/air mixture in a 4.0 or a 40.0, thus the ignition system and the batterys that power it are just as heavy. You end up with an ignition system that weighs nearly as much as the engine.
Better and cheaper Li-Po batterys are the real threat to small glow engines in the future IMHO.
In my experience with engines .40 and smaller, fuel costs are the least of my expenses, lower than club/AMA dues, lower than the cost of driving to the flying field to fly.
Hide Signatures
       Post #: 24
RE: Why Methanol? - 5/4/2006 4:36 PM
speedster 1919
Score: 100
Status: offline
A 40 size with ignition and twice the weight does not fit the better rule. Indiana has 6 ethanol plants being built. My prediction is GLOW FUEL in the future will be ethanol instead of methanol based. First nail in coffin is cars on 85% and second will be Indy cars running 100% ethanol ,rather than methanol next year.
Hide Signatures
       Post #: 25
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Glow Engines >> Why Methanol?
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.297RCU1
