Which engine?
Tower Hobbies
Logged in as Guest
  Printable Version
NIB O.S. Engines O.S. .91 SZ-H PS-Hyper - RTF
Seller:  mkranitz
Details:   $339.00   |  10/6/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Manufacturers Direct Support Forum >> RCV Engines Support >> Which engine?
Page: [1]
Login
Which engine? - 5/2/2006 2:58:42 PM
mazer
Status: offline
Hi!
I'm looking to put a RCV 4 stroke in my new VQ Macchi 205. The manufacture recommends a .46 2-stroke or a .70 4stroke. Which of your engines would fit this the best? The plane has a 62" wingspan and will weight in at approx 7lbs.
I love the looks of your engines and I HATE cutting the cowls on my planes, so looking forward to hearing from you so I can make my purchase!
Thanks!
Mazer
       Post #: 1
RE: Which engine? - 5/5/2006 12:43:41 PM
RCV Engines
Status: offline
Hi Mazer
I would probably go for the RCV60SP or RCV58CD. Both of these should have no problems pulling a 7lb model around the sky.
If you are looking to use 3 or 4bladed props with the model, I would opt for the RCV60SP.
I hope this helps. If you have any more questions, please do not hesitate to contact me.
Best regards
Laurenne
(I'll be away until 15th May)
_____________________________
Technical Support
RCV Engines - UK
(in reply to mazer)
       Post #: 2
RE: Which engine? - 5/5/2006 4:25:38 PM
mazer
Status: offline
Thanks!
Folks have been recommending the .90's for this plane, but they seem awfully large. Maybe I'll try the .60. Got decisions to make!
Cheers!
(in reply to mazer)
       Post #: 3
RE: Which engine? - 5/15/2006 12:37:52 PM
RCV Engines
Status: offline
Hi
We also find that many modellers like to use larger engines than needed. However the kit manufacturers always recommend the largest size engine needed (as they want their planes to perform well), so generally it is an overkill if you exceed the kit manufacturers recommendations.
Best regards
Laurenne
Technical Support
RCV Engines - UK
(in reply to mazer)
       Post #: 4
RE: Which engine? - 5/15/2006 7:23:46 PM
mazer
Status: offline
Makes sense, I'll get the sp 60....I intend to spin a three blade prop..Thanks again for all the help!!
Mazer
(in reply to RCV Engines)
       Post #: 5
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.406RCU1
