snowbl!nd
Joined: 1/21/2005 From: Manchester, UNITED KINGDOM Status: offline
That's either the 1-way bearing, or it's part of the backplate. Take off the backplate and see if you can remove it. [EDIT] Definately looks like part of the 1-way. In which case it will come out. The backplate extends about 3mm outwards in the pic....so clearance might still be an issue. You should be able to work out if it will work by looking at the tiger drive to see if it has a small void in the centre.
< Message edited by snowbl!nd -- 5/4/2006 6:50:03 PM >
_____________________________
RC obsession. The quest to discover just how deep those pockets really are... Life is short - Drive fast.
