STYRKORO S27
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> S.P.A.D. Aircraft - Coroplast design >> STYRKORO S27
Page: [1] 2   next >   >>
Login
STYRKORO S27 - 5/6/2006 7:46:25 PM
microsprint9
Status: offline
Well here's my second attempt at a SPAD, it's the STYRKORO S27. I loved my parkzone f27 so much and have designed many foamies around the basic shape of the stryker, then i bought a glow motor and since then i have been neglecting my electrics. This has got to be one of the easiest builds i have done, then plane is 90% finished, only some paint and vinyl to make it look like a stryker. My first spad was this same plane without the nose, it was basically a flying wing and flew very good with a 40LA but it was tail heavy so i decided to move the motor forward and use the stock shape of the stryker, i guess i moved the motor too far forward, i needed 5oz of lead in the tail to balance it. I have drawn this plane in cad so if anyone is interested i will post a file. I hope to maiden it next week if the wind dies down a bit. Here are the specs.
Wingspan 44"
Wing Area 580 sq/in including elevons
Wing Load 16.8 oz/sqft
Weight 4.25lbs
Engine OS 40LA
Prop 10x7
Radio Hitec Optic 6
Receiver Electron 6
Servos HS-325HB 3 needed ( 2-elevons, 1-throttle )
Here are some pictures up to now
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 1
RE: STYRKORO S27 - 5/7/2006 4:24:57 AM
FantzyPantz
Status: offline
I like the design of your Strykoro. Is this made with a single piece of 4mm or do you double 2 pieces of coro with the flutes perpendicular like the BullDawg? I would like to see how you mount the servos, measurements, CG, or Drawings. Did you use anything to stiffen up the wings like carbon rod, or BBQ skewers? It looks very similar to the CoroRoo, found at http://www.spadcombat.com
< Message edited by FantzyPantz -- 5/7/2006 4:28:28 AM >
(in reply to microsprint9)
       Post #: 2
RE: STYRKORO S27 - 5/7/2006 7:23:22 AM
acam37
Status: offline
Have you seen the coro-roo? It is very similar in design. I watched a video of one and with the right engine and prop these things are very fast.
(in reply to FantzyPantz)
       Post #: 3
RE: STYRKORO S27 - 5/7/2006 12:47:21 PM
microsprint9
Status: offline
Sorry i forgot to mention in my first post that it is just a 6mm pc of coroplast and 2-1/2 x 2-1/2 pvc downspout. I did epoxy a 3/16 dowel in the wing, if you look closely in the one of the pictures you can see it. My prototype was basically the same and it was quite fast with the 40LA, the wings did start to flutter a bit on fast level passes but i'm sure with some leading edge stiffening and maybe some more of those bbq skewers you could make this thing extemely fast. Late yesterday i mounted the elevon and throttle servos and did some painting, going back to my shop right now to finish it off. I'll post some more pictures later on. It might look like the coro-roo, but this plane is 100% built around my first plane, the parkzone f27 Stryker. http://www.horizonhobby.com/Products/Default.aspx?ProdID=PKZ1200
(in reply to acam37)
       Post #: 4
RE: STYRKORO S27 - 5/7/2006 4:53:30 PM
microsprint9
Status: offline
Back from the shop, WOW, what a difference paint makes, it's also nice to have a vinyl cutter. All servos are zip tied in place and the CG should be 9"-10" from the back flat part of the wing which is same as my stock stryker, just scaled up. Plane is 95% finished now, only throttle linkage and hooking up the radio gear to go, i might also make a front cowl for looks, but this is simple plastic aircraft design, a cowl will probably be a little bit of work and not so simple. Once i have maidened the plane and exacted the CG i will post plans for all to enjoy. Here's some pictures up to now.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 5
RE: STYRKORO S27 - 5/7/2006 4:54:46 PM
microsprint9
Status: offline
A few more.
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 6
RE: STYRKORO S27 - 5/7/2006 6:51:38 PM
FantzyPantz
Status: offline
Alright, with those pictures you convinced me that I really want to build one of these. It's going to compliment my CoroRoo quite nicely I think. I'm interested in the drawings that you have.
       Post #: 7
RE: STYRKORO S27 - 5/8/2006 2:33:51 AM
DLSmith2
Status: offline
Great looking ship with an awesome paint and graphics job!
Looking forward to seeing the plans!
Blue skies,
DL
       Post #: 8
RE: STYRKORO S27 - 5/8/2006 8:21:42 PM
Smooth Spanky
Status: offline
Microsprint9:
Great idea and nice job on the plane! You mentioned only 3 servos (elevons + throttle). Does this mean your nose gear is not steerable?
SS
(in reply to DLSmith2)
       Post #: 9
RE: STYRKORO S27 - 5/9/2006 8:30:12 AM
jamesg25
Status: offline
looks god, great paiont job. perhaps you may want to consider putting clear tape over the leading edge, it should make it fly nicer.
great job,
looking, waiting for flight report.
regards
james
(in reply to Smooth Spanky)
       Post #: 10
RE: STYRKORO S27 - 5/9/2006 10:10:01 AM
microsprint9
Status: offline
Thnaks for the complimements, i got to fly it last night. I don't have a runway but i wanted gear on the plane to save the prop on landing, so i made the nose gear solid. The first flight went alright, but hand launching this plane was not the best idea, i nosed it in a few times, but on my last try i got it up in the air, i think i still need some more weight in the rear, so the CG will be 9-9-1/2" from the back flat part of the wing. I will draw up some plans today and post them. I think next time i fly her i'll find a runway to takeoff from, and make the nose gear steerable.
(in reply to jamesg25)
       Post #: 11
RE: STYRKORO S27 - 5/9/2006 1:41:15 PM
Muldoer
Status: offline
Since you got it flying, do you think that a .46BB would be overkill on this plane? I have a Sickle with a 40la on it, but I also have an Evo 46NT sitting on a low winger and I since the Sickle flies so great I am starting to have a deeper interest in flying wings.
       Post #: 12
RE: STYRKORO S27 - 5/9/2006 3:21:45 PM
microsprint9
Status: offline
I found the 40La seemed to have more power in the prototype, but it also weighed 10-12oz less, i think a good .32 would keep some of the weight off the nose and allow for less lead to be used in the tail. I think a 46bb could be used but you might want to scale the plans up a bit to lower the wing loading. Plans will be posted very shortly.
(in reply to Muldoer)
       Post #: 13
RE: STYRKORO S27 - 5/9/2006 4:53:33 PM
microsprint9
Status: offline
Okay here we go. In drawing 1 layout all the dimensions onto a sheet of 6mm coroplast and cut out. The tail fins are giving me a problem to post so they can be printed to scale, please e-mail me and i will send you a printable .jpg file that will work on a legal size sheet, or on a 8-1/2" x 11" and just improvise the rest, i used 1/2" quarter round to attach these to the wing, triangle would also work. In Drawing 2 cut out fuse from 2-1/2" x 2-1/2" PVC downspout, i used a pc with sides cut down to 1/2" for the hatch. Drawing 3 is the graphics, not sure if the picture is usable to you guys but it will give some reference. Everything was assembled with ZAP CA and zip ties were used for attaching servos, battery and reciever. I used a 3/4" thick pc of ply for the motor mount bulkhead, since this was my first attempt at landing gear i'll leave that one up to you. CG is between 9" and 9-1/2" from the middle flat part of the back of the wing forward. Enjoy, and if you need anymore details please let me know.
Wayne Vanderweyst
microsprint9@hotmail.com
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by microsprint9 -- 5/9/2006 5:07:49 PM >
