RE: *~ Official RC10GT2 Thread ~*    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Nitro Stadium Trucks >> RE: *~ Official RC10GT2 Thread ~* Page: <<   < prev  9 10 [11] 12 13 14 15 16 17 18   next >   >>
Login
RE: *~ Official RC10GT2 Thread ~* - 1/24/2007 8:17 AM
whoajoe
Last Login: 12/19/2007
Status: offline
quote:
ORIGINAL: Pro Twister Mods
This is the 6508 it is a direct bolt in the GT2, no citting on the threads. the TC3 nut goes right on use lock tite and the shim that comes in the GT2 kit and 1 thin shim and your set.
Forgive my ignorance, but doesn't the GT2 have to have a rear exhaust, or does it matter? Anyway, I just looked on the Associated website and it says that a standard crank with the clutch nut will work. Also, I looked at the LRP .12 that they used in the photos of the factory team GT2 and it has a longer looking shaft and it just says it needs the clutch nut. Here is the page. The engine is the one on the right. http://www.teamassociated.com/shusting/CatalogHub/lrp/engines.htm
So I should be good if I get this engine and the NTC3 clutch nut.
http://www.horizonhobby.com/Products/Default.aspx?ProdID=DYN6507
_____________________________
J.C.-
"Do work son!" -BB
Hide Signatures
(in reply to Pro Twister Mods)
       Post #: 251
RE: *~ Official RC10GT2 Thread ~* - 1/24/2007 4:17 PM
Wide Open
Last Login: 10/20/2009
Status: offline
hmm, i dont know why they said it would work. i had an engine with a standard crank and it was way too long for the clutch nut. if you do get a standard crank engine you need to remove the drive hub in front of the front bearing and cut the crankshaft down. the short cranks dont come with the drive hub and the crank is already short enough. (finding engines for the gt2 can be hard )
I can divide by zero.
Hide Signatures
(in reply to whoajoe)
       Post #: 252
RE: *~ Official RC10GT2 Thread ~* - 1/25/2007 1:11 AM
whoajoe
Status: offline
I guess I will figure it out eventually. I don't plan on getting the truck for a couple of months anyway, I just wanted to have a plan of everything I needed to get. Thanks for your guys's help.
J.C.-
"Do work son!" -BB
Hide Signatures
(in reply to Wide Open)
       Post #: 253
RE: *~ Official RC10GT2 Thread ~* - 1/25/2007 6:16 AM
Wide Open
Status: offline
well, it seems my OS .12 is finally waking up. to get full throttle i have to have the end point on the transmitter set to 120%, and i have it set to 90%... and its still insane. i was pulling wheelies like mad off the line, but now the back of my battery box is all scratched up from all four wheels lifting off the ground. time to loosen that slipper clutch!
Hide Signatures
       Post #: 254
RE: *~ Official RC10GT2 Thread ~* - 1/25/2007 6:31 AM
Pro Twister Mods
Last Login: 1/5/2008
Status: offline
wide open, if it's ok with the folks, email me your phone number and i will call you and help with the diff.
Brian Carey
brian@protwistermods.com
Hide Signatures
       Post #: 255
RE: *~ Official RC10GT2 Thread ~* - 1/25/2007 6:35 AM
Pro Twister Mods
Status: offline
the GT2 can run side or rear, i prefer side because the powerbands are much smmother.
Brian Carey
Hide Signatures
       Post #: 256
RE: *~ Official RC10GT2 Thread ~* - 1/26/2007 6:53 AM
Pro Twister Mods
Status: offline
wide open ya have the diff out, it will make more sence, i will call friday afternoon, i am in Knoxville Tn right know i will call you during my drive back home OK. cool
Brian Carey
Hide Signatures
       Post #: 257
RE: *~ Official RC10GT2 Thread ~* - 1/26/2007 7:22 AM
whoajoe
Status: offline
RPM arms now available for the GT2.
J.C.-
"Do work son!" -BB
Hide Signatures
       Post #: 258
RE: *~ Official RC10GT2 Thread ~* - 1/26/2007 12:05 PM
ImGoinRCn
Last Login: 4/14/2007
Status: offline
I bet he's stuck in I-40 traffic..lol
When all else fails, aim for the quarter panel.
Hide Signatures
       Post #: 259
RE: *~ Official RC10GT2 Thread ~* - 1/26/2007 12:29 PM
tattguy12
Last Login: 3/28/2008
Status: offline
where did you find them?
Hide Signatures
       Post #: 260
RE: *~ Official RC10GT2 Thread ~* - 1/26/2007 4:08 PM
Wide Open
Status: offline
ok, will do also, it turns out that i have to get allergy shots today, so i might not get home until about 3:00 my time.
< Message edited by Wide Open -- 1/26/2007 4:09 PM >
Hide Signatures
       Post #: 261
RE: *~ Official RC10GT2 Thread ~* - 1/27/2007 10:13 PM
Drvrswntd
Last Login: 10/25/2008
Status: offline
Check it out http://www.rcuniverse.com/forum/m_5331187/tm.htm
Hide Signatures
       Post #: 262
RE: *~ Official RC10GT2 Thread ~* - 1/27/2007 10:29 PM
tattguy12
Status: offline
looks good, thats a bummer about the clutch
Hide Signatures
(in reply to Drvrswntd)
       Post #: 263
RE: *~ Official RC10GT2 Thread ~* - 1/28/2007 4:02 AM
Wide Open
Status: offline
hmm, maybe there is a problem with the springs on the first couple runs of these. when i bought a new set of the same clutch springs i noticed the color was slightly different. maybe they used a different way of making it on the new runs of the springs?
Hide Signatures
(in reply to tattguy12)
       Post #: 264
RE: *~ Official RC10GT2 Thread ~* - 1/28/2007 4:45 PM
ImGoinRCn
Status: offline
How much of the kits Associated has and has Thunder Tiger making parts? Is it me or has Associated gone down hill since TT has been involved?
Hide Signatures
       Post #: 265
RE: *~ Official RC10GT2 Thread ~* - 1/29/2007 6:57 AM
Wide Open
Status: offline
AE will be hurt by the deal at first from what ive heard, but it should eventually work to both companies benefit.
i finally got my gt2 off road for a tank today and it did well. the handling is great
Hide Signatures
(in reply to ImGoinRCn)
       Post #: 266
RE: *~ Official RC10GT2 Thread ~* - 1/29/2007 7:19 AM
Pro Twister Mods
Status: offline
wide open did you get the diff sorted out i've been meaning to call if not let me know if i can call now
Brian Carey
Hide Signatures
       Post #: 267
RE: *~ Official RC10GT2 Thread ~* - 1/29/2007 4:18 PM
Wide Open
Status: offline
my diff is working fine. i took the tranny apart this weekend and there are no signs of anything wrong with it. thanks anyway, though
this is proving to be a fun car, i just dont like starter boxes. having to have that extra battery charged and everything can get in the way sometimes, but once the car does start, its awesome!
Hide Signatures
       Post #: 268
RE: *~ Official RC10GT2 Thread ~* - 1/30/2007 3:47 AM
Pro Twister Mods
Status: offline
good deal
Brian Carey
Hide Signatures
       Post #: 269
RE: *~ Official RC10GT2 Thread ~* - 1/30/2007 4:16 PM
Wide Open
Status: offline
so, how many of you guys are racing yours? once i get the engine running really well im going to take it to the track and try my hand at it. it really seems to be a point and shoot car. it doesnt get off course easily or get messed up by roughness in the way.
Hide Signatures
       Post #: 270
RE: *~ Official RC10GT2 Thread ~* - 1/30/2007 4:43 PM
ImGoinRCn
Status: offline
Waiting for the weather to get warmer...
Hide Signatures
       Post #: 271
RE: *~ Official RC10GT2 Thread ~* - 1/31/2007 6:31 AM
Wide Open
Status: offline
quote:
ORIGINAL: ImGoinRCn
lol, ive got to get racing in as soon as possible because the weather will be up around 120 in the next few months!
Hide Signatures
       Post #: 272
RE: *~ Official RC10GT2 Thread ~* - 1/31/2007 6:55 AM
Pro Twister Mods
Status: offline
I take it racing every sat night, and test on friday nights, a gallon of fuel last 3 weeks for me LOL
Brian Carey
Hide Signatures
       Post #: 273
RE: *~ Official RC10GT2 Thread ~* - 1/31/2007 12:00 PM
ImGoinRCn
Status: offline
100 degrees?? WOW!
Twister, where do you race, Thunder RC or?
Hide Signatures
       Post #: 274
RE: *~ Official RC10GT2 Thread ~* - 1/31/2007 4:13 PM
Wide Open
Status: offline
nice! are you running a .12 also? i probably wont be racing every week so a gallon should last even longer.
quote:
ORIGINAL: ImGoinRCn
100 degrees?? WOW!
those are our night time tempuratures the alcohol roll level indicators in the helicoptors my dad flies boil and explode during the summer it gets so hot here. needless to say there is a lot of money spent on roll indicators during the summer.
Hide Signatures
       Post #: 275
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.984RCU1
