batteries and electronics
Tower Hobbies
Logged in as Guest
  Printable Version
Hangar 9 Showtime 50 + Saito 82 - RTF
Seller:  kmac425
Details:   $600.00   |  9/29/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> IMAC >> batteries and electronics
Page: [1]
Login
batteries and electronics - 5/7/2006 11:04:16 PM
xxsnookxx
Status: offline
i am building my first imac plane and would like some suggestions on batteries and electronics .i am using jr 8411sa on all except throttle 3241sa .was thinking 2 fromeco 2400 with reg. jr match box on elevators..i am also using a 26gt evo so i would like to stay as light as possible oh ya by the way its a QQ 73" yak54 thank you...
< Message edited by xxsnookxx -- 5/7/2006 11:07:46 PM >
       Post #: 1
RE: batteries and electronics - 5/8/2006 12:47:27 AM
sweetpea01
Status: offline
No need for matchbox on the elevators, unless your radio doesn't have V tail or something simlar to that mix.
Other than that sounds good. Keep it simple. I like dual batts for the rx just in case and a way to kill the engine, but your plane is a little smaller.
_____________________________
www.propnuts.org
www.hobbiesxtreme.com
(in reply to xxsnookxx)
       Post #: 2
RE: batteries and electronics - 5/12/2006 1:00:04 AM
xxsnookxx
Status: offline
whats the best lightest imac legal kill switch?
(in reply to sweetpea01)
       Post #: 3
RE: batteries and electronics - 5/12/2006 8:14:28 PM
Dean Bird
Status: offline
xxsnookxx,
I convert all my ignition units to standard JR connectors so that any battery, switch, regulator, or Ignition Cutoff can plug into it.
I've always used the Smart-Fly Ignition Cutoff. It has a small unit that you include in the line between the ignition battery switch and the ignition unit, and another small unit that plugs into the receiver channel. The two are connected by a fibre optic cable so that no RF signals can travel down the line to the receiver.
I've seen guys use this Optical Cutoff as their ignition switch. The ignition can ONLY be on if your reciever is on and that channel is sending the "on" signal. Seems like a very effective switch. If you run a setup like that, you have to unplug the ignition battery if you aren't going to fly for several weeks because it does draw a little power.
You always need to pay cloase attention to your fail-safe position for the "kill" channel. If you want the engine to die in a fail-safe situation, you have to program the "kill" channel to go to the "off" position for fail-safe.
Let us know if you have any questions or need any other information.
Take care,
Dean
< Message edited by Dean Bird -- 5/12/2006 8:22:17 PM >
www.Smart-Fly.com
www.TroyBuiltModels.com
       Post #: 4
RE: batteries and electronics - 5/12/2006 9:54:40 PM
Rocketman_
Status: offline
quote:
ORIGINAL: xxsnookxx
I use the RCATS RC100 - Electronic Switch $24.95. It is very small and light (weighs 12g/.42oz) and plugs into a vacant receiver channel.
http://rcatsystems.com/electronics/rc100.php
I've used it with PPM and PCM receivers with no glitches or reduction in range check distance. I have no knowledge of whether this one is IMAC legal but RCATS offers another one (RC100FO - Fiberoptic Electronic Switch $34.95) which they say is favored by IMAC contestants.
Click to see fullsize image.
Click for fullsize
       Post #: 5
RE: batteries and electronics - 5/13/2006 3:29:10 AM
sweetpea01
Status: offline
I've always used the Electro Dynamics kill switch....similar to Smart-Fly but a little larger.
www.propnuts.org
(in reply to Rocketman_)
       Post #: 6
RE: batteries and electronics - 6/9/2006 6:06:27 PM
toprudder
Status: offline
IMAC newbie here. Where in the IMAC rules is a kill switch specified? I have not seen a reference to that.
I'm in the process of building my first gasser, and intend to fly it in IMAC. I like the idea of the fiber-optic setup. I will probably invest in that. For now, I have a traditional manual kill switch, and will program the fail-safe to cut throttle.
       Post #: 7
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.609RCU1
