jrf
CA, USA Status: offline
quote:
I wouldn't take it. The Luscombe is a nice little two-place airplane that does very well what it was designed to do - and high speed is not it. If I wanted something faster and racier, I would step up to a Cessna 170 or 180 but not repower the Luscombe. In my mind, a larger engine would spoil the charm of the Luscombe. You see, I believe that planes (big and small) are all purposefully designed. If you want to spend a Saturday afternoon skimming the treetops and doing touch and goes, you do it in a Cub. However, if blistering speed is what you're after, it doesn't make sense to me to repower the Cub when a Mustang would do a much better job going fast. (Assuming that I had gobs of extra money! ) You, and many of the other posters here seem to equate more power with more speed. In models at least, that is not usually the case. Most of the "grossly overpowered" models you take exception to are actually quite slow. 3D models in particular typically have a top speed of around 50 mph. The primary reason for overpowering a model is for better accelleration and vertical penetration, and a more constant speed through maneuvers. The fact that these characteristics also provide the ability to change the airplanes attitude and direction from impending crash to safety in the blink of an eye is a happy coincidence. It is also the main reason that non-3D flyers find "overpowered" models to be safer and, oh no, here it comes... easier to fly. Overpowering an airplane for more speed can be dangerous of course, but overpowering an airplane, using a low pitch prop for more thrust and using rational throttle control can make it a better airplane in every way. That theoretical 130 hp Luscombe, given no significant weight increase and propped for the same top speed would make the airplane much safer with a full load on a high density altitude day and give it short field capabilities it doesn't have now. If Luscombe could have done it at the same weight, for the same price, he would have. Jim
< Message edited by jrf -- 5/23/2007 5:20:10 PM >
