CAPtain232
Joined: 12/15/2001 From: Waynetown, IN, USA Status: offline
quote:
The real weight savings on the foam is if you can remove the foam, the sheeting over it and the glue that would be in that area. You are absolutely right. The issues are curved surfaces. You can cut foam out of a curved surface, but if you cut even small holes after sheeting, you are going to see indentions in the covering. When you honeycomb the foam and THEN apply the sheeting, you will never see those indentions as long as the holes used to honeycomb aren't big holes. I typically make the hex holes 3/4" or less from flat side to flat side. I think I could make bigger holes and still have a great finished look, but 3/4" holes seem to leave the right amount of foam to maintain strength and great looks. Flat surfaces..... Prep the foam, glue the sheeting on and then cut your holes....NO PROBS
_____________________________
CUSTOM GIANT SCALE BUILDER PROTOTYPE MODEL BUILDING for full scale aircraft current project can be seen at http://www.geversaircraft.com
