RE: HurriKane Kit
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Pylon Universe - RC Pylon Racing >> Q-500 Racing >> RE: HurriKane Kit Page: <<   < prev  1 2 3 [4] 5   next >   >>
Login
RE: HurriKane Kit - 5/22/2006 4:11:18 AM
HighPlains
Status: offline
Is that a quickie or the box it came in?
How to tell the difference........Count the number of sides........if you count 5, then it is the quickie.......6 means it's the box.....
_____________________________
In politics if you want anything said, ask a man. If you want anything done, ask a woman - Margaret Thatcher
(in reply to daven)
       Post #: 76
RE: HurriKane Kit - 5/22/2006 10:23:45 PM
daven
Status: online
Just about done, a 15 day quickie without a lot of time spent in any single day or evening.
Just a consistant 1-2 hours per day. Probably about 20 hours, but Randy did the wing.
It still needs the receiver, fuel tank, battery, and throttle cable hooked up. Current weight is 3 lbs 4 oz so its going to be a little heavy (3-4 oz).
If all arrives this week, it should get maidened on Saturday.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Dave Norman
klasskote.com
supertrc.com
(in reply to HighPlains)
       Post #: 77
RE: HurriKane Kit - 5/22/2006 10:25:36 PM
daven
Status: online
The AMA numbers on the right side of the fuse are Green. I couldn't do a plane without using Green somewhere
< Message edited by daven -- 5/31/2006 1:12:16 PM >
Dave Norman
klasskote.com
supertrc.com
(in reply to daven)
       Post #: 78
RE: HurriKane Kit - 5/23/2006 12:12:14 AM
Ed Smith
Status: offline
quote:
The NMPRA numbers on the right side of the fuse are Green. I couldn't do a plane without using Green somewhere
What about the LEGALY required AMA numbers.
Ed S
(in reply to daven)
       Post #: 79
RE: HurriKane Kit - 5/23/2006 1:06:04 AM
daven
Status: online
Ooops, I meant the Legally required AMA number.
No NMPRA numbers on this plane.
That brings something up I'm curious about.
Just about everyone puts their AMA numbers on the wing, I think they look much better on the fuse.
Dave Norman
klasskote.com
supertrc.com
(in reply to Ed Smith)
       Post #: 80
RE: HurriKane Kit - 5/23/2006 2:40:33 AM
P. Johnson
Status: offline
Good point Dave, the idea behind the numbers is for identification if the plane is lost. I have seen several race planes that seperate from the wing, usually the wing is easy to find, but I have seen a fuse travel a long distance and actually not be found for a long time.
Please ... Don't eat the Monokote !!
(in reply to daven)
       Post #: 81
RE: HurriKane Kit - 5/23/2006 4:27:52 AM
Clark L
Status: offline
Ya know...
I've seen this a few times but... I don't read in any AMA document where ANY markings are required. Only that if you do choose to place "registration numbers" on your aircraft that they "shall" be done a specified way...
I don't mean to start a war over something so trivial.... but, am I missing something?
(in reply to P. Johnson)
       Post #: 82
RE: HurriKane Kit - 5/23/2006 6:34:25 AM
garys
Status: offline
Clark,
Yes you are missing something, although it is pretty trivial, especially considering how often airplanes change hands and the # of ARF's in use today (both the Viper/Pred's and composites). Section 10, 10.1 (it's in the general rules at the beginning, not in the event specific rules). The rule says "registration numbers shall consists.......", although I've only seen this rule enforced a couple of times. The next rule, pertaining to racing numbers, says that the racing numbers are not required. I use the 27 from my NMPRA # on most of my planes, but leave out the "d" area letter.
The way I look at it, you can write the registration # on the lane sticker, even if it's on the wrong side of the airplane. If somebody's going to cry about it being on the wrong side, they've probably got other things to worry about, and may need to schedule an appointment with Dr. Phil.
GS
< Message edited by garys -- 5/23/2006 6:47:26 AM >
GS
(in reply to Clark L)
       Post #: 83
RE: HurriKane Kit - 5/24/2006 3:22:57 PM
tropejm
Status: online
Started a new post
< Message edited by tropejm -- 5/24/2006 3:25:13 PM >
       Post #: 84
RE: HurriKane Kit - 5/24/2006 5:31:06 PM
Clark L
Status: offline
Thanks Gary, While I don't exactly interpret section 10 the same way, I think you're right about the original intent of the rule. I guess I'll keep puttin' on my numbers...
(in reply to garys)
       Post #: 85
RE: HurriKane Kit - 6/1/2006 1:17:18 PM
daven
Status: online
Well, the radio gear arrived finally, and everything is installed, throws are set, and its ready to go.
Final weight came in at 3 lbs 11.7 oz.
Heavier than I wanted, but perfect if the rule passes
I attribute the heavier weight to a slightly heavy wing, a 2oz composite tail, the blocks I had to add to the tail area to bolt the tail down, and my fiberglass/paint job. Using the kit tail, and ultracote would have resulted in a plane closer to 1 oz heavy.
Dave Norman
klasskote.com
supertrc.com
       Post #: 86
RE: HurriKane Kit - 6/1/2006 1:20:49 PM
daven
Status: online
I balanced the plane up this morning and was surprised. Its balancing at 3 1/8" back from the leading edge. The Hurrikane has a shorter moment from wing to tail than my Seeker, with the same length nose, so I was sure it was going to be nose heavy. I can move the battery in front of the fuel tank, but I'll test fly it first and see how it flies. I normally fly mine at about 3" back, but that is with a 9 3/4" chord wing (roughly 30-31%) back. Randy's wing has a 10 1/8" chord, so the percentage is basically the same.
Dave Norman
klasskote.com
supertrc.com
(in reply to daven)
       Post #: 87
RE: HurriKane Kit - 6/1/2006 3:48:15 PM
luv to race
Status: offline
Probably that "compostit" tail. (Or TV antenna you got on that thing..LOL...)... as opposed to a "wood" tail. The extra weight could be causing it ??
RB
(in reply to daven)
       Post #: 88
RE: HurriKane Kit - 6/1/2006 3:53:19 PM
daven
Status: online
I like the name "bunny ears" for the Neme tail.
I think I came up with the name for this plane, its a....
Hurri-Q 200
Hurrikane Fuse
Neme-Q Tail
R-200 wing
Dave Norman
klasskote.com
supertrc.com
(in reply to luv to race)
       Post #: 89
RE: HurriKane Kit - 6/1/2006 7:07:42 PM
kane
Status: offline
Dave,
I love the HURRI-Q 200!
Interested to see how it flies. See there was nothing to worry about with the CG.
Dan
Dan Kane
(in reply to daven)
       Post #: 90
RE: HurriKane Kit - 6/1/2006 7:35:31 PM
daven
Status: online
I was worried about the CG, I was shocked when I checked it last night, and had to double check it this morning.
As long as I got the tail/wing/nose straight, there is no reason it shouldn't fly great.
Dave Norman
klasskote.com
supertrc.com
(in reply to kane)
