RE: HurriKane Kit
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Pylon Universe - RC Pylon Racing >> Q-500 Racing >> RE: HurriKane Kit Page: <<   < prev  1 2 3 4 [5]
Login
RE: HurriKane Kit - 6/16/2006 12:15:36 AM
Shackas
Status: offline
So, you want to know how to align the 2nd and 3rd firewall pieces on the HurriKane? Try using a HurriCork...
Click to see fullsize image.
Click for fullsize
(in reply to HighPlains)
       Post #: 101
RE: HurriKane Kit - 6/21/2006 3:21:26 PM
kane
Status: offline
Dave,
Please keep the dirty picts to a minimum
Clever idea.
DK
_____________________________
Dan Kane
(in reply to Shackas)
       Post #: 102
RE: HurriKane Kit - 6/24/2006 11:53:30 PM
bigtrev@xtra.co.nz
Status: offline
A broom handle does the same trick, as in NZ more and more wine is being sold in screw-on caps. atleast with a broom you can leave it against the workbench over night with the fuselage attached whilst it driess.trevor h, nz
(in reply to kane)
       Post #: 103
RE: HurriKane Kit - 6/26/2006 12:37:26 AM
Terryoc
Status: offline
Yes Trevor but with a bottle cork you have something to drink while watching it dry and it gets more exciting the longer it takes to dry
Terry
(in reply to bigtrev@xtra.co.nz)
       Post #: 104
RE: HurriKane Kit - 6/26/2006 12:44:51 AM
bigtrev@xtra.co.nz
Status: offline
Terry, lucky we know each other- I always use the broom after Liz has done the housework- then its bedtime.................whoops, trevor h
(in reply to Terryoc)
       Post #: 105
RE: HurriKane Kit - 6/7/2007 12:44:57 AM
daven
Status: offline
Well, I've been flying the Huri-Q 200 quite a bit over here in Cheese Land, and its time for an upgrade. I think the warp in the wing has worsened over time, and I literally can NOT turn left (even on high rates and full stick) as the plane slows down for landing. Its taught me how to land with a right hand turn final, but thats about it. It also has a weird twisting "wiggle" through the turns with full elevator.
Dave Norman
klasskote.com
supertrc.com
       Post #: 106
RE: HurriKane Kit - 6/7/2007 12:51:10 AM
daven
Status: offline
I had to add wood to both wing plates, and fill in the holes, but that didn't take much.
Tried to mount the wing tonight, and I got the opposite problem that I had putting it together the first time with Randy's wing. I need to raise the TE of the wing about 1/8" to get the wing inicidence correct. Not sure its possible (at least easy) to lower the LE. Thought about adjusting the tail and nose incidence, but thats just as much work.
Picked up this wing a couple weeks ago, looks great.
Click for fullsize
Dave Norman
klasskote.com
supertrc.com
(in reply to daven)
       Post #: 107
RE: HurriKane Kit - 6/7/2007 10:41:45 PM
kane
Status: offline
Dave,
I would remove material from the wing saddle (Dremel with a sanding Drum) so that the wing fits the way you wish and re-pot it.
Dan
Dan Kane
(in reply to daven)
       Post #: 108
RE: HurriKane Kit - 6/7/2007 11:00:22 PM
daven
Status: offline
Dan,
too late, added the spacer block at the TE and will add some scrap wood and repot. I will also have to add something to the fuse behind the wing to lessen the transition behind the wing.
Pretty much a practice / local race plane. Hope to use it in Amery, WI later this summer. You should try and make that race, I believe Seaholm and his crew may make it also.
Dave Norman
klasskote.com
supertrc.com
(in reply to kane)
       Post #: 109
RE: HurriKane Kit - 7/4/2007 2:07:48 AM
JAS
Status: offline
I can't wait to get my 2. I'll have them ready to run at Tangerine
Uncle JAS
Shulman Aviation
(in reply to daven)
       Post #: 110
RE: HurriKane Kit - 7/7/2007 6:33:21 PM
CharliesHobbies
Status: offline
When is tangerine running a race?
(in reply to JAS)
       Post #: 111
RE: HurriKane Kit - 9/24/2007 3:20:25 PM
daven
Status: offline
I flew the plane in Amery this weekend, and wow, it flew great. This is really a good flying combination, my only advise would be to add about 10% down Elevator mixed with low throttle to avoid the plane pitching upwards under no power. It also took me a bit to get the C.G. perfect, I'm at 3 1/8" and it is perfect for how I like to fly. At 3 1/4" it was a handfull.
Bruce's wings are definately heavy duty, I midaired Chuck E. coming back from #1 and put about a 3" hole in the leading edge of the Seeker wing. I was able to fly 4 more laps at power and the wing did not explode with all the air rushing in there like you normally see with a composite wing. A couple of strips of aluminum duct tape and its nearly as good as new.
Good combo of fuse, wing, and tail.
Dave Norman
klasskote.com
supertrc.com
(in reply to CharliesHobbies)
       Post #: 112
RE: HurriKane Kit - 10/14/2007 4:35:43 AM
PylonDave
Status: offline
any one got any pics of the airloin servo tray set up for the two piece hurrikane wing??? I don't see any pics of this on the supertrc site.
(in reply to daven)
       Post #: 113
RE: HurriKane Kit - 10/14/2007 2:07:14 PM
daven
Status: offline
If I could find my camera, I'd take a picture for you Dave, but basically, I just mount mine on the left wing, with the servo edge even with center of the wing. You have to slightly angle your servo arm, and run your torque rods to the horns. I put my 1/8" ply on top of the wing (some put it inside to save room, works good on q40's) to screw my servo screws into.
Dave Norman
klasskote.com
supertrc.com
(in reply to PylonDave)
       Post #: 114
RE: HurriKane Kit - 10/14/2007 5:20:56 PM
djlyon
Status: offline
here as per Clark
Click for fullsize
Click for fullsize
< Message edited by djlyon -- 10/14/2007 5:22:21 PM >
I never met an engine I didn't like.
Of the things I've lost I miss my mind the most.
       Post #: 115
RE: HurriKane Kit - 10/14/2007 6:30:03 PM
PylonDave
Status: offline
Thanks Dave and Denis, Clark
I think i will use Clarks method to keep the servo in the middle.
(in reply to djlyon)
