sc204
As Joe said I put the anhedral stab on mine. I had some trimming issues that I thought may have been due to unequal elevator half tapers. Sam over at Oxai volunteered to replace the stab with one he had in stock which was the anhedral version. (Sam if you are reading this, the original will be on its way back to you this week ) As many have said about Oxai, replacement parts fit perfectly. Even with the anhedral in the stab, it mated perfectly to the fuse. I probably have about 13 flights on it so far and finally got a low wind say last Sunday to play with trimming again. It seems to be fine and some of the issues I was seeing with the other stab appear to be gone. I can't say I see any significant difference in the rolling maneuvers although I do not do any of the integrated rolling/looping maneuvers that the anhedral stab is said to improve. Is it a gimmick or does it really help? I do not know but I can tell you that just like my first pattern ship a Hanno Pretner Magic with anhedral stab it does get lots of notice at the field Stuart
