RC On Road Nitro Cars Discuss all aspects of on-road nitro rc cars here
rs4 3 18ss + os 18tz
Old 05-11-2006 | 08:25 AM
Default rs4 3 18ss + os 18tz
What would it take to do this, and would it be worth the money? I dont race , just parken lot stuff. Its mostly stock. thanks
Old 05-11-2006 | 05:42 PM
Default RE: rs4 3 18ss + os 18tz
ORIGINAL: xstar
all you need is engine mount, an 18tz, a new manifold and an hpi evo rs4.
I"ve got one right now thats highly modified with an 18tz in there but never got around to breaking it in, I'm thinking of selling it but not sure yet. LMK if your interested in details.
Old 05-11-2006 | 08:13 PM
I have the rs4 3 18ss. I was looking to upgrade it thanks
Old 05-11-2006 | 08:33 PM
ok so i would need this..
http://www2.towerhobbies.com/cgi-bin...?&I=LXFAZ8&P=0
http://www2.towerhobbies.com/cgi-bin...?&I=LXHLW1&P=M
http://www2.towerhobbies.com/cgi-bin...?&I=LXBYG0&P=0
Not sure what mounts you or talking about... thanks for the infor on if this is all i would need?
Old 05-11-2006 | 08:41 PM
Rs43EVOman's Avatar
That last thing you need is this
[link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXCLR3&P=7]http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXCLR3&P=7[/link]
Or if you want to save money i think these will work also
[link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXN373&P=7]http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXN373&P=7[/link]
Old 05-12-2006 | 02:08 AM
heres a link to what mines looks like
http://www.rcuniverse.com/forum/fb.asp?m=4247647
I'm thinking of selling my 18tz let me know if your interested I've also got a starter box to go with it if your interested? never broken in so you'll hvae to break it in.
Old 05-13-2006 | 02:30 AM
RCsHPI's Avatar
if you want some other mounts check out: WOLFPACK RADICALS MOTOR MOUNTS...they are very well made and are adjustable unlike the other mounts
CLICK ----> http://wolfpackradicals.com/html/all_mounts.html
Old 05-13-2006 | 07:31 PM
Ok, but, Im going to make a order from tower , All i should need is
http://www2.towerhobbies.com/cgi-bin...1&I=LXFAZ8&P=K
http://www2.towerhobbies.com/cgi-bin...?&I=LXHLV6&P=0
Do i realy need this, or will the stock on do?
http://www2.towerhobbies.com/cgi-bin...?&I=LXCPX4&P=0
Im thinking this is all i need????? thanks
Old 05-14-2006 | 12:37 AM
ORIGINAL: xstar
dude don't buy that 18tz, you need the rotary carb. i'm selling mine if your interested.
Old 05-14-2006 | 12:52 PM
RCsHPI's Avatar
"dude don't buy that 18tz, you need the rotary carb. i'm selling mine if your interested."
just curious why you said he needs a rotary carb instead of a slide
SLIDE CARB IS ALOT MORE EFFICENT THAN A ROTARY CARB
why would you say dont buy a slide??
hey Xstar, YES everything you have is perfect and I have the THS pipe, its AWESOME...also dont get a rotary carb get the O.S. w/ the slide carb
GOOD LUCK BRO~
Old 05-14-2006 | 02:21 PM
to run a slide carb you need a new servo horn piece but it is only a few dollars.
http://www2.towerhobbies.com/cgi-bin...?&I=LXCXF8&P=7
Old 05-14-2006 | 04:32 PM
Thats what i needed to know. Thanks sooooo much. As for as the servo horn, i have a few that came in the kit... I was wonting the slide carb couse i was to told that the slide was better for onroad.. thanks againn
Old 05-14-2006 | 04:54 PM
Does anyone know of a slide carb that will install on the hpi .18ss engine? Have the rotary carb and I hate it. Cant get it to run right. Idles way fast and when you hit the brakes, the engine dies!
Old 05-14-2006 | 05:01 PM
thats minor set up problems. first your idle trims are set to high and the idle screw is turned in to far. put the brake on and hold it and watch how the carb closes all the way with air filter off.
Old 05-14-2006 | 07:27 PM
Looked at it again and it will not hold settings. It looks like the nut on the side of the carb is loose. Turned idle screw got it set right but when I hit the brakes it wont come back to original setting. Think I will have to make a trip to the LHS and see if one of their guys can get it for me.
