Cedar Hobbies B-17????
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Twin & Multi Engine RC Aircraft >> Cedar Hobbies B-17????
Page: [1] 2 3   next >   >>
Login
Cedar Hobbies B-17???? - 5/11/2006 2:51:38 PM
PE2fan
Status: offline
Twinman are you out there??
Did you ever finish the production model and could you give us some insight?
I am seriously considering this plane but need some reassuring.
Will it Saito .40s be a good fit? This is most urgent answer needed. They are discontinued. I have 2 already and am thinking of grabbing 2 more if they will work good, before they disappear completely.
What kind and number of servos are we talking?
Will I be needing more than my JR 6102 to fly it?
What kind of multi experience is recommended for flying one of these?
TIA
Micheal
_____________________________
Club Saito #299
       Post #: 1
RE: Cedar Hobbies B-17???? - 5/14/2006 10:03:16 PM
twinman
Status: offline
YOUR KILLING ME!...Tee Hee.
Ok the production versions will be here Next Friday..or so Neil Tells me
The sample for production just arrived this week...No, it is not ready to fly...Neil!!
This is Mother's day...she does not see me on RCU!!!
To answer your questions.
Saito 40's would in my opinion be over kill,,,,,,but...the first two prototypes, I flew had Magnum 32's two stroke and scale three blade propellors...Can you say unlimited vertical!! IF sanity...and remember you are on the twin forum...twinsanity rules... prevails here then yes they could work, but four ounce tanks are about the max size for the nacelles. Would use three blade propeler..you do not need the extra thrust of two blades...and it looks cooler sitting there on the flight line! Could you put larger, yes, but the neat built in servo tray would not work for throttle. This servo set up in on the left side of the nacelle, so it allows your throttle mechanizm to connect with no headaches.....Yes I am working on pictures...Your killing me.
FYI, this is the final version of FIVE prototypes to get his right. The first one, http://www.rcuniverse.com/forum/m_2447788/anchors_2454095/mpage_1/key_four%252Cengines%252Cone%252Cfuel%252Ctank/anchor/tm.htm#2454095 and I told him that asking the pubic to buy four fuel pumps was out of the question.
The kit progressed with further improvements and modifcations...note, two were never built, but Neil was determined...What you want me to fly another plane that is not mine...I'm IN!! Linkage to the tail wheel..solved..Servo modual for the tail wheel...no linkage...fuel tanks..one no way..four and scale look...big mess...solved..engine control...where to put servos??? solved..neat way...Inside nacelles and still scale look. 81" wing and four engines too hard to move...( Personally I have Suburban and it fits just fine, but big SUV's are out right now..but I am keeping it!!)...now two piece wing...scale look, can accessability...removable canopy arrangement with dove tail interlock..neat...Landing gear scale look...oleo struts standard...no retracts are designed at this time...not sure of Neils future plans on that one. Problems with elevator and rudder strength and control over long distance..two elevator servos in tail area and pull pull for rudder..Not sure if the pull pull is standard, but I would recommend for installation ease. Nacelle design..plastic..crummy..fiber glass..cracks on most planes..built up with fake cylinder..or spokes..Good. You guys paint as you want.
How does it fly?..Well, this is my first experience with four engines...(OK, the five engine Kadett does not count!!!. )There are others who are more experienced with this bomber. In a word, really MUCH easier than I expected and MUCH lighter wing loading than other bombers. Landing was just slightly more than most sport planes due to the large wing area.
Now, Take off...This is a tail dragger and four engines. I have been told that one of the problems with the B-17 is low speed control as you roll out. You hit a transitional area as you roll where the tail wheel comes up, but the rudder is not effective enough yet. This I was warned about and took it to heart..IS true. It goes where it is started and pointed. I chickened out and had assistant hold the plane in a safe direction and let it go at full power..no problem..(shaking hands do not count)( WISH THE PEANUT GALLERY WOULD STOP THE BETTING ON CRASH ZONES!!) Now, I have a few ideas on this, but on prototypes I could not experiment with gyros for the engines..and yes on twins I have done that successfully, There is also the coupling of rudder to engines which I do on a regular basis for aerobatics,but have not tried here. One note on that coupling..DO NOT allow it to work at low throttle settings..or you will have the plane running away from you each time you hit the rudder. I set it up for high,,above 50% settings.
Would I suggest to ANYONE that you rush into a four engine bomber with NO multi engine experience?? NO WAY..My favorite question,,do you ALWAYS fly coordinated with ailerons and rudder input?...no?...don't do this!!! While I have been lucky to not experience and engine out on the prototypes,,I have had it on the vertical test and at full throttle the Plane will YAW BAD!! This is NOT the time to get good with rudder control to correct yaw due to a failed engine in flight.
Now, I am not trying to scare anyone, but the same holds true for ANY multi-engine plane. Fly with rudder, or you are going to crash some day due to a spin at the loss of an engine. Also always do the vertical test...particulary with FOUR engines...do with a helper!!
As for special radios..no..I flew both prototypes on only four channels...so far...see above...I bought this one..it is mine to do whatever I wish!!. You must have at least six Y cords..Three for the engines to one channel, one for the ailerons..one for the elevator.
Let me get back to you on description of the servos and number. The throttle servos are special due to size. The tail wheel servo is a mini metal gear recommended. The others,,two for ailerons, two for elevators..one should be reversed and one for rudder are ALL standard servos..nothing special.
(in reply to PE2fan)
       Post #: 2
RE: Cedar Hobbies B-17???? - 5/14/2006 11:42:54 PM
shanksow
Status: offline
Thankyou Twinman -
I too have become interested in this B-17 ARF and I am thinking of buying one. In my case, I'll just have to set it aside until I can afford to get a twin engine trainer to play with first.
Don W. Shanks
http://aerospacedreams.blogspot.com/
(in reply to twinman)
       Post #: 3
RE: Cedar Hobbies B-17???? - 5/14/2006 11:44:04 PM
twinman
Status: offline
I have asked for help on this one with flight assistance from our buddies at the warbird section.
http://www.rcuniverse.com/forum/m_4277552/anchors_4277712/mpage_1/key_/anchor/tm.htm#4277712
I am not going to attempt to give advice on the flight characteristics of a B-17 based upon only four flights, so I decided to ask for help.
Hope this helps as we progress.
Twinman
       Post #: 4
RE: Cedar Hobbies B-17???? - 5/15/2006 12:40:50 AM
PE2fan
Status: offline
Thank you for the info. I am going to go ahead and top off my Saito 40s at 4 in preparation for flying this in the future. I am thinking I will probably buy in the fall for build over winter. I need suggestions for a twin that would be a good starter into multi's that would work with the Saito's for the summer. Another thread perhaps.
Club Saito #299
       Post #: 5
RE: Cedar Hobbies B-17???? - 5/15/2006 12:55:55 AM
twinman
Status: offline
Well, how about a twin stick arf?
Go to http://www.rcuniverse.com/forum/m_4152450/tm.htm to see what others say. Yes, I have one too. Not a warbird but I NEVER recommend a warbird twin for a first plane. It was also reviewed in RC report a few months ago.
This is larger than the twinstar and your engines will work and fit fine. Landing is actually similar, if anything the twin stick comes in a little hotter. I guess this is due to the full symetrical wing, but a blast to fly. Yes, it will fly on one engine safely, but it WILL make you learn rudder control if it happens. I would prop it with three blade props similar to what you would put on the B-17...saves money and perhaps the slower take off speed will simulate.
ALWAYS do the vertical test with a helper on any twin or multi.
If you have the time to build..check out my latest project below at http://www.rcuniverse.com/forum/m_4277196/tm.htm
Good Luck,
Twinman
PS Will keep you posted on progress.
< Message edited by twinman -- 5/15/2006 12:57:44 AM >
       Post #: 6
RE: Cedar Hobbies B-17???? - 5/15/2006 1:08:45 AM
PE2fan
Status: offline
Umm, I thought the Saito's would be a bit on the small side for the twin stick. Remember these are 4 stroke 40s not 2. Everyone seems to be flying the TS with .46 2 strokes or more.
Club Saito #299
       Post #: 7
RE: Cedar Hobbies B-17???? - 5/15/2006 1:21:20 AM
twinman
Status: offline
While I am NOT a four stroke expert, can you prop them for thrust over speed. 12" for example?
I fly mine at most of the time 1/2 throttle unless I want full aerobatics..so run your engines a little faster?
A stick is not supposed to fly fast for most fun...OK, so I do it...but I'm into multi's that allows craziness.
Twinman
       Post #: 8
RE: Cedar Hobbies B-17???? - 5/15/2006 1:24:54 AM
PE2fan
Status: offline
Largest recommended prob is a 11x5 or 11x6. I could prop one of my broken in ones with a 11 and see what kind of rpm and response I can get out of it.
Club Saito #299
       Post #: 9
RE: Cedar Hobbies B-17???? - 5/15/2006 1:36:12 AM
twinman
Status: offline
OK, I run 12x4's on 40's and 45's two strokes. Similar load factor. Just a thought. Try that.
I try to get trainers to try those for more thrust.
Twinman
       Post #: 10
RE: Cedar Hobbies B-17???? - 5/16/2006 1:18:12 AM
twinman
Status: offline
OK,, anything worth doing is worth doing backwards first.
The plane in these pictures is the production proof model,,so no one have a fit over no decals and there are small detail changes, but this basically is the plane as it will arrive next week.
What you see in the below pictures took 22 minutes from box to setting on the included oleo struts..Might just take a bit longer to add the radio..batteries..engines..servos..controls..linkage..ect...but had to see it.
Here it is right side up
Twinman
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 11
RE: Cedar Hobbies B-17???? - 5/16/2006 1:20:29 AM
twinman
Status: offline
Here it is upside down. Yes, those are working oleo struts.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by twinman -- 5/16/2006 1:31:57 AM >
       Post #: 12
RE: Cedar Hobbies B-17???? - 5/16/2006 1:29:10 AM
twinman
Status: offline
Inside the fuselage. The top cover is split to allow access the the radio gear and wing hold together bolts, without removing the wing. Yes, you see two wing tubes. It is a two piece wing at 79". If the extra one inch is needed..do not slide into the fuse so deep and make a spacer.
The front cockpit area has one screw holding it and it is doweled to the main cover and recessed.
Weight at this point..5.5 pounds...total!
You can install all the rear servos here above the wing or it is designed for separate split servos for the elevator mounted in the rear of the fuse. There was not way to really tie the elevator halves together and use one servo on such a large plane and with the tail design, and not have a flutter risk.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 13
RE: Cedar Hobbies B-17???? - 5/16/2006 1:34:29 AM
