majortom-RCU
NH, USA Status: offline
Blw, you probably already know this, but for others who might see this and want to try it, I will just say that while you have your fuselage open, you ought to take some measure to restrict the side-to-side movement of your elevator pushrod. I notice the guide hole is a loose fit around the pushrod. If the pushrod is free to flop from one side to another, it can impart significant differential between the two elevator halves. I have sometimes used a couple of pieces of balsa snugged up (not tight, just snug) to the sides of the pushrod, then CA'ed them to the former. If you cut a diagonal corner in each piece to let the pushrod ride in, that works well enough. On other occasions I have used a couple pieces of foam rubber laid up against the sides of the pushrod, and gooped them to the former. It doesn't take a lot of pressure to stabilize the sideways movement, and the foam rubber presents very little friction on the pushrod. If you link up your elevator halves with the fuselage open, then just move the pushrod from side to side with your finger, you'll see a significant differential movement in your elevators.
