flatlandmike
KY, USA Status: offline
quote:
ORIGINAL: bodywerks "fromeco 4800 battery yes big but only 3 oz bigger gets me redundency" I am confused by this statement. By "gets me redundancy", do you mean that you have two Fromeco 4800's? That's the only way it could be redundant, as far as a power goes. If that's the case then the extra battery actually adds over 1/2 pound, not just 3 ounces (6.6 oz for the battery, 1.5 for the regulator, 1 or so for that "miracle" switch,, and another ounce or two for all the extra wiring and foam and velcro). You could have gone with two 2400's and still had redundancy and saved 1/2 pound. Those miracle switches are also an ounce heavier, each, than the stock switches that come with the regulators. "1 ign kill module weighs .3 oz including servo wires " If it is a Smart-fly or electrodynamics, the RX unit and tx unit weigh .3 ounces each, not total, and I am not sure they include the wire in their claimed weight - not that that would explain the extra pound of weight you have. And if you do have a smart-fly cutoff, you don't need a switch - that'll save you another ounce I also see a TON of extra wire all bundled up in there that probably doesn't need to be there. That will add 3-4 ounces in a hurry. It also appears that Kentucky averages 50-70% humidity, so you probably have an extra 4-8 ounces in water weight compared to here, for example, where we are lucky to get 15%. I order my batteries with 2 jr leads so i don’t have to worry about one switch and reg going bad the odds of 2 going bad at same time are acceptable to me The 4800 is self redundant if one cell goes bad the bat runs on just 2 so there’s the redundancy call and ask Kurt about it if you want to know more so like i said 3 oz i have taken out far more than that on this plane there’s no extra wires as the switches and battery are close enough to not need it I gave you accurate weights on every thing as weighed by me with that scale including the kill switch which is super light and ill get a link for you and others as it is a great little add on to lose the choke servo for an extra engine kill Miracle switch 1 oz normal switch and reg 2 plus ozs There is no more wires there than are stated as needed in the manual that would put the battery were it is in the manual there’s some wire rolled up next to the rx (ele wire)but is what would be needed to put the rx were every one else’s rx is 2 more inches to the right and 2 more inches up Do you know how much Velcro you would need to use to get an ounce i used less Velcro than the zip ties the manual said to use so i saved weight with those each peice of velcro i used was less weight than ech zip tie I didn’t use the wheel pants 5 to 6 oz weight savings could be more including hardware So like i said besides the battery and muffler wares the extra weight This is a real issue and i dont know why some one from Aero-works hasnt addressed it PS: believe me there’s nothing that went in this plane with out me mulling over the weight effect and this gear is the very same gear i used in my 28% wild hare extra that weighed 16.5# with the fiberglass gear and carbon tube
< Message edited by flatlandmike -- 5/13/2006 2:31:24 AM >
_____________________________
www.jerseymodeler.com Special thanx to The Crew Mike B. Jim Z. Ed J. Jim S.
