RE: Nitroplanes Seawind
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Seaplanes >> RE: Nitroplanes Seawind Page: <<   < prev  1 2 [3] 4 5 6 7   next >   >>
Login
RE: Nitroplanes Seawind - 6/30/2006 10:53:15 PM
jrf
Status: offline
(edit) Comment no longer necessary.
Jim
< Message edited by jrf -- 7/1/2006 3:51:46 PM >
(in reply to RVman)
       Post #: 51
RE: Nitroplanes Seawind - 6/30/2006 11:48:23 PM
viper21
Status: offline
Tom and Roy, sorry I was just trying to help I have been flying all sorts of planes of water so I thought I might be able to help.
Good Luck Guy's I hope you get your planes sorted out I know how much of a pain it can be fly a plane that does not perform like it should.
Joe
(in reply to jrf)
       Post #: 52
RE: Nitroplanes Seawind - 7/11/2006 1:15:02 PM
rhklenke
Status: offline
I just looked at the Nitroplanes site and you know, there are NO pictures of their Seawind actually flying! There is only one picture where the plane is "off the water" and its 45 degrees nose-up, the prop is stopped, and you can see the boots of the guy standing behind it that just threw it for the picture...
Looks like something to stay away from to me...
Bob
(in reply to viper21)
       Post #: 53
RE: Nitroplanes Seawind - 7/19/2006 10:37:44 PM
Fast Freddy
Status: offline
I've seen the site a few times and nothing has changed. No flight pictures, no manual, no video, no response, no nothing! Strange way of doing business. I'll keep my money thank you very much.
(in reply to rhklenke)
       Post #: 54
RE: Nitroplanes Seawind - 7/30/2006 5:47:23 AM
heinz
Status: offline
Sounds like that is the way to go . I purchased a gp seawind and tried it out ,the bottom came apart , on landing she bounced like one does once in a while and basically and the sides seperated from the bottom. I consulted GP and they said that because I bounced the plane they concidert that a hard landing and would not replace it. By the way all the formers shatterd .Now we all have bounced on the runway once in a while and none of the planes ever came appart like that. I also find that the construction method on the GP plane is not up to an exceptable level. If you notice the main hull is made of three parts, two sides and the bottom and that is where the weakness is . So before you buy check it out thurrowly. Thats all I have to say. By the way that seawind cost us over$400.00 in canada.
(in reply to Strykaas)
       Post #: 55
RE: Nitroplanes Seawind - 7/30/2006 12:45:51 PM
souslin
Status: offline
I've had my NP Seawind on the table for a few days, just staring at it. The manual, in plain language, sucks. Basicly it tells you where to put the wings, tail peices, etc. But being a modeler for many years, I already knew that. The concerns I have are the canopy, not sure how I will handle that, and things like the wing mounts on a tube, and a 12 inch rod in the rear of the wing, and then a bolt into the wing from the inside, just behind the wing tube. I haven't figured out how I will get my hand or tools to tighten the bolt after it has been started! One review I read said it took 22ozs of lead in the nose to balance it.
The other problem of both the NP and the GP is they are so hard to take off from the water. One guy stated it is considerably easier if you drop flaps on take-off, and I would suppose use ailerons to keep wings level. I'm thinking of using a G90(which I already have), but if I haden't already blown my wad on the plane, I've wanted to try the RCV 91 four-stroke. It would be a great fit.
We're having a float fly in a couple of weeks, but I doubt I'll have it ready by then. Lots of flying to do. Good luck with yours, and I think we did get the better plane. Hope it proves out.
       Post #: 56
RE: Nitroplanes Seawind - 8/17/2006 2:00:42 PM
Dale Campbell
Status: offline
I built the Great Planes-Seawind last winter and flew it 6 times out of 15 atempts to get it airbourne. It bounced every time. On the last flight it bounced in the air about 3 feet high and slammed back to the water doing a lot of damage. I gave up and purchased the Nitro model. I just recieved my Nitro-Seawinds. There are no instructions at all in the box. I tried calling and faxing Nitro with no answer. Does anyone have a set of instructions they could e-mail me. My e-mail is dalecamp@epix.net . It would be appreciated. Thank you, Dale Campbell
(in reply to souslin)
       Post #: 57
RE: Nitroplanes Seawind - 10/21/2006 7:22:43 PM
heinz
Status: offline
To ACMCELROY
Hi , I tried to test fly mine and found it tail heavy taking of from land, and it wanted to snap violently. What C.G. did you end up using, and elevator throws?
Comparing the CG on the GP model to the nitro planes there is a hugh difference. GP states 26 mm to the nitro models of 90mm and GP states not to deveate from their location.
(in reply to RVman)
       Post #: 58
RE: Nitroplanes Seawind - 10/21/2006 7:38:48 PM
ryan_m
Status: offline
mine was pretty tailheavy too (Nitroplanes) but I mounted the rudder servo on the rear hatch, not in the main wing area like the manual calls for. I added about 6 oz. of lead in the tip of the nose to balance it out. Let's just say the first flight was interesting... scared me to death and I'm amazed it is still in one piece. It's much more flyable now that it's balanced better.
Flaperons are VERY helpful for takeoff if you have them configured.
_____________________________
(in reply to heinz)
       Post #: 59
RE: Nitroplanes Seawind - 11/10/2006 4:57:44 AM
heinz
Status: offline
Ryan
Did you use the Cof G as they called for in the book, or did you move it to another location
(in reply to ryan_m)
       Post #: 60
RE: Nitroplanes Seawind - 11/10/2006 4:41:20 PM
ryan_m
Status: offline
Not sure what you mean by Cof G... I assume center of gravity?
I found it a bit tricky to balance, the first flight I *thought* I had it balanced per the instructions, but after it landed it turned out to be significantly tail heavy, that was why I added the 6 oz. of lead in the front. It is now balanced per the instructions at the recommended CG point, or maybe just slightly back from it (maybe 1/8" or so).
(in reply to heinz)
       Post #: 61
RE: Nitroplanes Seawind - 12/14/2006 3:20:32 PM
CKS
Status: offline
Hi,
i've been keeping track of the two Seawinds on the market; I have the GP kit in progress. I did notice you set the CG at 900 mm (back from the LE). Comparing that with my kit, it's way too far. That I think is the reason for your problems. The GP CG is only less than two inches. strange but that's where GP said it should go. I hope this helps/
CKS
(in reply to acmcelroy)
       Post #: 62
RE: Nitroplanes Seawind - 1/5/2007 5:45:23 AM
truevine77
Status: offline
How's the Nitroplanes Seawind working out for all you intrepid flyers? How are the take off and landing characteristics? I've just ordered one and I'd like to keep up with your progress and hopefully have something to eventually share re my experiences.
thanks
(in reply to CKS)
       Post #: 63
RE: Nitroplanes Seawind - 1/5/2007 1:43:40 PM
CKS
Status: offline
I've not completed the GP Seawind yet; too busy flying. The weather here is remarkable for Dec./Jan. Reminiscant of Spring. However I want to pass along a few obversations about the GP version. I'm using a standard servo for throttle- there's plenty of space. The recommended distance oof the prop nut from the firewall is about 1/8" too much. I had to remove the engine and mount and re-drill it. Also. those servo cable tubes; don't need em'. Just let them dangle down and grab them. I WILL however drill a hole in the tip of the fin and install an antenna tube. I'll be flying from salt water so my Rx and battery are going in a 'Strong Box'- the larger one. i'm going to mount it as a far forward as I can get it to avoid a lot of nose weight. What additional weight I need will be in the Strong Box as well. The recommended 36" servo extensions are way too much; used 24" and they work fine. I should have it ready soon, I'm loath to go swimming for it before Spring. For me the water has to be at least 78F.
(in reply to truevine77)
       Post #: 64
RE: Nitroplanes Seawind - 1/5/2007 2:00:53 PM
Dale Campbell
Status: offline
I also have both Seawinds. The Nitro model flies just like the Great Planes model. They are both very sensive on elevator control. The Nitro model has better wing tips and gets off water easier. But they can supply no parts if you damage it. I bounced one of my landings and it dove into the water and blew the canopy to pieces. That was last summer and they still can not provide me with a replacement. So I had to glue the old one back together. Set your elevator for short travel to make it less sensitive. On your Great Planes model velcrow a set of pontoons to wing tips to keep your wings from dipping under water on take off. Have fun, Dale Campbell
       Post #: 65
RE: Nitroplanes Seawind - 1/5/2007 2:19:32 PM
CKS
Status: offline
It's been by experience that sensitive elevator is an indication of the CG being too fat art.; bringing it forward can't hurt. Yuo can always east it back.
(in
