shakes268
TN, USA Status: offline
Ok, I think you have the same problem I had. I don't think its the tube, I think as the wing widens going into the saddle that the sheeting on the side might be too tight of a fit. It needs to fit flush because those steel pins go in and you put the washer/o-ring and kotter pins in to hold the wing on. If its not flush, the wing could move around a little and not be held tight at the root. Here is something to try. Take off the wing that fits in. Now, slide the wing tube out some on that end and see if you can get the wing you're having trouble with to go in flush. If it does not, its not the wing tube. If it does, might be something with the wing tube.
