Rezagh
CA, USA Status: offline
Doug, Mine never did vibrate out. Now it's a good idea to use neoprene washers. For those who want to remove the stab for transportation, I don't recommend loctite because it can in some cases strip the blind nut or damage the threads on the screw or even stripping the phillips head unless you are using socket cap screw. I would hate personally to redo the blind nuts If you won't be constantly taking it off and putting it back on, using loctite is not problem, otherwise neoprene wahsers are great! Thank you, Reza
_____________________________
Quique's Aircraft Company
