Rezagh
CA, USA Status: offline
Dear All, We have listened to you! We have improved and modified our Yak 102" both structurally and cosmetically. Following is the list of things that have been done. Covering: After problems that we encountered in the second batch of our 102", our OEM has prepared the balsa surfaces to a better quality finish. Also new technique is used to apply the Ultra-cote. The overall quality of the film finish should be outstanding. Landing Gear: Wider base, New resin therefore less flex. Canopy: Canopy mounting system is improved. A pin attachment to the rear of the canopy/hatch is added to keep the canopy from vibrating. Canopy frame has been improved and a bead of silicone has been applied at the bottom of the canopy to the plywood. Canopy is tinted blue. Hinge Slots: To insure minimum gap and full deflection capabilities, we have improved the shaping of the hinge joining area with a sharp V on both fixed and movable surfaces. New shipment of our second generation Yak 102" will arrive on May 23rd. You can call us at (937) 629-0339 to order yours. Thank you for being our customers and we make sure to provide you the customer service you deserve to get. Quique's Aircraft Company
_____________________________
