AK, USA Status: offline
I think I am going with the WRAITH 7K & Quark 33amp Car Pro Combo from B-P-P. Heres the link, http://www.b-p-p.com/proddetail.php?prod=db_wraith . And I can just use the stock gearing. How would you gear it?
CA, USA Status: offline
I havn't, I just boiled my gears, then lubricated them all with Traxxas lithium grease. A dual mamba is a waste of money, one moter will be faster then the other, and it will put load on the other motor and cause it to burn up.
It was for a little bit, while trying to replace a broken screw, the screw broke off so now I have to order another part. I also want to say that the stock MLST radio does NOT work well with the Quark. If you have an aftermarket radio your in the clear though.
Joined: 1/5/2006 From: Shanklin, UNITED KINGDOM Status: offline
quote:
ORIGINAL: -Inverted- A dual mamba is a waste of money, one moter will be faster then the other, and it will put load on the other motor and cause it to burn up.
Lots of people have run dual Mambas/Hyperions etc. with no problems. Check 1/18th.com. What does tend to happen is that the diffs disappear very quickly, the tires are extremely hard to keep on the rims and the front wheels never seem to touch the deck. With dual mamba systems, just turn down the power on the motor that gets hot, problem solved.
Incidentally the diff problem is intermittent between trucks. You get some people (like me) who have never blown a diff, and others that blow them every 2 minutes (literally). The difference is getting a perfectly formed ring and pinion from the factory and a perfectly formed diff housing that doesn't allow slop in the bearings.
Xtants MLST:
< Message edited by Lilredmachine -- 5/15/2006 5:36:25 PM >
Lots of people have burned up dual motor brushless systems, one will be faster and created a load which in turn burns up the motor. Some are just lucky, same as the differentials. Im on brushless and have never replaced my differentials, I just boiled and lubricated them.
PA, USA Status: offline
i dont think its any faster than about 40mph, Depending on the batteries but im sure the torque is outta hand I have a hyperion 6k in my MLST and its hauls two would be outta hand I'd like some vids of that.
Joined: 1/20/2006 From: kent, UNITED KINGDOM Status: offline
im thinking about dual brushless , why cant we install the 2 motors without the pinion gears first, then pass a soft dc voltage thru the motors so that they line up, then install the pinions... then, wire them up to the same esc, because the spur gear will lock them at the same phase all the time they should behave as one single motor... of course this is assuming that the esc has unlimited output capacity or you make it so that it doesnt burn itself up...
_____________________________
Hey how did you do that... Practice, man But thats what they always say! Yeah cuz theyre always right....
