RE: Mini LST
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> 1/16th, 1/18th, Mini & Micro RC Cars >> RE: Mini LST
Page: <<   < prev  1 2 [3] 4 5 6 7 8 9 10   next >   >>
Login
RE: Mini LST - 5/30/2006 6:23:31 AM
-Inverted-
Status: offline
The motor will go first.
_____________________________
The Living Legend
(in reply to unseen1)
       Post #: 51
RE: Mini LST - 5/30/2006 6:38:46 AM
sit1
Status: offline
So you must have Ni-MH charger with Dean plug for that battery, don't you?
Question: can I change the stock charger (wall charger) to have a Dean plug? In this way, if I change the stock battery to have dean plug, I can still charge it with the stock charger.
(in reply to -Inverted-)
       Post #: 52
RE: Mini LST - 5/30/2006 6:43:56 AM
-Inverted-
Status: offline
Yep!
You can but the stock charger is sooooo slow.
The Living Legend
(in reply to sit1)
       Post #: 53
RE: Mini LST - 5/31/2006 5:34:43 AM
Dokioto
Status: offline
Inverted what charger do you use? With the stock battery and charger how long dose it take to charge?
JR XS3 Synthesized Transmitter... What more could a guy need?
       Post #: 54
RE: Mini LST - 5/31/2006 9:10:04 AM
Jrgunn5150
Status: offline
I just had to register here to clear a few things up, speaking from my personal experience.
I bought my Mini LST used in January, with a Mamba 5400 already installed. I ran it around for a month on 6 IB1200 cells, no cogging or burning, was actually a nice torquey motor, great acceleration. I then upgraded to a 6800, since I already had it. On the same 6cells, it was faster top end, little less low end, but really needed to be geared down (I was running a 24 tooth pinion).
Next I switched to the fun stuff, I purchased a second 5400, and added both esc and motor's, with 25 tooth pinions and a Apogee 1570 3cell pack. I used the Castle link to get the settings on both exactly where I wanted them, great stuff. Also, no motor's or esc's went up in flames. Next came dual 6800's, same effect, although I really wish I could have geared that up a little more. Even with the throttle curves set very conservatively it would flip from a 20 mph roll. Finally just for giggles, I added 2 8000's. That was just ridiculous, couldn't control it no matter what the settings. Very entertaining though, again, no esc's or motors died in this mayhem.
Recently I've ordered a Wraith, it should be here this week. I would like to get the truck back where it's actually drivable on all surfaces, rather than just up and down the parking lot due to the ridiculous speed and wheelie power. Although I'm sure in a month tmeptation will get the best of me...
BTW all this was done with a complete Monotuning kit, CAW axles and hex's, and 1/10th scale wheels and tires.
Another note, Shawn Palmer from Castle Creations did this quite awhile ago, and okayed it.
In summary, a Mamba can push a Mini Lst just fine, and is a nice upgrade over stock, just get some good cells, and more cells are always better than less. Also, two Mamba's are even more fun! And they don't "burn up". I find it hard to beleive I have "gotten lucky" so many different times, and for so long.
Lastly, here's a few pics.
(in reply to Dokioto)
       Post #: 55
RE: Mini LST - 5/31/2006 11:16:15 PM
Dokioto
Status: offline
How you think two of these would do in a mini lst? http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXMUP3&P=RF
And what about two of these... http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXLBZ4&P=7
Hey Jrgunn5150 that looks sweet.
(in reply to Jrgunn5150)
       Post #: 56
RE: Mini LST - 5/31/2006 11:58:56 PM
carmatic1
Status: offline
quote:
ORIGINAL: Dokioto
those are 280 size motors, you need 370 size motors
< Message edited by carmatic1 -- 5/31/2006 11:59:22 PM >
Hey how did you do that... Practice, man
But thats what they always say! Yeah cuz theyre always right....
       Post #: 57
RE: Mini LST - 6/1/2006 4:38:02 AM
Jrgunn5150
Status: offline
Normally, yes, but people have been running the Reedy motors with good results. I haven't heard anything about the other ones.
Aren't the Trinity Cobalts 280's also?
(in reply to carmatic1)
       Post #: 58
RE: Mini LST - 6/1/2006 5:49:27 AM
Racing T
Status: offline
did your single mamba setup overheat the motor? and how your gears hold?
       Post #: 59
RE: Mini LST - 6/1/2006 5:53:53 AM
Dokioto
Status: offline
I have been looking for brush and brushless motors that work good in the mini lst so I now what to get when I get my mini lst. Any way I have only found a couple brush 370 size motors, but they don't sound like they are the best choice for me. On page two of this thread Inverted suggested some brush motors and some of them were 280 size motors. Well my point is can the mini lst use 280 size motors?
< Message edited by Dokioto -- 6/1/2006 5:54:59 AM >
(in reply to Racing T)
       Post #: 60
RE: Mini LST - 6/1/2006 5:57:27 AM
Jrgunn5150
Status: offline
My Mamba didn't overheat ever, except when I got a bad esc in a new set. I never took temp readings, just touch, but never too hot too touch.
Yes the Mini Lst can use 280 can motors, that's Mamba and Reedy size.
       Post #: 61
RE: Mini LST - 6/1/2006 6:23:11 AM
-Inverted-
Status: offline
Im converting to brushed, i'll do a report once done.
The Living Legend
       Post #: 62
RE: Mini LST - 6/1/2006 9:56:42 PM
rcMitch71
Status: offline
What motors are you gonna be using?
Mini Lst-Ball diff, yellow dish rims, mini atx tires.
E-Flite Tribute
       Post #: 63
RE: Mini LST - 6/2/2006 12:54:00 AM
-Inverted-
Status: offline
SECRET! But Im expecting a great setup. The objective is low matienence, affordability, and a great all around setup.
I own a Dynamite Vision Peak Ultra, great charger for the $$$. The stock charger takes about 8 hours to charge the stock battery.
