Reload this Page >
GREAT PLANES YAK 54 BUILD THREAD
Old 07-19-2006, 12:27 PM
  #51
marmitas
marmitas's Avatar
Default RE: GREAT PLANES YAK 54 BUILD THREAD
ORIGINAL: Machinegun21
Sound good, when i get mine i will prob put a 1.60 on it. can the 1.60 on the yak do full 3d?
I am not good enough to try a full range of 3D but hovering, high alpha flight, climbs form a hover, etc. are no problem. Jason Knoll appeared to have no problems doing a wider range than I'm capable of doing.
Old 07-19-2006, 10:01 PM
  #52
Machinegun21
Well just keep practicing, you'll get better.
Old 07-20-2006, 02:06 AM
  #53
I Buy Houses
I Buy Houses's Avatar
Hi,
Just got the plane flying and she is awesome. 9 Flights over the last few days
DA-50 weighs in at 13.9LBS
Li-Ion batteries and Micro throttle servo
Just Tintied the Canopy and it looks great. I'll post a pic here soon.
Old 07-20-2006, 03:37 PM
  #54
Vlad3D
Hy guys !
I"m planing to put an mvvs 3.15 in this plane but i don't know if this engine have enough power for 3D manuvers !
What do you think ? It will work ?
Old 07-25-2006, 03:54 PM
  #55
charlesdanni
I am going to be getting a DA50 for my GP Yak and this will be my first gasser. Not sure what you mean by cutting a hole in the firewall for the 1" clearance to the carb body? How big of a hole are you talking about and exactly where do you cut it out at. Also do the push pull servo in the fuselage do a good job and did you have any problems setting them up? I am go to need all the help I can get with this DA50.
Thanks to all who reply.
Old 07-26-2006, 12:42 AM
  #56
I Buy Houses
Hi Charles,
I did not cut a hole for the Carb and it works fine. I used the Pull Pull set up with just one HD servo JR Z900T Works awesome. I'm using li-ion packs for weight and have them both mounted on the motor box up fornt. The plane flys awesome.
If you have any other questions just let me know.
Old 08-09-2006, 10:43 AM
  #57
charlesdanni
Thanks for the heads up. I was also wondering do I need to put some right thrust in the engine when I mount it. It appears that this is already built in to the fusealage. I have read that you are suppose to keep the batteries at least 12" away fro the electronic ignition due to interference. Have you had any issues with radio interference?
Old 08-09-2006, 11:15 AM
  #58
The MacDaddy
My Feedback: (10)
The MacDaddy's Avatar
IBH,
Can you put some links in for the batteries and switches you used? How about some pics of the mounting locations?
Mac
Old 08-09-2006, 02:30 PM
  #59
I Buy Houses
Hi,
Here is a link for some inexpensive packs they are the same LG cells everyone else uses. http://www.batteryspace.com/index.as...OD&ProdID=2732 For switches I use the MPI HD switch and MPI 10 amp regulators.
For mounting I put the Ign battery inside the battery box and the RX pack I have next to the Receiver. I'm a little too tail heavy and would recommend mounting them both on the battery box unless you do a lot of Hovering.
Hope this helps.
Old 12-18-2006, 10:33 AM
  #60
mippe
mippe's Avatar
Hallo
I have buy YAK from GP and i thinking about putting a ZDZ 50NG or 3W 48i B2 in .
Someone who can help me with the choice?
Sorry about spelling i´m form sweden
Old 12-20-2006, 04:08 AM
  #61
k_jitsu
Hi everybody.
I've just got my GP yak and I'm thinking on a DA 50 on it. I'd like someone with this configuration to tell me if any change in right or down thrust is required for this engine. I hate to have to move the cowl after some flights to adapt it to the new position of the engine...
Thanks a lot
Javier
Old 12-20-2006, 01:47 PM
  #62
Kostas1
Kostas1's Avatar
Hey,
this question goes to all guys that have assembled this Beauty of sky!
Did you reinforced the firewall?
Old 12-20-2006, 02:58 PM
  #63
marmitas
marmitas's Avatar
I did not reinforce ANYTHING and have many flights witout any problem. I'm using an OS 1.60 but people with gasoline motors (DA 50, etc) do not have any problems either.
Don't worry, this plane is NOT built like the CAP 232 from Hangar 9. I had one of those and reinforced most of the airframe because I saw what happened to a friend that did not.
Old 12-20-2006, 04:37 PM
  #64
Kostas1
Kostas1's Avatar
Well,
so that's very good.
Greatplanes's engineers made it AGAIN!
Am,
could you please post some other pics from different views of your Yak 54?
Also,
how possible it is to make a video of it?
Old 12-20-2006, 08:32 PM
  #65
maxun
My Feedback: (12)
I you do a gas motor, because of vibration I recomend to got thrue the whole aircraft especially the fire wall, extra glue is allways good.
Old 12-22-2006, 03:03 AM
  #66
fingers73
fingers73's Avatar
I am on my second yak, the first went in doing a low high alfa knife and the left elevator servo locked in the neutral position. That plane had the fuji 50 with a bisson muffler and a 3w 20x8 prop. It would do everything you would ask of it. My setup had 1 rudder servo in the tail. the reciever and battery were on the secondary servo tray. The only thing that took a bit to get used to was the rate of descent, very steep needed a little power to not pancake it in. I would land with about a 15 foot rollout. I do not know the weight or the cg I just put it where it needed to be to fly for me. I will say I added no weight to the plane to balance. Plane number two is almost done it will havev a DA 50 for the weight. I found that the landing gear wouldn't hold the plain up very well if it has the heavier engines. In my gallery is a picture of the fuji and the gear splayed out and it is just sitting . It seems the file is to large to post here.
Old 01-14-2007, 03:59 PM
  #67
Spynete
Hey Marmitas,
me encanta ver, desde España como usas nuestro escudo en tus Post.
Hoy he estrenado mi GP Yak 54, gracias por tus consejos, y que sepas que es un lujo para mi poder leer en vuestro Foro consejos desde este rinconcito de España, cuenta con un amigo en en Cabanillas de la Sierra.
Spynete
Old 01-14-2007, 05:31 PM
  #68
marmitas
marmitas's Avatar
Hola Spynete,
(This message goes in Spanish followed with the same content in English)
Muchas gracias por tu mensaje, yo vivo en USA pero mi familia es de Casares de Arbas, Leon. Es un pequeño pueblÃ*n más pequeño que el tuyo. Está cerca del puerto pajares. Yo hace 42 años que vivo en USA pero me enorgullezco de mis raices, por eso uso el escudo español en mis mensajes. Marmitas es el apodo que heredé de mi abuelo porque tanto él como yo "explotamos" con mucha facilidad.
Thank you for your message, I live in the USA but my family is from Casares de Arbas, Leon. It is a small village smaller than yours. It is close to Puerto Pajares. I have lived in the US for 42 years but I'm proud of my roots and that is why I use the Spanish seal as my avatar. Marmitas is a nickname that I inherited from my grandfather who, like myself, could "blow-up" easyly.
Un abrazo
Andrés RodrÃ*guez
Old 01-17-2007, 04:49 PM
  #69
bartoke
Hey
Does anybody knows if the yak 54 can fly with a titan zg 38cc.
With flying I mean hover and torque rolls and much more.
Or is the titan zg 45cc a better option.
I've heard someone whose horizontal fin was come loose,
do you have the problem too?
thanks Bartoke
Old 02-14-2007, 05:07 PM
  #70
crash99
What prop should I with a OS 1.60?
Crash99
Old 02-15-2007, 01:30 AM
  #71
maxun
My Feedback: (12)
APC18X4W for 3D
Old 02-15-2007, 05:02 PM
  #72
crash99
OK guys, I am sure there has to be some video out there. I have seen the sales video from GP but I would love to see some of your video. I am picking up mine on Monday and I would love to see your planes in the air first.
Crash99
Old 02-15-2007, 05:20 PM
  #73
Kostas1
Kostas1's Avatar
Yet me too need a video.
Please HI_RES!
Old 02-16-2007, 07:28 PM
  #74
crash99
I am picking up one that is ready to go. The Length is 68" but How tall is it? How wide is it? I will be taking my 4 door truck. The short bed is is 5' 3" long. 7" in a 45 deg angle. I will have to see how tall tith the top closed. I do not know if it will fit. I don't want to take a trailer down there unless it will not fit.
Crash99
Old 02-16-2007, 11:32 PM
  #75
flyman1948
Bartoke
An earlier post addressed a way to prevent the horizontal fin from coming loose that I used in building my Yak. Remove the covering on the bottom of the plane in front of the tailwheel where there is no balsa sheeting..you can lay in a fillet of epoxy on the inside, and if your creative you can get epoxy on the top of the stab as well.
